Old Jul 06, 2001, 03:37 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You only install them if provided and required. There is no benefit to adding them if not required.
Old Jul 07, 2001, 12:19 AM
shv2sail is offline
Find More Posts by shv2sail
United States, FL, Tampa
Joined May 2001
MORE Diode Stuff
I've read a bunch of threads regarding Schotky Diodes that come with ESCs. What if your ESC wasn't supplies with one? Should a diode still be installed? If yes, where can one get a Schotky Diode?
Steve
shv2sail is offline Find More Posts by shv2sail
Old Jul 07, 2001, 12:42 AM
Greg Covey is online now
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Many ESCs already have them installed. The Great Planes ESCs are the only ones i've seen that supplies them external.
Depending upon the power switching technique used by the ESC manufacturor, it is not always needed.
You can buy schottky diodes at Radio Shack or on-line stores like The Electric Goldmine.
Greg Covey is online now Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jul 07, 2001, 07:43 AM
plinse is offline
Find More Posts by plinse
plinse's Avatar
Baden Baden, Germany
Joined Feb 2001
The shottky diode cuts of voltage peaks produced by the motor and keeps them away from the speed control and the receiver. As the cables between speed control and motor can be interpreted as antennas it makes sence to add such a diode to a motor to improve the safety of the RC system but if there is none required because of the speedcontrol it has no aditional effect on the control.
But watch out: you can destroy a control with reverse mode by adding such a diode. It is like soldering a diode onto the motor the wrong way.
Eike
http://www.schunternet.de/~eike/
plinse is offline Find More Posts by plinse
More great stuff for sale! Hacker ESC, MPI cobalt motor, Zagi packs... Heli Slime Aircraft - Electric - Airplanes (FS/W) 12 Oct 30, 2002 11:59 PM
More interesting stuff from a CD-rom Erik Johansson Scratchbuilt Indoor and Micro Models 5 Sep 06, 2002 02:30 AM
more blonde stuff AirWarriorBelgy Humor 0 Aug 30, 2002 06:44 PM
More Electric stuff on eBay georgeg Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2002 12:34 AM
