Old Aug 26, 2011, 06:12 AM
JoseLuis28 is offline
Find More Posts by JoseLuis28
JoseLuis28's Avatar
Colmenar Viejo - Madrid - Spain
Joined Jan 2009
Question
the highest temperature in a gasoline engine , (heat cylinder & exhaust gas)
Change name of threadHello everybody,
I want to make an electronic circuit that it should disconnect the electronnic ignition if temperature is above the highest one.
Could someone tell me which is the highest temperature in order to avoid any damage ?
Thank you
Enjoy flying
Jose Luis
JoseLuis28 is offline Find More Posts by JoseLuis28
Last edited by JoseLuis28; Sep 02, 2011 at 05:59 PM. Reason: Change name of thread
Old Aug 26, 2011, 06:57 AM
ACS tech is offline
Find More Posts by ACS tech
Canada, NS, Greenwood
Joined Aug 2011
I could see this for electric motors, but there too many variables in IC engines for failure other than temperature. Wrist pin snap rings, stuck ring etc. You can have a catastrophic failure without high temperatures.
ACS tech is offline Find More Posts by ACS tech
Old Aug 26, 2011, 03:35 PM
NefariousRC is offline
Find More Posts by NefariousRC
NefariousRC's Avatar
USA, CA, San Diego
Joined Jan 2011
You missed the point entirely. He's looking to create a circuit the kills the ignition to prevent heat damage. This would potentially remove one of those variables. You're right, not all failures cause excessive heat but excessive heat can/will cause various failures (stuck ring, siezed piston, bearing failure) so while it wouldn't be a catch-all solution, it may prevent some failures.
OP, A nice feature would be some sort of audible alarm thar sounds a few degrees before the ignition is killed.
NefariousRC is offline Find More Posts by NefariousRC
Old Aug 26, 2011, 04:06 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
You may want to start searching snowmobile sites. Umpteen years ago I had a racing snowmobile that had temperature sensors that ran gauges. Basically the sensor was a thick sparkplug gasket which was wired to a gauge box. I think at one point in time it was an OEM option on one of the brands.
The only other non-water temp sensor available for any gas motor was a exhaust gas temp sensor which indicated if your mixture was rich or lean. I wonder if todays auto oxygen sensors in the exhaust pipe would be similar or the same as.
jjkupinski is offline Find More Posts by jjkupinski
Old Aug 26, 2011, 04:35 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The temperatures can vary depending on the engine brand and type, how much cooling it gets from the fins and air flow and so on.
But the temps seem to be around 200 degrees Farenheit give or take a little.
ref: http://www.troybuiltmodels.com/ns/in...g_easier.shtml
So if you set your temperature cutoff to 220 degrees F, that would be a good starting point.
earlwb is online now Find More Posts by earlwb
Old Aug 26, 2011, 05:29 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
You don't need to build one. Nobody does this however.
http://www.venom-group.com/itemdesc.asp?ic=0605
The answer is proper cooling and monitoring temperatures. Many carry an onboard temperature sensor that records peak temps and if things get hot, you make adjustments to your baffling to improve cooling.
http://prme.nl/forum/viewforum.php?f...23912c2c33cef5
http://www.venom-group.com/itemdesc.asp?ic=0602
Gas engines can handle more than than 220°F without damage. Try to keep it under 250°F. Even higher peak temperatures can be acceptable.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Aug 26, 2011, 05:50 PM
Jason_WI is offline
Find More Posts by Jason_WI
Cox Engine Hoarder
Jason_WI's Avatar
Neenah, Wisconsin, United States
Joined Jun 2004
Enhaust gas temperatures will be the highest and from 600 to 1000 degrees F. Diesel tractors use pyrometers to monitor exhaust gas temperatures in the turbos to get a feel for how hard the engine is working. Once you start pushing past 900 F on the pyrometer engine life is shortned.
A K type or T type thermocouple should work for your application. You will need a cold junction compensated thermocouple to digital converter for your microcontroller such as a Maxim MAX31855.
http://www.maxim-ic.com/datasheet/index.mvp/id/7273
I have used the MAX6674/MAX6675 before with good results.
Jason
Jason_WI is offline Find More Posts by Jason_WI
Old Aug 27, 2011, 06:03 PM
JoseLuis28's Avatar
Joined Jan 2009
Sorry
Old Aug 27, 2011, 06:05 PM
JoseLuis28's Avatar
Joined Jan 2009
Oh no I lost my answer.
Ok doesn't matter, as on monday, I'll be at home , I'll reply that day or next tuesday.
Thanks a lot everyone , very good info to start.
Enjoy flying
Jose Luis
Old Aug 30, 2011, 05:16 PM
JoseLuis28's Avatar
Joined Jan 2009
Hi, just at home, easy to write with keyboard, not mobile phone as before.
The idea is to design an electronic CDI , and this circuit will be an auxiliary one, only to prevent damage due higher temperatures. If every engineīs model has its ideal temperature cut off, I have to ask the manufacturers about it, of course I need that info , I must indicate it in manual and user could program the right cut off temperature, also could disconnect the preventive circuit.
Jason, that Maxim thermocouples looks very good, 14 bits resolution is excellent, maybe Iīll use it, but my initial idea was that a PIC including A/C converter with 8 bits resolution would be good for my application.
Anyway, I have to study every detail, every component carefully.
Any idea, any circuit to prevent damage, please tell me.
Enjoy flying
Jose Luis
Old Aug 30, 2011, 05:21 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
Where would you measure/monitor the temperature?
MCarlton is offline Find More Posts by MCarlton
Old Aug 30, 2011, 06:25 PM
JoseLuis28's Avatar
Joined Jan 2009
I donīt need it. My circuit must be simple, cheap to build, adding few components and using the PIC of CDI circuit.
Of course, I have to use precision tester in order to know
real temperature
JOse Luis
Old Aug 30, 2011, 10:46 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
When I worked on snowmobile engines back in the 70s, the operating temp was between 250 and 300F with a thermocouple under the sparkplug. 350 was getting dangerous.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Aug 30, 2011, 10:48 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Old Sep 01, 2011, 06:24 AM
JoseLuis28's Avatar
Joined Jan 2009
I think I must give some option between 220F to 350F.
Using the info you are telling me, I think it would be a good range.
Flypaper2, you install the thermocouple under the sparkplug in order to aviod aircooling refreshing the sensor, donīt you ?
Now I have to ask manufacturers about cut off temperature, and "ignition advance curve". I donīt know if in english it would be its technnical name.
Also, I have to open new thread.
Enjoy flying
Jose Luis
Sold New In Box GF26i-V2 -- 26cc Gasoline Engine ny_hawk Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 03, 2011 10:00 PM
Wanted 26CC or 38cc gasoline engine in trade for 50cc TODDRAPONI518 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Oct 19, 2009 05:35 PM
Discussion DL50 Gasoline Engine and Parts, now available in Canada! Grizak Product Announcements 0 Oct 01, 2007 12:58 AM
Discussion Gasoline in a nitro engine? Sir-Ipswich Nitro and Glow Power Cars 5 Aug 27, 2007 11:29 AM
Highest temperature you fly your planes? Citation7 Parkflyers 49 Jun 11, 2003 01:28 AM
