This thread is privately moderated by yomgui, who may elect to delete unwanted replies.
Old Aug 27, 2011, 08:43 AM
yomgui is offline
Find More Posts by yomgui
Joined Feb 2011
pictures of the wind tunnel
Entrance cone of the wind tunnel:
Even the belt was not enough to curve the four parts in the right position!
The curve is simply parabolic function.
The entrance cone is kind of too short, but I needed place…
Inner side surface is not perfect.
Build up with some improvisations.
The “honeycomb” (balsa) was a bit complicated to make and is still a problem, slowing down the airflow but much better for steadiness (believe or not!).
The anemometer used as reference for speed measurement:
Speed is only around 53 km/h in the test room, limited by the low pitch of the wind tunnel propeller(s) and the poor performance of the motor that spinning it.
The entrance cone should be easy to remove and replace.
The door of the test room:
USB cable:
This is just to prevent the door from falling when speed comes back to zero:
Pitot tube installed for “velocity distribution” tests:
From upside:
Exit cone from the inside:
Wind tunnel motor speed control:
Exit cone:
2800 tr/min, rated 900 W dead lawn mower motor and 2 graupner 20x12 props (needs 4 blades 20x20 and a good motor).
yomgui is offline Find More Posts by yomgui
Reply With Quote  (Disabled)
Wind Tunnel Smoke zagisrule! Power Systems 23 Feb 06, 2015 12:28 AM
Discussion Wind Tunnel F/S, not mine, but someone may have a use Stalled Modeling Science 1 Dec 29, 2011 11:35 PM
Discussion Propeller wind tunnel tests yomgui Power Systems 35 Jul 30, 2011 05:35 PM
who's got wind tunnel pics? Tim Green Electric Plane Talk 0 Feb 12, 2003 11:34 PM
sources of wind tunnel pics Tim Green Modeling Science 0 Feb 10, 2003 07:29 PM
