Old Aug 27, 2011, 08:17 PM
werlec is offline
Find More Posts by werlec
United States, DE, Lewes
Joined Dec 2005
Build Log
Another J-boat build
I'm sitting here waiting for Irene to pass, so I thought I would start a build log of my 36" J-boat. I was going to build a Canterbury-J but decided I really didn't want a large 48" boat(It is one georgeous boat though!!)
A 36" size seemed more practical for me. I really like the looks of the Canterbury, so I used the same shape & proportions. I then reduced them to 75% for a 36" length.
I've finished the plug & plan to use this as a male mold to make the hull.
Here are a few pix of my progress so far. I built a plug from scrap foam, then covered it with light spacke(several times with the last coat being thin & brushed on), then sanded it smooth. I then put a thin coat of Envirotex Lite & sanded it to get rid of any imperfections then put on a full coat of Envirotex Lite for the final finish.
The next step is to try a fiberglass or epoxy hull from the mold.
werlec is offline Find More Posts by werlec
Old Aug 27, 2011, 09:02 PM
obses4sail is offline
Find More Posts by obses4sail
obses4sail's Avatar
Visalia, CA
Joined Sep 2010
looking good
obses4sail is offline Find More Posts by obses4sail
Old Aug 27, 2011, 09:20 PM
werlec is offline
Joined Dec 2005
Originally Posted by obses4sail View Post
looking good
Thanks - I hope mine turns out looking as good as yours I've been following your thread - I'm anxious to see if your version II sails as well as you hope it does. (So I can make corrections to mine from your experience)
I'm concerned about there being enough weight down low - I'm considering adding a bit of a lead extension to the keel(ala Canterbury)
Old Aug 28, 2011, 04:12 AM
Hobiestoke is offline
Find More Posts by Hobiestoke
slow & draggy...
Hobiestoke's Avatar
Albuquerque, NM
Joined Jul 2004
Yes very nice so far
Hobiestoke is offline Find More Posts by Hobiestoke
Old Aug 29, 2011, 11:13 AM
obses4sail's Avatar
Visalia, CA
Joined Sep 2010
As a mold release, I wax about 7-8 times with a car paste wax, the local big boat dealer goes about 11 times. This is the old way of doing it before PVA (poly vinyl alcohol)
Old Oct 26, 2011, 02:12 PM
werlec is offline
Joined Dec 2005
Well, after 2 less than successful attempts at a fiberglass hull from the plug, I decided to go another route, I'm building the hull in a way I'm more comfortable with - shadows & planking.
Here are the results so far. It's just about ready for the final coat of Envirotex Lite. The hull will still be sanded & painted(maroon I think).
Old Oct 26, 2011, 05:49 PM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Your hull looks very good. Looking forward to watching your build.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Oct 26, 2011, 07:54 PM
werlec is offline
Joined Dec 2005
Ed,
I hope I can come even close to the quality of #529!! A beautiful boat!!!
Erle
Old Nov 01, 2011, 08:24 PM
werlec is offline
Joined Dec 2005
A little more progress. I've donr the rudder post & the rudder servo. Thanks to Rick(Faiwind900) for the great idea for the rudder post/servo mount combination!! It really works great!!
I think the old Futaba S48 should be enough for the rudder.
Now on to the sail control servo - I plan to use a Hitec HS645MG w/180 deg. from Servo City - they seem to be the only one's with a 180deg. mod(for an extra $10)
Sorry for the lousy pix(probably shoulda' been in macro)
Old Nov 01, 2011, 09:56 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Looking very nice!
Aerominded is offline Find More Posts by Aerominded
Old Nov 07, 2011, 07:52 PM
werlec is offline
Joined Dec 2005
More progress - I've added the king plank and the perimeter reinforcement. I've also pretty much finished the rudder(2 thiicknesses of 1/8 balsa sandwiching a 1/32 ply). The servo placement is now finalized - now I have to order the hs645mg servo.
I'm now working on the crossmembers & waiting for the mold for the keel weight to cure(it's taking forever for the spackle to cure!) so I can pour the lead keel.
Old Nov 08, 2011, 08:50 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Looking good.
Ed
Old Dec 03, 2011, 09:45 PM
werlec is offline
Joined Dec 2005
Some more progress on the hull.
The lead keel is now ready for a light coat of primer & some more sanding before the final coat of Envirotex on the hull. I would have shown the "bare" keel weight "casting", but it was so crappy looking, I was embarassed to show it, but the end result is 3 lbs. of lead as far down as it can be Bondo can hide many a mistake!! It's attached to the rest of the keel with 2 stainless steel bolts.
I've also finished the deck framing & the attachment points for the sheets below deck.
After seeing Ricks(Fairwind900) 1st sail with his 36" "J", I now know about what size rig to build
Erle
Old Dec 03, 2011, 10:46 PM
Joined Feb 2004
Keep up the great work!
Old Dec 03, 2011, 10:52 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Looking good.
MILLERTIME is offline Find More Posts by MILLERTIME
Build Log 36/600 "J" type boat II obses4sail Sailboats 102 Dec 10, 2013 06:56 PM
Discussion BOAT = Bring out another Thousand Killionaire Chit Chat 7 Sep 02, 2011 07:39 AM
Discussion "J" boat (1 Meter) Capt.Crash Sailboats 8 Jun 18, 2011 03:38 PM
Discussion Looking to buy another boat! help me out! chevypower1930 Racing Boats - Electric 14 Apr 15, 2011 05:52 PM
