Old Dec 22, 2011, 05:51 AM
jeremyc is offline
Find More Posts by jeremyc
Joined Nov 2011
I've successfully reversed the HK orange servos, everything works nicely. They're spaced out with polystyrene foam and the balls are mounted on the back of the horns for clearance. The front servo is still a Walkera, I'm not noticing any weirdness due to the mismatch.
I've also got a bit more flight time back, after my overheating issues - new motor, new blades, removed the remainder of the button from the head (about 1/3 of it snapped off). The motor still gets hot, but the batteries less so.
Also, if anyone was looking at buying Zippy 350mAh batteries, make sure they're not the Flightmax version - they're long and flat and there's no way to mount them.
jeremyc is offline Find More Posts by jeremyc
Old Dec 22, 2011, 06:03 AM
Joncreid is offline
Find More Posts by Joncreid
Joncreid's Avatar
Joined Oct 2011
Originally Posted by NorCalMatCat View Post
Already lost one to the carpet...
Same here, not happy lol
Joncreid is offline Find More Posts by Joncreid
Old Dec 22, 2011, 06:47 AM
Username> is offline
Find More Posts by Username>
Joined Dec 2007
Originally Posted by jasonjetski View Post
Hi,
I don't suffer with shakey hands unless I don't have my morning coffee But I learned a trick while learning to arc weld. Using a long welding rod,You can notice the slightest shake. My welding teacher taught me to rest my elbows on my hips,or against anything safe while arc welding to help promote a steady hand. It may not help you with soldering,but it costs nothing to give it a try and see if it helps you.
Regards Jason
About 10 years ago, I used to be a pcb assembler for an alarm company.
I did this for about 18-20 Months, soldering a target of 35 pcb's per day (about 210 components p/h), on a dismal 200 p/w income.
It was an awfully robotic and mundane job.
Anyway, working all those Months on a poor income has paid dividends in a sense, as I can easily work on Walkera rx and similar stuff using surface mount components. In fact, I just recently got rid of the stock Walkera rx connectors, then directly hardwired motors, servos, to the pcb, instead.
I can do 3 or 4 Micro Deans in less than a couple of minutes, no sweat, and that's without helping hands.
Now that I don't do it for a career, I really enjoy soldering. It was a different matter back then.
Username> is offline Find More Posts by Username>
Reply With Quote  (Disabled)
Old Dec 22, 2011, 07:05 AM
1Hammer is offline
Find More Posts by 1Hammer
Micro Helicopter Electrician
1Hammer's Avatar
Central California Coast
Joined May 2008
Originally Posted by RawmadeCF View Post
lol why do people have such a hard time soldering...buy a helping hands =)
I soldered 12 gcp batteries w/ micro deans and made a 6 battery parallel harness with m deans and banana plugs in about 30 minutes...the helping hands really does what the name intitles.
The right size solder makes a world of a difference too, thats the biggest mistake I see made, people using way larger gauge solder than needed then wonder why they have a huge blob haha.
Yeah a decent iron and good condition tip will make a difference! I invested in a pretty nice station a couple years ago and never looked back.
Yeah, I agree having the right equipment really helps soldering these little components.
I have a few helping hands and a few vices and clamps that really help.
Regards,
John
1Hammer is offline Find More Posts by 1Hammer
Old Dec 22, 2011, 07:31 AM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA, San Mateo
Joined Oct 2011
Walkera Genius Cp Pro Brushless With Pro Tail And New V3 Canopy.
Have had this heli And Canopy for a week now.
Walkera Genius Cp (1 min 10 sec)
Flight Clip
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Dec 22, 2011, 08:22 AM
candy76man is online now
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
I got one of these as a Christmas present this year...and tried it out before my wife wrapped it
Works awesome compared to the radio shack junk I was soldering with and no digital controls to go out and turn it into a paper weight.
candy76man is online now Find More Posts by candy76man
Old Dec 22, 2011, 08:27 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Couple mods
Did a couple mods today to make the gcp more living room friendly.
Fixed Pitch Blades
Head speed with the cp blades was a little high for in the house so I changed them out with some spare V120d01 blades (waiting for v100d01 blades to arrive). The v120 blades were a little long so I snipped about 1.5cm. The blade root of the v120's is only 1mm, whereas the gcp blade root is 3mm. Blade spacer washers were made using a drill, sim card holder, and a leather hole punch. The spacers aren't perfect but they get the job done.
Cheap & Sturdy Canopy
The canopy I got with mine shattered after a few flights. I have replaced it with a xieda 9958 canopy as it is much sturdier. However, the 9958 canopy is 1.2 grams heavier than the stock, but I don't notice the weight difference in flight.
bytemuncher is offline Find More Posts by bytemuncher
Old Dec 22, 2011, 08:30 AM
Joined Dec 2007
If anyone wants a decent mid priced soldering iron, you can't go wrong with Weller.
Like I said above, I was once a pcb assembler.
In the 18 Months or so that I was doing it we were using a sky Blue coloured soldering station.
Mine was used for around 18 Months of continuous 8 hours per day and it was still working A1. That's good enough for me!
Old Dec 22, 2011, 11:04 AM
RawmadeCF is offline
Find More Posts by RawmadeCF
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
Why turn a GCP into FP when you can get an actual FP heli built for FP bladed for less than half what a Genius Devo rtf costs?
Or do you just do that indoor and switch back elsewhere?
RawmadeCF is offline Find More Posts by RawmadeCF
Old Dec 22, 2011, 11:13 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Is anyone else having issues with bad tail motors ?
The recent few I have seem weak.
I think I'll be getting the dual BL upgrade as I'm not very happy with my CO5 set up.
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Dec 22, 2011, 11:24 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
I'm having good luck with my stock tail motors. I'm actually shocked at how good they are doing... Lasting much better than the ones on the CB100, 4#3, 4G3, V100D03DBL, which are the same tail motor as the Genius DBL kit are going to be..
livonia bob is offline Find More Posts by livonia bob
Old Dec 22, 2011, 11:25 AM
Heli collector
Joined Apr 2009
I don't turn my Genius into a FP I just set it up to fly as a very mild CP.. For indoors and flip to high rates and go outside..
Old Dec 22, 2011, 11:32 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
The BL tail motors didn't last as long as the stock GCP brushed tail?
F..k
Not what I want to hear Bob!
Old Dec 22, 2011, 11:47 AM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Exactly what I do. I can't be taking out Christmas ornaments anymore. Don't want to get the missus down on indoor flights. It flys like a well set up FP indoors. I have a different model set up for outdoors.
I get my parts today. One day late. Should be flying by afternoon. That one extra day is killing me. Am I a heli-addict?
shastamike is offline Find More Posts by shastamike
Old Dec 22, 2011, 03:12 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Welp I went out to the field I fly at, brought my GCP as I figured I would try my first attempt at inverted. So I hovered her around, flew in some circles, then brought her tail in infront of me, I then flipped my fmode switch and proceed to flip her upside down, she hovered there for about a second, I then went to go flip her back rightside up, somehow lost control, slammed the grass upside down, and my NEW CANOPY was split right down the middle of the top! ON GRASS!!!
NorCalMatCat is offline Find More Posts by NorCalMatCat
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
