Old Sep 01, 2011, 08:14 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Between a 4#3B, UFO#5 and UFO#8, I never want to see another Walkera brushed motor.
Balr14 is offline Find More Posts by Balr14
Old Sep 01, 2011, 08:17 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Yes I hope it's not a crappy motor
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Sep 01, 2011, 08:45 AM
Pontiaddict is offline
Find More Posts by Pontiaddict
Pontiac my other Obsession
Pontiaddict's Avatar
USA, FL, Apopka
Joined Jul 2010
Last week a member (thunder2661) posted this link in regards brushed motors and break-in, I had no experience but I wonder if it would help in the future for this little genius...
http://www.rcuniverse.com/forum/m_5628228/tm.htm
The point may be moot as it sounds like Darryl & WOW will have a BL setup available commensurate with the release of the Genius CP.
Pontiaddict is offline Find More Posts by Pontiaddict
Old Sep 01, 2011, 09:13 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Good article thanks
Old Sep 01, 2011, 09:59 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
The problem with Walkera brushed motors is they use copper fingers, not carbon brushes. Heat makes the copper fingers lose tension, which means poor contact. Normal brushed motor break-in doesn't work. It's meant to seat carbon brushes.
Old Sep 01, 2011, 10:05 AM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
You were Right however walkera are using carbon brushed motors nowadays - but as on the previous post its a moot point.
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Sep 01, 2011, 10:28 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
I can now attest to the toughness of this heli. First I plowed straight into a cement light pole in full forward flight and chicken danced on the pavement. I then flipped it back upright and took off again with no issues. Cool. Unfortunately, after the next few circuits my neighbor's Corvette drove up the driveway so I hovered up and over the car but he decided to stop in the CCW turn path. I had to drop her into the pavement real quick. Unfortunately, it slid across the street into the path of his rear wheel and he ran it over. . Oh no. I picked up what was left and hoped the Rx and servos were undamaged. Had to repair the tailboom with some CA, replaced the tail motor and blade and replaced the feathering shaft. Believe it or not, its back in the air in less than an hour. Nice. Got to say, this heli is definitely tough. Here is what is left of the tail rotor. LOL.
dkfuji is offline Find More Posts by dkfuji
Old Sep 01, 2011, 10:47 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
lol
crazyness
damn tough
so
is this devo 6 better than dx6i?
Old Sep 02, 2011, 02:42 AM
MartinL is offline
Find More Posts by MartinL
Australia
Joined Oct 2000
I cant understand why Walkera is till using brushed motor for their heli..it is inefficient and is a Lipo killer, brushless is dirt cheap(HK micro outfit)
Walkera can do better in bulk. Also the Genius is using servos???? instead of all in one!!!(must be unbreakable servos)
Any idea of the pricing?? for serious heli flyers wanting to use the micro for aerobatic/3D training another Tx to buy is a
pain and not practical. They should really get into bed with one of those after market module players like Frsky,,Assan
MartinL is offline Find More Posts by MartinL
Old Sep 02, 2011, 03:39 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
You can pose the same question to Blade regarding the MCPx. The answer is to save weight. You will an external ESC for a brushless motor. If you are looking for a brushless CP heli of the size, then Walkera has the V100D03BL.
The linear servos used in the MCPx are open and exposed. The servos used by Walkera in this heli are not normal servos. The servo driver circuit is probably built into their receiver. I am not sure whether it is possible to build all the servos onto the same board. The MCPx has 3 independent servos and the Solo Pro 100 3d has a rear servo.
Transmitter compatibility is a major issue here. There are lots of modelers who have already got an existing 2801pro. But Walkera has chosen not this incompatible with existing Walkera users. But at the end of the day, Walkera is there to make profit and they do what they think is best for their profitability.
zadaw is offline Find More Posts by zadaw
Old Sep 02, 2011, 11:03 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
... Also the Genius is using servos???? instead of all in one!!!(must be unbreakable servos)
What servos are unbreakable?
One can read many posts (say on Helifreak) of the linear servos on the mCPx dying (and all the stores having the servos on back order due to the high demand).
Not to mention that there are also many posts of having to periodically take apart and clean the mCPx linear servos (the feedback variable resistor is exposed and gets dirty).
And if a servo were to break, I would rather not have it on the all-in-one:
instead of just unplugging and replacing one servo, the option becomes either taking apart a servo on the all-in-one or totally replacing the all-in-one.
flying-llama is offline Find More Posts by flying-llama
Old Sep 02, 2011, 11:10 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
I'd much rather have rotary servos over linear - linear are a PITA.
Old Sep 02, 2011, 11:21 AM
Hellraser's Avatar
UK
Joined Jul 2007
+1
Regards David
Old Sep 02, 2011, 12:22 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Actually most brushless conversions on the mcpx loose weight, mine lost 6-7 grams
If they wanted they could do a built in esc as well.
indoorheli is offline Find More Posts by indoorheli
Old Sep 03, 2011, 04:36 PM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
WOW!!! ,just read this thread and i just cant believe how tough this thing is,,,a walkera that doesnt bend when you look at it too rough Looks like an awsome toy,,,,i was thinking of a 250cp next to fly in smaller areas but this thing looks wicked for playing 3d without all the sad rebuilds
Magic k2 is offline Find More Posts by Magic k2
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
