This thread is privately moderated by OC Flyer, who may elect to delete unwanted replies.
Old Aug 26, 2011, 06:46 PM
OC Flyer is offline
Find More Posts by OC Flyer
Trader Rating: 1
United States, CA, Laguna Niguel
Joined Apr 2007
Trader Rating: 1
For Sale
E-flite 30-Amp Pro Switch-Mode BEC Brushless ESC- $20
$20
Brand New, never used:
Key Features
Up to 30-amp continuous current with proper airflow, 35-amp peak
5-volt Switch-Mode BEC circuit capable of 700mAh continuous current on any recommended input voltage
Drives up to 5 analog or 4 digital sub-micro servos with the BEC
3S-4S Li-Po or 9- to 12-cell Ni-MH/Ni-Cd input voltage
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cut-off with settings for 3S Li-Po (9.2V), 4S Li-Po (12V) or 74% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shutdown if signal is lost or there is interference
Programmable timing - 5 user-selectable ranges for use with a larger variety of brushless motors
Heli mode for starting the motor with a low speed ratio
Optional RS232 Serial Link available for programming (EFLARS232)
Pre-wired connectors - E-flite EC3 connectors on battery input and 3.5mm female gold bullets on motor output leads
Overview
E-flite’s 30-amp Pro SB brushless ESC offers up to 30 amps of continuous current with proper airflow and a peak of 35 amps. It drives up to 5 analog or 4 digital sub-micro servos with the BEC on any recommended input voltage. This brushless ESC includes programmable motor braking, soft start for helis and planes, timing, throttle input range, and low-voltage cutoff. It also features auto motor shutdown in case of lost signal or interference. The safe power-arm mode prevents accidental starts.
OC Flyer is offline Find More Posts by OC Flyer
Sold Flown once.....bought new::: E-FLITE 40 amp lite pro Switch Mode BEC Brushless ESC crosby Aircraft - Electric - Power Systems (FS/W) 3 Jul 27, 2011 11:20 PM
For Sale Brand New E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC Scooter33 Aircraft - Electric - Power Systems (FS/W) 0 Jul 15, 2011 09:22 PM
Sold E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC Jester707 Aircraft - Electric - Jets (FS/W) 2 Jul 07, 2011 05:37 PM
Sold Price Drop! E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC vinman0725 Aircraft - Electric - Power Systems (FS/W) 10 Jun 06, 2011 07:17 PM
Question E-flite 60-Amp Pro Switch-Mode BEC Brushless ESC Mathelo Power Systems 5 Mar 07, 2011 12:07 PM
