Old Aug 26, 2011, 02:59 AM
United Kingdom, England, Portsmouth
Joined Jan 2009
which motor for 10x4.7 sf prop quad?
ok this has prob been covered so many times but i can never find a thread that has a list of prop sizes and then a list of motors that have been proven to work well with each prop on a quad?
all i am after is a motor for a quad that will turn a 10x4.7 sf prop and b ok for aeriel photography and video no fpv.
many thanks in advance and yes i have used the search function plus many hours of looking a motor specs and then trying to match them to a 10x4.7 sf prop, but i just not getting very far.
RCT
rcta15 is offline Find More Posts by rcta15
Old Aug 26, 2011, 03:44 AM
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
here i used hextronic dt700 motors with a 10/6 gws DD prop so it will swing a 10/47 all day long without getting hot it will also swing 12/45 nicely too but warms up a little over body temp with that prop
Quadcopter Rockley Sands Poole UFO N-DROID S Ultimate Ground Effect Final Test N3M1S1S (16 min 50 sec)
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Aug 26, 2011, 03:52 AM
UK
Joined Jul 2002
Any motor in the 700 - 800 kV range should be ok. Obviously some are better than others quality wise. The above choice is popular as well as the 750 kv 2830-14 by RC-Timer. A budget motor, but good for what it is. I use 3 on a T-Copter, swinging 10 x 4.7's, equipped for AV and FPV.
Tatty is offline Find More Posts by Tatty
Old Aug 26, 2011, 04:34 AM
Nemo in a blender
Connexxion's Avatar
The Netherlands-Amsterdam
Joined Mar 2007
I'm happy with Flycam 925 kv.
Have used them on a quad for countless hours and they still run happy.
Even use them on 4S with no problemo what so ever.
http://www.kkmulticopter.kr/index.ht...m_925&id_no=45
Connexxion is offline Find More Posts by Connexxion
Old Aug 26, 2011, 04:48 AM
Joined Feb 2007
i like 925 to 950kv too for avp the vibes seem less or at a different frequency to the camera but i run them on 9inch props
Old Aug 26, 2011, 04:54 AM
Joined Jan 2009
many many thanks to all that replied i have used your info and purchased 4 of these,,,
http://www.hobbyking.com/hobbyking/s...ner_750kv.html
again many thanks. RCT
Old Aug 26, 2011, 05:25 AM
Joined Feb 2007
great stuff now find my dt700 750 mod vid and do the bits you like to make these motors hard to break
Discussion Looking for 10x4.7 Prop Adapter for 3mm motor shaft tarrigo Multirotor Talk 1 Aug 17, 2011 08:16 PM
Data 10x4.7 APC SF v. 10x6x3 GWS HD Dr Kiwi Power Systems 0 Jan 23, 2008 04:03 PM
Discussion ??? FOLDING PROP EQUIVALENT TO A APC 10x4.7 SF FOR A 170W HACKER A20-20L barb wire Parkflyers 1 Mar 15, 2007 07:25 PM
Found APC 10x4.7 or 11x4.7 SF prop slo_dave Aircraft - Electric - Miscellaneous (FS/W) 0 May 15, 2006 11:53 AM
Which prop for TM Outdoors 10x4.7 or 9x7? Acer Parkflyers 3 Mar 14, 2002 09:33 PM
