Old Jan 29, 2012, 12:56 PM
RaymondM is online now
Find More Posts by RaymondM
Multirotor Promotor
RaymondM's Avatar
United States, MI, Cadillac
Joined Apr 2011
I have a problem, I just changed over to 22 awg for the power leads from the pc board and put micro deans connectors on the heli as well as three stock batteries, it was running great. All of a sudden when I hook up the batteries and leave the batterys out of the battery tray it will bind and run great but when I try to insert the batteries into the tray it looses it's bind and starts to blink with the servos intermittently jumping up and down.( i think the wires on the stock batteries are too short and are loosing connection when i have to bend them to get them in the tray. I have ordered some 240 hyperions with and without wires and was thinking that with longer wires they won't short out (if this is the problem). Has anyone encountered this or a problem like this. I would really appreciate any help on this.
RaymondM is online now Find More Posts by RaymondM
Old Jan 29, 2012, 12:57 PM
i812 is online now
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Originally Posted by fishfiend View Post
At last I'm having a blast with my Genius! I just changed the main motor, and now it's fun, I can go inverted without hitting the ground whilst bogging the motor a LOT more power with this one. It's my fourth motor and the only thing i've done differently is NOT putting Triflow in the can before flying it. I thought if I used some oil in it it would prolong the life of the motor I guess i was wrong. The other motors were oiled before use and never seemed to have the power of this one, and they got HOT too, whilst the latest stays warm.. So if you're suffering from a weak motor and have been oiling them try it dry...!
A few other people in different threads have reported loosing power after getting oil on their Motor's brushes. Here's another example:
Originally Posted by tracknoob View Post
So, I went ahead and did a 'no parts rebuild' -- rather than throw more money at it, I took the two motors and dunked each of them into their own glass of water with a 1.5V battery to see if anything would come out. The old motor came out clean, not even any brush debris, but the current motor sure enough was spiting out oily debris, and some sort of strandy stuff... it did not turn the water black from carbon dust like burning in a new motor does, but it was definitely contaminating the water.
I don''t break in all brushed motors in water, but for the 120Sr and the mcpx I have done it and even (As described in the post you are concerned about) used it after the fact to clean a suspect motor.
When used on a new motor, the slower speed, cooling and lubrication of the water, etc is supposed to allow the brushes to more perfectly form to conduct well and thereby have max contact area, and work efficiently and last longer. I cannot say that I have scientifically verified all claims, but the technique is almost as old as brushed motors themselves.* Some people recommend alcohol, but the old salts say it is not as good as water. People just hearing about it often express concerns about conductivity and rusting. I assure you that with soft water (or DI or distilled if you are a real nervous norvous) and then a blow out with air, followed by putting it back in use, you needn't worry about rust.
I'm not here to make crazy claims about super performance using this awesome technique that EVERYONE ought to do right away.... I'm just sharing what I did to restore my own balky mcpx, for free.
This is what a brand new 120SR motor looks like after 20 minutes of run in:
*there are many 'guides' and 'how-tos' around -- here is a link to just one typical one:
http://www.rcuniverse.com/forum/m_5628228/tm.htm
i812 is online now Find More Posts by i812
Old Jan 29, 2012, 01:03 PM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
I think that one of the wires you soldered might not have a good connection. Try binding the heli, then carefully wiggling each wire until you find connection is goofy. It might be the wires on the batteries or on the heli.
Just a WAG,
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Jan 29, 2012, 01:06 PM
i812 is online now
i812's Avatar
Joined Aug 2009
If everything was working properly before the micro Deans conversion, then I'd suspect bad wiring/soldering.
First: For high flex application: stranded wiring is normally considered better than solid wire.
Second: If you need help figuring out what could be wrong, I suspect you may be new at soldering, and further suspect maybe problem is due to bad soldering? Maybe not a good/strong electrical/mechanical connection? Maybe strand(s) of wire are "frayed" out and intermittently touching other wire ?
Third and finally: Maybe you used bad wire, which already had broken strands?
Edit: I posted this before reading Rafa's post. +1 with wiggling wires for trying to locate source of intermittent connection problem.
Old Jan 29, 2012, 01:13 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
My guess is that you didn't get the wires soldered to the PCB very well and that's where you need to look.. And if there isn't any smoke they are not shorting out,, they aren't making a good connection..
livonia bob is offline Find More Posts by livonia bob
Old Jan 29, 2012, 01:24 PM
MarcusMX233 is online now
Find More Posts by MarcusMX233
MarcusMX233's Avatar
United States, TN, Johnson City
Joined Oct 2011
Originally Posted by mhills51 View Post
I'm starting to think they don't even have the double brushless. The pictures look like something someone just threw together. I ordered mine over a month ago. When I asked to cancel they gave me the run around and said oh so sorry we have problem with battery will send out soon we ship it monday. That was three weeks ago.
I just received mine on Friday from oomodel. First off I set everything up and tried to fly. No tail power. After further inspection one of the tail motor wires was disconnected from a bad soldering job. I soldered it together and everything works. The tail hold is SOLID and power is better than my c05. But the flying time is almost cut in half. I dont have the exact time because I was flying, tweaking with the rx pots, then flying. stop and go sort of thing. Mine came with a 350mah 25c battery even though in the pic it wasn't listed on oomodel. It has more power than my hyperion 25c batts!!! But you only get the one battery. I will try to fly some more and maybe make a vid if I can get a camera man.
MarcusMX233 is online now Find More Posts by MarcusMX233
Old Jan 29, 2012, 02:01 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Flew my CP outside for the first time today 5 to 10 mile winds and it was great! just had to stay up with the collective management. Had a great time. If I wasn't sick I would go to the field with my big boys, but this is just as fun.
mhills51 is offline Find More Posts by mhills51
Old Jan 29, 2012, 02:03 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Great I thought that would work. (Murphy law) say it don't exist and it will turn up. lol!!
Old Jan 29, 2012, 02:41 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by livonia bob View Post
I have found that the florescent tape I added to mine really helps me keep track of it..
OK thanks, florescent tape looks a good option
Bravo47 is offline Find More Posts by Bravo47
Old Jan 29, 2012, 02:47 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Don't know if it was the wind or what, but it took a lot of power to complete a couple of flips.
Maybe it's my set up. I had never flipped this heli and I just did what I would normally do, but it took about everything out of it.
First one I ended up getting it back just before the ground. The second I used a lot more + pitch going into it and that seemed to help.
Old Jan 29, 2012, 03:04 PM
distortionist is offline
Find More Posts by distortionist
Joined Jan 2012
My genius flies really good without the canopy, but when its on it tends to want to drift off. I tried with my new genius and it is the same. I think its partly to do with heat effecting the gyros, and also the aerodynamics. I try and keep it as loose as possible so it doesn't rub against the motor or the servos.
I think I will have to cut one up to experiment.
distortionist is offline Find More Posts by distortionist
Old Jan 29, 2012, 04:28 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Have you done the mod to keep the canopy from touching the servos? Before I did that one I lost a servo because the canopy moved over and restricted the movement of the servo.
The rod holding the canopy in the back needs some heat shrink or 24 gauge wire coating slipped over it to keep the canopy from moving in and touching the servos.
Good luck with your problem and let us know what happens.
shastamike is offline Find More Posts by shastamike
Old Jan 29, 2012, 06:28 PM
Joined Jan 2012
No, But that is not what is happening. I will do that mod tho, thanks for bringing it to my attention. It just seems to be drifty and not as stable with the canopy on. I'll get some heat shrink on it and have it as close as possible without touching the servo. Another thing that is annoying me is the trims, they reset, so does the tail subtrim. I think I will try having a different copy to bind from with everything reset and then switch to the other one. It is still annoying. I think it could be fixed with a tx update, let it bind first and then load the trims, and do it each time it binds, so when you switch batteries it binds then loads the trims. I am sure it is possible!
Old Jan 29, 2012, 06:34 PM
Multirotor Promotor
RaymondM's Avatar
Joined Apr 2011
Bob, what you said seems to be the case. I took it to my friend who is a master welder and he looked it over. His prognosis is to heat the solder again on the red wire at the connection to the PCB and let the solder sweat through the stranded wire making for a better connection. Thanks for the advice.
Old Jan 30, 2012, 05:20 AM
Username> is offline
Find More Posts by Username>
Joined Dec 2007
Been having some fun with my GCP outside recently.
Followed the Tom z beginner settings, where normal mode is zero pitch at 0 throttle, and st1 and 2 have a good amount of negative pitch.
At first I flew it in normal mode which is great in no wind although a bit FP like, and switched to st1 in a breeze or windy conditions.
Last week I thought I would never get to grips with it, but i'm now doing FFF and the full monty.
I like this a lot, but wish I could get a little more than the 5 minute flight times per cell.
Username> is offline Find More Posts by Username>
Reply With Quote  (Disabled)
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
