Old May 26, 2012, 08:11 PM
stormforce is offline
Find More Posts by stormforce
Closed Account
Joined Nov 2011
Originally Posted by Proud Infidel View Post
My tail rotor finally went bad from all the crashing. The good news is that the NE Bravo SX tail motor worked. I'm airborne again. So, if you're ever at myrcmart.com, you should pick up a Bravo SX tail set for $2.99. The dimensions of the motor are the same, but you cannot use the tail boom, which is approximately 1.76 mm, and the tail motor holder. You can only use the tail motor. That's not bad for $2.99.
Tried the bravo sx tail motor and it fits into the genius tail motor holder perfectly and it uses the same polarity and works quite well, it's slightly better in performance too, it really zips the tail around compared to my other genius.
The main shaft of the bravo sx motor is 2mm shorter, but the base of the genius tail blade still clears the motor body and base of the shaft by 1mm, so it may save the tail motor shaft from being bent (as what happened with mine) and the bravo sx tail motor wires need to be lengthened by another 1 inch to solder onto the genius tail motor plug to reach the pcb socket. The bravo tail motor wires are easier to get into the tail boom too, because of their smaller wire diameter. So, if one was desperate for parts, one could use a Solo Pro, Bravo Sx or Xieda 9958 tail motor (but the Xieda 9958 motor is a little underpowered compared to the BravoSX motors).
To look at it, you'd never know it was from a Bravo Sx, save for the shorter motor shaft, it's an all round perfect retro fit.
stormforce is offline Find More Posts by stormforce
Old May 26, 2012, 08:12 PM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
Originally Posted by stormforce View Post
Maybe retro fitting a mini cp motor might be a better upgrade...
What's the advantage? What do I have to do to retrofit?
Thanks for the response, BTW.
Proud Infidel is offline Find More Posts by Proud Infidel
Old May 26, 2012, 08:19 PM
Joined Jan 2012
I wouldn't call it a retrofit. Just cut the wires and solder the new tail motor wires in. Just don't shove the tail rotor in too far.
Old May 26, 2012, 09:09 PM
Closed Account
Joined Nov 2011
a retro fit is using a part designed for another vehicle, that may be an upgraded or better part than the original.
Old May 29, 2012, 07:03 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
I ordered a pair of genius main blades for a project but won't need them. $7 shipped, pm if interested.
itsmillertime is offline Find More Posts by itsmillertime
Old May 29, 2012, 08:10 PM
Jon.M.Barter is offline
Find More Posts by Jon.M.Barter
Team Armattan
Jon.M.Barter's Avatar
United States, CA, Garden Grove
Joined Apr 2012
flew the genious with the mini cp frame, flies good, flies smooth, flies great. i did not think it would work out when i first started the project but looks like i pulled it off. i am glad i do not have to deal with the origianl frame anymore (never liked the single body design and horrible battery tray/style) sincere thanks to you guys for helping me out with the project, i could not have done it without you.
Jon.M.Barter is offline Find More Posts by Jon.M.Barter
Old May 30, 2012, 01:19 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
parts for Sale
I no longer have my Devo 6 transmitter, but do have the heli board and parts for sale if anyone is interested
Need to sell the following
1. control unit - has been set up for BL, comes with micro deans (with pot flat head screw driver)
2. brand new canopy (newer one piece design)
3. xtreme alum swash
4. Xtreme grips
5. Xtreme rotor head
6. Xtreme metal control horns
7. stock head and grips
8. Stock swash
9. new in bag main blades
10. new in bag tail rotor
11. main gear
12. other odds and end pieces.
Everything is in good shape and hardly used. PM me if interested
Selling everything for $75 US + shipping
Razors edge 29 is offline Find More Posts by Razors edge 29
Old May 30, 2012, 02:43 PM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
Have any of you guys tried a smaller pinion on the std motor ? i run 80 to 100 on throttle curve ,,,maybe get a little more punch with smaller pinion ?
Magic k2 is offline Find More Posts by Magic k2
Old May 30, 2012, 04:07 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
I have on the BL C05M but not the stock brushed. On the BL I ran 7, 8 & 9T, I prefer the 8T.
Crash Survivor is offline Find More Posts by Crash Survivor
Old May 30, 2012, 05:45 PM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
Yes, I tried a 7T but it didn't have enough punch. I think the 8T is a perfect match for the stock motor and even an HP05.
Good Luck, Don
dbennettya is offline Find More Posts by dbennettya
Old Jun 01, 2012, 03:00 PM
Team Armattan
Joined Apr 2012
hey fellas, for your information! this is a great deal and i couldnt resist (especialy since i busted my elevator servo yesterday on my mini)
http://helircstore.com/shop/index.ph...product_id=666
Old Jun 01, 2012, 03:06 PM
Joined Jan 2012
They want $31.80 each. Typical price for a Genius servo is between 14.90 to 16.50. Xheli.com sells servos for $15 each, subtract 7% for coupon code XHFather (expires June 18).
Old Jun 01, 2012, 03:10 PM
Heli Crash Survivor
Joined Feb 2011
31.80 is for 3 servos.
Old Jun 01, 2012, 04:00 PM
Joined Jan 2012
So quantity 1 = 3 servos? You want to try that, go ahead.
Old Jun 01, 2012, 04:28 PM
Apphoard is offline
Find More Posts by Apphoard
Apphoard's Avatar
United States, MD, Silver Spring
Joined Mar 2011
Looks like three for 31.00 to me also. 😃
Apphoard is offline Find More Posts by Apphoard
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
