Old Aug 27, 2011, 12:42 PM
dpurcell is offline
Find More Posts by dpurcell
Canada, ON, Bracebridge
Joined Aug 2011
Help!
Nine Eagles battery
Hi Folks. I just got a Nine Eagles Sky Eagle. It came with a 2s Li-Po 7.4 V/180 mAh battery. Can I purchase a replacement battery that will give me longer flight times? I'm only getting around 5 minutes with the stock battery.
dpurcell is offline Find More Posts by dpurcell
Old Aug 27, 2011, 02:08 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Longer flight time ?, probably no.
The problem is a larger capacity battery will also be physically bigger, and heavier. Heavier models usually need more power to fly, more power which can equal short flight times........
Just buy more batteries to get more fun time, improving your landing skills are an important part of leaning about flying models.
eflightray is offline Find More Posts by eflightray
Old Aug 27, 2011, 04:08 PM
dpurcell is offline
Joined Aug 2011
OK! Thanks for that.
Old Aug 27, 2011, 04:25 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Yeah, you could do that. Increasing battery capacity is one of the easiest ways to gain more flight time, contrary to the post above.
The stock lipo is pretty small, so it might be tough to find any that are just slightly bigger, but here's one with almost twice the capacity. The stated weight is 21g, which is eight grams heavier than your stock battery, but if you shortened the leads you could take off maybe a couple grams.
Increasing capacity will rarely make the plane heavy enough to end up with LESS flight time as Ray says. It will force you to fly a bit faster, and the plane will need a bit more room to land, but adding a few grams shouldn't hurt it THAT much.
There is the matter of fitting it intp the plane, but it's a foamie. These things are born and bred for modifications
As long as the CG balances out, you don't have much to worry about.
Piece is online now Find More Posts by Piece
Old Aug 27, 2011, 06:06 PM
dpurcell is offline
Joined Aug 2011
Cool..so there are options!!
New Product Nine Eagles Solo Pro 328 (Nine Eagles' answer to the Blade 120 SR?) SoloProFan Micro Helis 1758 Feb 27, 2015 04:24 PM
For Sale Nine Eagles 210A TX, Flybar & Battery Klippie Aircraft - General - Radio Equipment (FS/W) 0 Mar 23, 2011 05:04 PM
Sold Nine Eagles Solo Pro or BRAVO III Battery Charger palomo Aircraft - Electric - Helis (FS/W) 0 Feb 26, 2010 10:33 AM
Sold Nine Eagles Solo Pro/SOLO/Free Spirit/BRAVO III Battery Charger palomo Aircraft - Electric - Helis (FS/W) 0 Feb 17, 2010 06:38 PM
For Sale NIB Nine Eagles Kestrel 500 with extra NIB battery RC Accessory Aircraft - Electric - Helis (FS/W) 0 Jul 20, 2009 05:50 AM
