Old Sep 22, 2011, 08:05 AM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Originally Posted by Razors edge 29 View Post
Did I mention that this heli rocks?
Lol
Na I got to disagree mine is very stable but it may rock after I have bashed it around a bit
Yes its a very impressive little heli - will take of couple of days to fine tune but flys excellent out of the box.
PS Tom did not find any auto setup as was implied in the Vid - but its real easy to setup.
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Sep 22, 2011, 08:07 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by magic_marty View Post
i set my th-hold switch at -15% so if i crash i flip the switch and it kills the throttle....BUT when i did this it works when the switch is flipped but when i return the switch to normal position the motor will not shut off it spins at a slow pace.....not sure why its doing this......one thing i did do is set a fixed ID and i love it, no long wait to bind up....turn on plug in battery and its ready to go.....
I have the same thing happening using the Wow suggested -5% throttle, so it looks like I am going to try really increasing the negative to hold off the throttle in TH. Perhaps this is a minor ESC bug or calibration issue... we will see. As long as it doesn't actually spool up, I think I can live with it.
As to the fixed code, glad you tried that out for us -- I have both of my 4f200s set up that way, and my other 2702v equipped helis as well, and I *love* the super fast bind and the security that the fixed code provides!
tracknoob is offline Find More Posts by tracknoob
Old Sep 22, 2011, 08:59 AM
HELIRON69 is offline
Find More Posts by HELIRON69
HELIRON69's Avatar
United States, PA, Chambersburg
Joined Feb 2010
I plan on buying the 2801pro BNF the first of the month. Will the charger for the 4#3b and CB100 work with the battery on this? I have converted them to minideans and before I do it to the genius I want to make sure it works. If so I will put the orginal plug back on one of the chargers.
Thanks, Ron
HELIRON69 is offline Find More Posts by HELIRON69
Old Sep 22, 2011, 09:08 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Thanks, Ron
Yes, it is the same charger.
zadaw is offline Find More Posts by zadaw
Old Sep 22, 2011, 09:14 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Thanks, Ron
No need to change a charger back over just make a Deans to Walkera adapter for now till you change the Genius to micro Deans..
livonia bob is offline Find More Posts by livonia bob
Old Sep 22, 2011, 09:25 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Possible Throttle hold fix!
I posted a possible throttle hold fix on the "alert" thread. Works for me, at least!
Woot!
Link:
http://www.rcgroups.com/forums/showt...2#post19389059
Old Sep 22, 2011, 09:59 AM
HELIRON69's Avatar
Joined Feb 2010
I thought about that too, but I figure the less solder joints and connectors the better the conductivity. I have an Imax B6 that I use for charging all my batteries. Don't even use the old chargers anymore.
I've been following all you posts way back to the begining of the CB100 thread. Must say you've given me quite a few a laughs.
I'm retired also and turn 60 next month. The Genius is a gift to myself. Have lots of time to play with my "toys".
Old Sep 22, 2011, 10:08 AM
Heli collector
Joined Apr 2009
I don't think it will be a problem with charging.. Unless your soldering skills are really bad the Deans will not cause much if any drop and even if they did it would only be another 30 seconds on the charger..
I have both adapters for my Acccell 6 chargers and I kept a stock Walkera charger just for charging a new heli for it's first test flight before I change it over to the micro Deans..
I often wonder now where I ever found the spare time to go to work... Seems I'm always busy now..
Old Sep 22, 2011, 10:12 AM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Genius parts on RC711
Some Genius parts appeared on RC711.com:
http://www.rc711.com/shop/walkera-ge...66_60_263.html
FDR_ is offline Find More Posts by FDR_
Old Sep 22, 2011, 11:00 AM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Originally Posted by Tom Z View Post
Scott, I agree with you 1,000%!
What a PITA it is to work through the Devo 7 menu. I am still trying to figure things out and I have been at it most of the day... I am making progress though.
Tom
So the guy who puts up stickies about setting on several TXs finds this one a PITA and spends the day figuring it out. This will be my first programmable TX EVER! I'm NEVER going to figure it out.
Hope you put up a comprehensive guide for the DEVIL 7, Tom.
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Sep 22, 2011, 11:19 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Cool! Thanks for the tip, esp since (this is not a dig, just a fact!) Wow either doesn't have them yet, or (more likely?) just has not updated the applicable parts of their website yet.
So far, no need for it, but good to know it's there if I do!
Old Sep 22, 2011, 11:21 AM
bobepine's Avatar
Joined Jun 2011
Regards David
Yeah right! Must be why the Dv 7 is now referred to as the Devil 7. Mine should be in tomorrow or the next day and I'm scared. I think I'll have bad dreams tonight.
Site Sponsor
Old Sep 22, 2011, 11:45 AM
babblin5 is offline
Find More Posts by babblin5
Tech Junkie
babblin5's Avatar
Wichita, KS
Joined Apr 2010
By the way, the battery for the Blade CX series of helis makes a perfect tx battery for the Devo 6. 2s lipo 800 mah with the proper connector and fits great in the battery compartment. Got mine for about 10$ at my lhs.
babblin5 is offline Find More Posts by babblin5
Old Sep 22, 2011, 11:47 AM
jazzjohn is offline
Find More Posts by jazzjohn
Madison WI
Joined Jan 2009
I am still sitting on the Devo 6 / Devo 7 fence. You guys are quickly talking me out of the 7...
But Walkera could step in at any time and provide a new interface for download, right? Sounds like they should.
jazzjohn is offline Find More Posts by jazzjohn
Old Sep 22, 2011, 11:57 AM
ScottAllyn is online now
Find More Posts by ScottAllyn
ɹǝsn pǝɹǝʇsıbǝɹ
ScottAllyn's Avatar
United States, FL, Lutz
Joined Sep 2011
John, one limitation of the user interface is the display itself. It's a crude text-based display that's only capable of showing two rows of 5 characters. That's a hardware limitation that no software update can fix.
The Devo 7 does seem like a capable transmitter and it's not actually that hard to program. The interface just leaves a lot to be desired, which makes it a frustrating process, especially while you're first learning it.
ScottAllyn is online now Find More Posts by ScottAllyn
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
