Old Aug 27, 2011, 09:06 AM
minivation is offline
Find More Posts by minivation
Professional tree finder
minivation's Avatar
United States, TX, Longview
Joined Dec 2010
Would 800W motor with 1150 do for a 2-3kg-ish RCM trainer?
Hi,
I'll be starting a restoration project of an old RCM trainer sometime later, and along with it I'll be performing a gas to electric conversion.
I bought a 890Kv, 800W motor (originally designed for 4S, but I'll be using 3S) and will be using a 11x5 prop with it.
Sorry for acting like an power-systems noob, but would the motor power be enough for some gentle flight (no rolling, no loops - just takeoff, fly, land)? As noted, although the motor is rated 800W, I'm running 3S, so I don't think it'll be as much. The RCM trainer used to fly with a .40 equivalent GAS engine, and the plane, empty, weighs in at 2.5 kilograms.
Thanks!
minivation is offline Find More Posts by minivation
Old Aug 27, 2011, 10:34 AM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Kv of 890, 3S and 11x5.5 is going to be pretty marginal on over 3kg as you'd only be looking at a bit over 200W.
If you can fit 12", I think you'd be a lot better of with a 12x8. if 11" is the max you can fit, then a APC 11x7 would give a bit better thrust and bit better pitch speed and should just fly it as you describe. Better still, a 3 blade 11x7, and you should have a bit more margin to play with.
ps as you can see, the 800W rating is kind of irrelevant in this case. Best not to think of "an 800W motor", but rather a power system that depending on prop and no of cells might be limited by the motor to a max of 800W.
scirocco is online now Find More Posts by scirocco
Old Aug 27, 2011, 10:41 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Even a trainer probably needs 50W-75W/lb.. let's say 3kg AUW (~6.6lb)... absolute minimum would be 330W... better would be 495W.
A rough rule of thumb for converting IC to watts is:
Watts = cubic inches x 2000.... thus a .40 IC is the equivalent of ~800W..... you can see that you have much less power than it was designed to fly with.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Aug 27, 2011, 12:45 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Have a look at this thread, there may be something useful there -
Converting RCM trainer to electric.
eflightray is offline Find More Posts by eflightray
Old Aug 27, 2011, 01:19 PM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
I have a Great Planes PT-40 ARF converted from glow. Minimal conversion work on the ARF, took the talk out and put a battery tray in so no weight savings attempted. It weighs 90oz ready to fly.
Originally flew on a Turnigy 42-40-750 and 4S 3700 and 4S 5000 pack on a 12x8 prop. Now I fly on a Monster Power 25 from Hobby Partz with a 12x6 prop and 4S 5000 battery. Flights of 10 minutes with aerobatics are the norm.
mt_100 is online now Find More Posts by mt_100
Old Aug 27, 2011, 01:22 PM
snoopy_schulz is offline
Find More Posts by snoopy_schulz
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Originally Posted by minivation View Post
Hi,
Thanks!
Hi minivation
Your RCM trainer will have a weight of about 3.3 kg with the 800W motor and a 3S lipo (~ 4000 mAh). So you should use as minimum a
14x7 Prop with your 800W motor. That gives you adequate power for gentle flight, about 340 W shaft power, 40 A. Using a 11x5
the shaft power is about 192 W. That is truly to low for gentle flight. I would suggest rather a 4S Lipo with a 12x6 APC prop.
Best regards
Micha
snoopy_schulz is offline Find More Posts by snoopy_schulz
Discussion Multiplex Twinjet: Any motor suggestions for Mach 1-ish performance? MRGTX Foamies (Kits) 28 Feb 27, 2012 08:05 AM
Help! Looking for Inexpensive Motor about Kv 600, max input ~800W scirocco Power Systems 17 Aug 20, 2011 03:13 PM
Discussion RCM Trainer 40 Wing Fit swimmer The Builders Workshop 3 Jul 24, 2011 03:44 PM
Wanted Looking for 3S 2200-ish batteries with Deans riverguardian Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 21, 2011 10:05 PM
Discussion RCM Trainer 40 Aileron Servo Mount Question swimmer Glow to Electric Conversions 5 Apr 21, 2011 09:09 PM
