Old Oct 02, 2011, 10:29 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Just wanted to report back that I finally got a good ultra light setup working on my Sokol (ARC110, 4.1x4.1e, Rhino 3s1250 30C, Phx25 esc, 11.9oz AUW). First, the arc didn't smoke after 30sec of WOT like the Hacker, WHEW! LOL! It also landed warm but not dangerous (I'm running a himaxx 20mm heatsink on it). Speed seemed visually on par with my D99 (~130-140), but the Sokol is smaller so perhaps it was just 120 or so. I set my cg to 20mm and she landed like a trainer, LOL! Fun setup for those smaller fields... made me and a couple buddies dizzy following it around today.
I'll add some pics of my Sokol's paint job to this post. I got it with sky blue wing and stab bottoms, so I had to paint it just to see it. Now with the new paint scheme it was easy to track.
Cheers,
Kev
[edit: FYI, after flying my Sokol for some time now, I've found a CG of 25mm or greater is a better starting point. 20mm results in much faster landings, and requires a lot more elevator deflection to flare.]
Truglodite is offline Find More Posts by Truglodite
Old Oct 04, 2011, 08:27 PM
knifeedge63 is online now
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
oh sweet! yeah id love to see some pictures!
knifeedge63 is online now Find More Posts by knifeedge63
Old Oct 04, 2011, 10:37 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I added pics. I wouldn't have thought of shooting the entire underside of a pylon racer sky blue, but that's what I got. It was white on the tops of the wing and tail as usual. The paint job added 0.1oz. Now as you can see, I can see it no problemo.
Kev
Old Oct 04, 2011, 11:20 PM
8ballfever is offline
Find More Posts by 8ballfever
CERTIFIED LIPO PUFFER
United States, CA, Cypress
Hey Kev,
You've already got a Sokol, but yet, you want another one??
8ballfever is offline Find More Posts by 8ballfever
Old Oct 05, 2011, 12:07 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
No, one is plenty for now, and the way it flies I won't need a backup. If I had money to for another small moldie it would have to be a Voodoo, or Micro Stinger.
Kev
Old Oct 05, 2011, 10:48 AM
Raffi is offline
Find More Posts by Raffi
all-weather pilot
Raffi's Avatar
Zürich, Switzerland
Joined Sep 2008
Hey
Check your EWD. I have measured at mine Sokol more then 1.5°, now i have reduce the EWD to 0.3° an the CG at 33mm. Flies very good.
Raffi
Raffi is offline Find More Posts by Raffi
Old Oct 05, 2011, 11:45 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Raffi, thanks for the info! Interesting to hear you have it working all the way back at 33mm; I think that's 8mm farther than anyone else who posted. Just to clarify, does the acronym "EWD" mean decelage, or incidence?
My trim is neutral at 20mm, so I was planning on tuning the decelage as I venture farther back. I don't have an inclinometer though. A few test flight iterations would go quickly, but a starting point would be nice. Do you remember roughly how thick a shim you had to use for the -1.2degree change?
Kev
Old Oct 05, 2011, 01:45 PM
Raffi is offline
all-weather pilot
Raffi's Avatar
Zürich, Switzerland
Joined Sep 2008
Hi
EWD= Angle of incidence
The angle between the wing and the elevator was more then 1.5° degrees by my Sokol.
So i reduce it to 0.3° and it flies with a CG of 33mm. Because the high angle is a reason for a CG of 15 to 18mm
Raffi
Sorry for my bad english
Old Oct 07, 2011, 07:15 AM
Joined Feb 2011
I have begun reconstruction on my sokol. I sanded for a good two hours yesterday evening.
I have heard that the fuselage section directly behind the wing saddle is a very weak point on pylon racers.. Has anyone ever confirmed or denied this? i want to know if I should reinforce weak areas on this plane.
Old Oct 07, 2011, 10:11 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
I did fly my Sokol for 4 years, rough landing and some bad starts , I was as new when I sold it, I didnt see any weak spots at all... But I did "only" fly it with 450watts. If you are aiming much higher, well then you will have to think in other terms..
sebbe is offline Find More Posts by sebbe
Old Oct 07, 2011, 10:19 AM
Joined Feb 2011
Im puttin in a Mega 16/15/2 on 3s.
Old Oct 07, 2011, 08:10 PM
Joined Feb 2011
hey can someone get a picture of the firewall/ motor mount for me? Mine came off and was lost, so im going to have to fabricate my own. But id like to make it just like the original.
Old Oct 07, 2011, 08:40 PM
Here you go Colin. Maybe you wanna glue the mount in w/ some down thrust angle, because the first time I glued the mount in, I had it at 0*, and the Sokol climbed at full throttle. Luckily I had a hard landing and the mount came loose, so I reglued it w/ some down, I'm guessing 3-5 degrees at most, and she goes straight and level at full throttle, w/ that Mega 16/15/2.
Old Oct 07, 2011, 08:42 PM
Joined Feb 2011
what size bolts are you using to mount the motor?
Old Oct 07, 2011, 09:02 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Put a couple of holes in the mount to let some air at the windings
jackosmeister is online now Find More Posts by jackosmeister
Sold Sokol Pylon Racer Greyout Aircraft - Electric - Airplanes (FS/W) 5 Aug 28, 2011 08:39 PM
For Sale D99 pylon racer up for sale deal!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! speedster Aircraft - Electric - Airplanes (FS/W) 4 Jun 18, 2011 09:39 AM
For Sale For Sale: Sokol Pylon Racer RTF $350 OBO Bay Area Only efinkg Aircraft - Electric - Airplanes (FS/W) 4 Jul 19, 2008 11:01 PM
For Sale For sale or Trade...Sokol pylon racer... papasmurf Aircraft - Electric - Airplanes (FS/W) 6 Jul 18, 2005 08:00 PM
Sokol Speed 400 pylon racer for sale sglade Aircraft - Electric - Airplanes (FS/W) 7 Jan 20, 2005 01:07 PM
