Old Sep 11, 2003, 09:47 PM
JVBAV8 is offline
Find More Posts by JVBAV8
JVBAV8's Avatar
Honolulu Intl, Hawaii, United States
Joined Jun 2003
look at aircraft world
(Nippon Dave)
vario props have the same looking prop nut as that spinner
they also make 3 and 4 blade hubs and scale look blades in various sizes
might look at these when running bl so I can use a 3 or 4 blade
http://aircraft-world.com/default.asp
JVBAV8 is offline Find More Posts by JVBAV8
Old Sep 12, 2003, 10:38 AM
thunder1 is online now
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
Also, the MPJet collet type of prop hub looks pretty nice.
thunder1 is online now Find More Posts by thunder1
Old Sep 12, 2003, 10:42 AM
agriebel is offline
Find More Posts by agriebel
agriebel's Avatar
Madison WI
Joined Aug 2003
I epoxied my landing gear brackets in and they are really in there. How can I remove them to put in the retract bracket?
agriebel is offline Find More Posts by agriebel
Site Sponsor
Old Sep 12, 2003, 06:31 PM
JVBAV8 is offline
JVBAV8's Avatar
Joined Jun 2003
epoxy
I don't know
it soaks into foam and turns into plastic
if you pull it out the foam that it soaked into comes out too
if you can cut it with a dremel right at the junction of foam and plastic - maybe
you don't have to worry about destroying the brackets though
might be easiser to order another wing from gws - probably cheap
then you can have two wings and one can be for belly landing on grass only
Rave Landing Gear for GWS Corsair jedville GWS (Grand Wing Servo) 5 Dec 10, 2005 11:04 AM
WTB: Landing gear plastic wing inserts and gear wire for GWS P51D or Zero Etonic Aircraft - Electric - Airplanes (FS/W) 1 Jan 25, 2003 12:23 AM
What gear ratio for a GWS Hybrid motor running on the Rare Bear Prop. JStory Parkflyers 14 Oct 01, 2002 07:47 PM
FS: Planetary Gearbox with 5:1 Gear Ratio for GWS IPS and N20 Motors GoEFlight Aircraft - Electric - Airplanes (FS/W) 4 Jun 12, 2002 08:12 PM
Gear Pulller for GWS and other small drives is available Bleriot Parkflyers 13 Apr 12, 2002 02:33 AM
