Old Sep 10, 2003, 03:25 PM
agriebel is offline
Find More Posts by agriebel
agriebel's Avatar
Madison WI
Joined Aug 2003
Gear doors for GWS Corsair
I didn't like the spindly gear on the Corsair, but I love to take off and land, so the gear had to stay. I came up with a gear door that looks scale like, and make the gear look much better.
www.hobbyhorse.com/corsair.shtml
what do you think?
agriebel is offline Find More Posts by agriebel
Site Sponsor
Old Sep 10, 2003, 03:55 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Much better!
Grejen is offline Find More Posts by Grejen
Old Sep 10, 2003, 05:17 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
The gear looks nice, but that canopy doesn't look right at all in the side view...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Sep 10, 2003, 05:24 PM
Team 30 Micro EDF
Joined Apr 2002
Here's a picture of what I mean...
Old Sep 10, 2003, 11:09 PM
JVBAV8 is offline
Find More Posts by JVBAV8
JVBAV8's Avatar
Honolulu Intl, Hawaii, United States
Joined Jun 2003
hey man you make me jealous every time yours gets better
now I want doors on mine too
but mine retract the wrong way (inboard laterally)
are those MPI units like the ones I got from Hobbyhorse?
they fit great
what's the difference in the canopy other than the overhead sunshade?
I can't see any difference
my eye is not that keen for the scale appearance (airplane looks like an airplane to me)
it's these details that can enhance scale appearance
so we all might learn what to look for
JVBAV8 is offline Find More Posts by JVBAV8
Old Sep 10, 2003, 11:11 PM
JVBAV8 is offline
JVBAV8's Avatar
Joined Jun 2003
thanks for the picture though
it will help me to make mine better
any more scale schemes that we already have decals for?
Old Sep 10, 2003, 11:15 PM
JVBAV8 is offline
JVBAV8's Avatar
Joined Jun 2003
link to more corsair fun
http://www.rcgroups.com/forums/showt...hreadid=148816
this thread may have similar interest for post veiwers
another hobbyhorse corsair with retracts
Old Sep 11, 2003, 12:01 AM
Team 30 Micro EDF
Joined Apr 2002
JVBAV8,
The one pictured in the link in the first message goes way up in the air and back down to the rear deck at a steep angle. The real ones blend into the fuselage at a much flatter angle. The canopy in the model Corsair bulges too much. Compare the CAF planes to the one in the link and you'll see what I mean...
Old Sep 11, 2003, 02:31 AM
JVBAV8 is offline
JVBAV8's Avatar
Joined Jun 2003
I see
don't think it can be done easily with a heat gun
just gotta not look as close
now I know
now I look
Old Sep 11, 2003, 03:42 PM
thunder1 is offline
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
Mike, Here's a side view of the F4U-1A. GWS is pretty close to this. But I would'nt care either way. I still love mine.
Those gear doors look great but they add a lot of drag. I believe the real plane was limited to 130 with the gear down.
thunder1 is offline Find More Posts by thunder1
Old Sep 11, 2003, 04:21 PM
Ralph A. D'Amelio is online now
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
Look good, I think I will add to mine....but the wheels got to go. BTW thanks for the speed limit on gear down, I am sure I can keep it below 130....
Ralph A. D'Amelio is online now Find More Posts by Ralph A. D'Amelio
Old Sep 11, 2003, 06:51 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
JVBAV8, those are just fakes, the gear is still fixed. I'll have to fly it with them off then on to see how much drag they add. Shouldn't be a problem when I go brushless....Still thinking about doing your retracts, but am concerned that I may not get the hole through the wing even on both sides...
Site Sponsor
Old Sep 11, 2003, 07:43 PM
JVBAV8 is offline
JVBAV8's Avatar
Joined Jun 2003
I was too
it's easy if you use a sharpened aluminum or brass tube
about 2-3mm od should be big enough for a little dubro flexible pushrod
use the middle of the inside bottom corner as the tube insertion point
use the middle of the outside top corner as a guide to rest the tube against
this aligns the tube straight down the middle of the wing and keeps the tube from wandering in depth
twist and go slowly - don't do the whole length all at once
all you can see on mine is a 1/4" hole inside the gear mount well and a 1/4" hole in the bay cut in the center of the wing
very clean install
just as long as your tunnel doesn't break the surface it will be invisible
Old Sep 11, 2003, 08:55 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
I will do it, but not for a while. I will fly it like it is, then on to the retracts....thanks for the info...
Site Sponsor
Old Sep 11, 2003, 09:37 PM
Highlander is offline
Find More Posts by Highlander
Highlander's Avatar
Lubbock, Texas, United States
Joined Jul 2003
Has anyone come up with a nice, more scale-like prop hub instead of the stock spinner? Look at the pic Thunder1 post to see what I mean. Any ideas?
Highlander is offline Find More Posts by Highlander
Rave Landing Gear for GWS Corsair jedville GWS (Grand Wing Servo) 5 Dec 10, 2005 11:04 AM
WTB: Landing gear plastic wing inserts and gear wire for GWS P51D or Zero Etonic Aircraft - Electric - Airplanes (FS/W) 1 Jan 25, 2003 12:23 AM
What gear ratio for a GWS Hybrid motor running on the Rare Bear Prop. JStory Parkflyers 14 Oct 01, 2002 07:47 PM
FS: Planetary Gearbox with 5:1 Gear Ratio for GWS IPS and N20 Motors GoEFlight Aircraft - Electric - Airplanes (FS/W) 4 Jun 12, 2002 08:12 PM
Gear Pulller for GWS and other small drives is available Bleriot Parkflyers 13 Apr 12, 2002 02:33 AM
