Smallest common size is 1.5mm or 1.27mm (Harbor Freight). Maybe eBay, Amazon, Aliexpress, etc. Sorry, not much help. |
Joined Aug 2012
I'm sure you guys know this already, but someone asked about using a v911 tail motor a few posts back. IDK about the motor (the v911 is a little shorter then the Genius) but, the v911 tail boom is a direct replacement. It's a little longer but that's not an issue. And the stock Genius motor fits right into the holder on the v911 boom. So if you split a boom but the motor is good, a spare v911 boom will do the trick.
Also , if you break the tail fin, a v911 fin can be glued onto the Genius boom. |
![]() My Genius tail motor is exactly the same size as my V911. They're both 6mm by 15mm motors (or close). However, obviously there could be differences in the windings or whatever. I will definitely try a V911 motor if my GCP tail goes out though. I read somewhere that someone used a V911 main motor in the Genius and it had more power than the stock. I'm going to try that too if/when my GCP motor dies. As for the tail boom, I have about 3 meters of 2mm carbon fiber tube that I will cut and use if I ever break a boom. This stuff is way cheaper than buying a stocker boom, only like $0.32 for a new boom when you DIY. You're right, it will work for the Genius or V911. ![]() Edit: Sorry, for some reason I had my micro-quad motors on my mind, I meant 6mm by like 15mm for the GCP and V911 tail motor, not 716. They're both the same, at least on my birds.
Joined Aug 2012
Has anyone messed around with the Gyro settings on the TX. I have the gyro set to the Mix switch 60/70/85 just to experiment. I don't notice alot of difference other then a jittery tail at the highest setting. I think the factory setting was 70. Just curious what others have experienced. Also, I thought I had read some posts that the Aux 2 dial could be used for the gyro on the Devo 7. I didn't see that as an option in the menu though.
Essentially the higher it is the stronger the gyros will hold but it also makes the heli slower to respond to stick input. Too high and like you said it will jitter or "hunt" a lot, especially noticeable in the tail. A very low value will make the heli response really fast with stick input but the gyros won't hold as well (tail will blow out, roll angles won't hold as well, etc). There are advantages to setting it both higher and lower so I think it depends on your personal style. For really fast acrobatics it needs to be set lower. For a more stable heli set it higher. You can not go below 50% on a 0-100 scale or it will turn the gyros off (below 0% on a -100 to 100 scale like the 9x). I thought about putting it on a pot on TX so any value could be set but then I started thinking that's probably not a good idea because if it's off a little it can make the heli respond different than what you expect. I also don't know how this transmitted gyro setting interacts with the gyro pots on the RX board. The pots on the RX board may act like a "rate" setting on the gyros which in effect lowers the transmitted gyro sensitivity with high stick input. |
Philippines
Joined Jul 2012
Philippines
Joined Jul 2012
Noticed that the heli's been losing power lately, to the point that it would often end up skidding across the ground after a sharp banked turn. At the start of the flight i can hover it at just over midstick, but soon have to push it all the way to the top just to keep flying. I've swapped out the motor, and while the blade tips are frayed, the leading edge is still sharp.
Looks like it's time to get new batteries. The four 350mah batteries were bought from chinesejade at the end of september, and i fly two or three times a day. So that would make about two and a half months for the lot. And that would be about 50 cycles each? Is that good? I've got these in my shopping cart. http://www.ehirobo.com/shop/Walkera-...duct_info.html |
I believe the instructions said to flip the switch after the battery is connected. I believe this is so that the servos will be centered before turning off the gyros. Otherwise they might be off if you had previously picked up the heli while disconnecting the battery. Technically I don't think it matters when the switch is flipped as long as you know the servos are centered. |
| Thread Tools | |
| Discussion smallest lightest 10-12mp camera? | cdi3d | Aerial Photography | 16 | Apr 27, 2011 09:36 PM |
| Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? | Michael Heer | Coaxial Helicopters | 27 | Oct 29, 2008 08:43 AM |
| The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox | ELE kiki | Product Announcements | 42 | Aug 27, 2007 11:49 PM |
| Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. | ELERC | Mini Helis | 11 | Jun 21, 2007 08:17 AM |
