Old Mar 02, 2012, 07:18 AM
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by helisb View Post
My GCP starts spinning clockwise, out of control, as soon as I throttle up. When I give rudder in the clockwise direction I get lots of tail thrust, in the other direction very little (does the tail spin in only one direction or should it reverse? Didn't think to check when it worked fine). I have gone through the radio transmitter set up to make sure all OK, and I have replaced the tail (including the tail motor). This happened suddenly but I can't relate it to a crash. I have certainly crashed, but no major impacts. I suspect that something is wrong with the receiver. I have visually inspected the receiver, can't see any evidence of trauma or anything loose or out of place. Any trouble shooting ideas/suggestions would be appreciated.
Sven
My first question is what is the main blades doing are they spinning right? enough power to fly? Main motor pinion not slipping on the motor shaft?
livonia bob is offline Find More Posts by livonia bob
Old Mar 02, 2012, 06:56 PM
Joined Sep 2011
Spinning GCP
The main blades are spinning normally, generating power to fly. The main gear is not slipping.
Sven
helisb is online now Find More Posts by helisb
Old Mar 02, 2012, 08:23 PM
Heli collector
Joined Apr 2009
Sven
Then unless you have screwed up the rudder gyro setting in the TX looks like you might have a problem with the RX.. When you twist the heli in your hand does it feel like the rudder is trying to fight you?
Old Mar 03, 2012, 12:34 AM
Madison WI
Joined Jan 2009
Originally Posted by shastamike View Post
Farmer Dave made the video but it disappeared and so did Dave. Dave are you out there?
The main idea was to take out the motor so the main blades spin freely. Bind the heli. Probably want to switch the RX to "adjust" and don't forget to set it back when done! One then spins the head and blades by hand while moving the TX cyclic controls to the extreme edges and corners. If there is binding it becomes very apparent because the rotor will slow down or seize. The adjustment is made by using travel adj. on the TX. So if you push the elevator stick all the way forward and you get binding you decrease the elevator travel. Seems like I was moving in 5or 10% increments. Next move the lever towards the elevator and aileron (the upper right corner) adjust for that. Go around the "square" of the cyclic. I only had binding of my elevator down and aileron right. got a bit more flight time as I wasn't bogging down my gutless brushed motor when cranking tight turns. Don't know how much effect it will have on a brushless motor though.
Dave...I miss you. Thank you for all your great advice.
Thanks Mike. I'll give it a try soon.
jazzjohn is offline Find More Posts by jazzjohn
Old Mar 03, 2012, 10:29 AM
Registered user
Joined Jun 2011
Sven
Have you unplugged both motors from the RX at any given time? Almost sounds to me like you have the tail motor and the main motor plugged in the wrong socket, as in, the tail motor is plugged in where the main motor is supposed to be plugged in and the main motor is plugged in where the tail motor is supposed to be plugged in. Try swapping them to see what happens.
Chris
bobepine is offline Find More Posts by bobepine
Old Mar 03, 2012, 01:35 PM
Joined Sep 2011
Spinning GCP
Chris
Chris and Bob,
Thanks for your suggestions.
The setup in the TX is good, checked again, the tail rudder is countering (fighting) movement in one direction. Is the tail propeller spinning in one direction only?
I have not unplugged both main and tail motors and I get response on the main rotor from throttle stick and tail rotor from the rudder stick.
Sven
Old Mar 03, 2012, 02:49 PM
bclong211
USA, SC, Columbia
Joined Jan 2007
brushless issues
Well the issues are that first like everyone else who's attempted to make the dual brushless kit work the tail is posessed. I can live without the brushless tail if I have to....Second is after I went back to the brushed tail it will not hold with the brushless main. Every slight or major punch causes it to blow out. Absolutely un-flyable unless you just want to hover. Any thoughts? Batteries are Hyperion 240's so it should have plenty of juice. I can't
find anyone who has made it work!
Tried all types of tailblades also and none make a significant difference.
bclong211 is offline Find More Posts by bclong211
Old Mar 03, 2012, 06:25 PM
United States, KY, Springfield
Joined Jul 2011
have you tried the new tail rotor for the Minicp ? it has lots more pitch and is a bit shorter...holds very nice
magic_marty is offline Find More Posts by magic_marty
Old Mar 03, 2012, 07:21 PM
Canada, Quebec, Mercier
Joined Dec 2008
Chris and Bob,
Sven
Yes
Try removing the tail rotor, as soon you give throttle heli will spin CCW. Air pushing on main blades. The higher the speed of rotation of main blades, the higher the pitch, the higher the force on the blades (push heli to turn CCW) and the higher the tail rotor has to spin (higher trust) to counteract the torque of the main blades.
Edit : What is the gyro gain on your Tx and what is the Rudder Travel Adjust in Tx
Batch1 is offline Find More Posts by Batch1
Old Mar 03, 2012, 07:24 PM
Joined Dec 2008
Witch brushless motor do you have and what ESC do you use and where did you buy it ?
Wow 3 questions in one sentence.
Old Mar 03, 2012, 07:35 PM
Better then Sliced Bread!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Man I love my GCP! The weather being so dang nice today and yesterday, I ran only 3 bats in her yesterday, but today I ran 6 thus far, I am sure I will run another 3 in an hour or so. Earlyer the wind was real calm and made for some nice flying, I even accidentally did a tail up funnel (was taking a turn with way too much rudder and it turned into a funnel ), here just a moment ago I was flying in much windier conditions but still not too bad.
I am coming to a point where I feel I could use a little more response from the controls! I always feel like the tail is fairly slow (I still have yet to put high pitch prop on), and I feel elevator could be a tad faster... this entire time I think I have been flying something like 30% expo on ail and elev, with none on rudder, and linear for throttle and pitch, though my last 5 flights or so I have been putting her in mode 2 which is no expo on anything, but she still feels like she could be a little more responsive...
Anyone have any ideas?
NorCalMatCat is offline Find More Posts by NorCalMatCat
Latest blog entry: Flying in the Neighborhood
Old Mar 03, 2012, 07:55 PM
Joined Jul 2011
Wow 3 questions in one phrase.
C05 motor and the 10LT walkera esc bought them from wowhobbies... they also have the new tail rotor which cost less then the stock tail rotor...
Old Mar 03, 2012, 07:58 PM
Joined Jul 2011
try +expo or move the links to the outside hole on the servos...just be sure to check the endpoints and make sure the servos aren't binding if you move the links out..
Old Mar 03, 2012, 08:48 PM
Tokyo
Joined Jan 2010
I'd suggest trying some negative expo and maybe have a look at manny's settings for the mini. http://www.rcgroups.com/forums/showp...&postcount=522
bytemuncher is offline Find More Posts by bytemuncher
Old Mar 03, 2012, 08:52 PM
Heli collector
Joined Apr 2009
What are your gyro pots set at and the extend pot?
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
