Old Oct 06, 2011, 10:11 PM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
I am going to look into some small airplane props and see what i can find. I refuse to pay all that money just for the tail blade.
buster7467 is offline Find More Posts by buster7467
Old Oct 06, 2011, 10:14 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
I just can't believe that the V3 rotor is better than the Genius stock rotor.. As Walkera made a new mold for this rotor you would think that they tested it out first... I'm having no blowout problems with my stock Genius..
livonia bob is offline Find More Posts by livonia bob
Old Oct 06, 2011, 10:15 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Originally Posted by zadaw View Post
In a way, I would prefer Walkera sells a complete boom solution like Eflight. I have absolutely scared of having to solder the small wires. I will probably have to pay somebody to do it and this will end up costing more than the MCPx boom.
Yes the whole boom assembly is only @ $10 but unfortunately it needs soldering - I will be making up a spare for mine so when the tail motor goes its plug and play but it would be easier if it was already done for us.
There is a Idea Darryl for wow plug and play tail assemblies
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Oct 06, 2011, 10:19 PM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I think Buster was referring to a Brushless Genius CP. I have only a blowout once when I tried to flip it.
Regards David
I wonder how difficult it is to sold those tiny wires?
zadaw is offline Find More Posts by zadaw
Old Oct 06, 2011, 10:27 PM
Hellraser's Avatar
UK
Joined Jul 2007
Not bad to solder if you have the technique down OK Just don't forget to put the heat shrink on first as I once did
Right so are you saying that e-flight will sell the rotor on its own but wow will not sell you one unless you have the whole brushless tail assembly
Regards David
morgantown, wv
Joined Mar 2004
Yea i was talking about the brushless setup. I don't like to run alot of pitch in my main blades so i think the stock tail set up will work for me. I hope it does. lol
Old Oct 06, 2011, 10:36 PM
Mickmeister is offline
Find More Posts by Mickmeister
Mickmeister's Avatar
Joined Oct 2010
OK you know now that there should be only the one white wire..
What TX and are you turning on the TX then plugging in the heli quickly and setting it up right and level?? Mine will not bind unless it up right but I'm in 6 axis mode so don't know if this is the same in 3 axis....
Thanks to all who verified that things are looking correct.
The transmitter is the Devo 8. I just spent the last twenty minutes trying to get it to bind, but no luck. Bob, I tried your suggestion of making sure it was level before connecting the batt - still no luck. The LED just keeps flashing red.
Mickmeister is offline Find More Posts by Mickmeister
Old Oct 06, 2011, 10:38 PM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
I don't have any problem with the stock t/r just getting tail wag from bent t/r blade so I try mcpx t/r next will be the solo pro t/r. I had the mcpx t/r because I have mcpx. My BL Genius tail held great with stock t/r but I like to try different things since those to heli are close in size I gave a test. I even tried the v100D03 main blades next will be the mcpx main blades. That little motor has more than enough power for now. Even handle some pretty strong winds.
vronny is offline Find More Posts by vronny
Old Oct 06, 2011, 10:45 PM
Heli collector
Joined Apr 2009
Doesn't have to be up right when plugging it in just has to be up right for it to bind.. I can turn on the 2801 then plug in the heli,, let it sit on my lap for 5 minutes and watch the flashing light.. Then set it down upright wait a couple of seconds watch the blades twitch and fly away..
Maybe you got a 2801 RX by mistake,, if so I'll give you 75 bucks for the Genius..
Old Oct 06, 2011, 10:52 PM
Joined Oct 2010
I definitely had it level. Not likely that they gave me the wrong receiver, since it's claimed to have been test flown...
Old Oct 06, 2011, 10:58 PM
ScottAllyn is offline
Find More Posts by ScottAllyn
ɹǝsn pǝɹǝʇsıbǝɹ
ScottAllyn's Avatar
United States, FL, Lutz
Joined Sep 2011
Did it come with a Genius model preconfigured? Have you made sure that the fixed ID is disabled? have you tried one of the default models, just to see if they bind? (I'm just shooting in the dark here )
ScottAllyn is offline Find More Posts by ScottAllyn
Old Oct 06, 2011, 11:16 PM
Joined Oct 2010
Yes, there's a setting for the Genius. As for fixed ID, I did assign one to it, but after I realized it wouldn't bind I turned fixed ID off. So I assume it shouldn't be interfering...
Old Oct 06, 2011, 11:24 PM
Hellraser's Avatar
UK
Joined Jul 2007
when you set fixed ID did you press match button ?
Regards David
Old Oct 06, 2011, 11:34 PM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
not sure about the binding but both of mine will bind no matter haw they are setting...as long as they are perfectly still and no movement ....i binded them laying on there side and it had no affect on the gyros they still flew just the same as if i bind them sitting on there skids....
magic_marty is offline Find More Posts by magic_marty
Old Oct 06, 2011, 11:46 PM
<Marty>
Joined Jul 2011
WOW has the v3 listed separately but they are out of stock....and no telling when it will be back in stock...
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 10:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 09:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 28, 2007 12:49 AM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 09:17 AM
