Old Sep 25, 2011, 06:41 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Originally Posted by Razors edge 29 View Post
Is anyone else having issues with short flight times?
I used to get like 4-5 min now im lucky if I get 2-3. Perhaps it's the lipos; BUT if it isn't, what else could cause this problem?
Could it be the main board?
Is your motor still running very hot Razor - problem is when a motor runs very hot it denatures the magnets and then motors just don't run as efficiently.
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Sep 25, 2011, 07:37 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
it gets hot yes
a higher c lipo would likely help that
or the motor could be bad.
the last flight was good on stock 25C mcpx lipo, which has been used. I imagine a brand new lipo would be better
Regards David
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Sep 25, 2011, 07:38 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
right now i'm still on stock pitch settings
will change soon.
and i have less than 12 flights
Originally Posted by livonia bob View Post
I'm flying for 6 minutes on the stock batteries but I have no where near the number of flights you have and most likely easier on the battery throttle and pitch settings..
Old Sep 25, 2011, 07:46 PM
Purple Aki is offline
Find More Posts by Purple Aki
Joined Jul 2011
Originally Posted by dado099 View Post
I was one of the first to get the Genius, so I have hundred of runs with it.
Today I think my brushed motor has gone.
I tried also with new fresh batteries, but it spins always slower and slower.
I have tried to open the bottom lid, but no success, the 4 little tabs are
too hard to lift.
I wanted to see if it's the usual walkera brushed motor with metal brushes that worn out very fast.
I could destroy the motor to open, but I have only this one and I have no spare.
I would like to know if anyone has suffered already this problem and after how
much time.....
Moreover if anyone has already opened it and what he has found.
Thank you
Dado
Wonder if Walkera are upto their old costcutting tricks and using copper prongs as brushes in these motors?
If so, try a few drops of motor cleaner/wd40 if there's any way of getting it near the commutator. It should get you another 30 uses out of it if the 5g6 motors are anything to go by.
I own a couple of Walkera 5g6 so i'm a regular with this method.
Purple Aki is offline Find More Posts by Purple Aki
Reply With Quote  (Disabled)
Old Sep 25, 2011, 08:03 PM
mnovotny is offline
Find More Posts by mnovotny
Joined Nov 2007
Anyone know weight difference between brushed and brushless versions?
mnovotny is offline Find More Posts by mnovotny
Old Sep 25, 2011, 08:08 PM
Proud Polac is offline
Find More Posts by Proud Polac
El Dorado de Helicópteros
Proud Polac's Avatar
Joined Aug 2011
The bl is about .5 g lighter from what most people are saying
Proud Polac is offline Find More Posts by Proud Polac
Old Sep 25, 2011, 08:14 PM
Hellraser's Avatar
UK
Joined Jul 2007
it gets hot yes
A higher C rated battery will supply more amperage which will make the motor run better but it will also shorten the motors life.
Regards David
QuAd FaNaTiC
Canada
Joined Aug 2009
i tried this, turned pot all the way CW, and then increased travel adjust to 125% and it seems to work
Originally Posted by magic_marty View Post
the servo ext pot is the one closest to the main shaft.....turn it clock wise to increase servo travel and vice-versa.....
Old Sep 25, 2011, 08:18 PM
NJ_Quack is offline
Find More Posts by NJ_Quack
Joined Nov 2010
Has anybody figured out the Left Yaw problem, or do some of these just have very weak tail motors? Thanks
NJ_Quack is offline Find More Posts by NJ_Quack
Old Sep 25, 2011, 08:19 PM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
has anybody else had a issue when you flip the AUX2 switch it disables axis gyros?
on my bnf 2801 i set the gyrosense and tried flipping the aux2 switch to try different settings and it disables the 3 axis .....not sure why but am i the only one with this issue?
is it a setting in the tx i need to enable or inh?
also when the switch is flipped the light on the rx goes out ...but i still have servo control and motor control....does it in both 3 axis and 6 axis mode....
magic_marty is offline Find More Posts by magic_marty
Old Sep 25, 2011, 08:46 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Are you using Toms setup guide,,, with rudder Travel adjust at L=93 and R=140?
livonia bob is offline Find More Posts by livonia bob
Old Sep 25, 2011, 08:52 PM
Heli collector
Joined Apr 2009
Only 12 flights and already it not fast enough for you?? Oh yea I forgot you're one of them dam youngster's.. I'm still putt putting around at 60% D/R..
Old Sep 25, 2011, 08:56 PM
<Marty>
Joined Jul 2011
could you please give the link to Toms set up guide?
it might help out with my Aux2 switch disabling the axis gyros...
thanks a bunch
QuAd FaNaTiC
Canada
Joined Aug 2009
No i set higher throw so it can flip faster.
after flying this heli for a week or so
I find that I love the way it tracks in FFF, it is smooth, and flies like a bigger heli.
the only thing that I think the MCPX might have over the genius, is that I think, or at least mine was, that mcpx is heavier to hover and keep still - I find the genius sometimes a challenge to keep stil, even on lower rates because once you make a correction, it wants to move fast lol.
could be that i need to add in more/less expo and or tweak settings more.
just an observation.
Old Sep 25, 2011, 09:00 PM
Heli collector
Joined Apr 2009
Do you have the AUX2 switch set to aux2/gyro?? it's under INPUT on the first menu..
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 10:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 09:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 28, 2007 12:49 AM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 09:17 AM
