Old Sep 24, 2011, 09:01 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by Ottawa919 View Post
The 2801 is tempting, but I can't help but think that the Genius might be one of the last Walkera's to have an rx for it and that it will be Devo only very soon.
Not to try to 'sell' anyone on the 2801Pro, but you know --when you have something and it's been a good experience, you tend to gush...
Anyway, there are a ton of receivers out there both FBL, motorized tail, regular tail, etc, all the way up to the 2702v which used on the 450-sized FBL bird,and of course the 2801rx... all available to 'pair' with this transmitter for your helis, so I don't think obsolescence is an issue, unless they quickly drop it's compatibility for new models, with the release of the Devo. If they have any sense at all, they will not do that, given the outpouring of people wanting to use it on the Genius... that said, who can tell, but even if they do, I think it's still worth the 'street price' of a used on to snag one.
tracknoob is offline Find More Posts by tracknoob
Old Sep 24, 2011, 09:11 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
thank you
i'll tinker with values later, i like where it lifts off now, so maybe i'll do what you suggested and change top end to 45
QUOTE=Hellraser;19405979]If it was me razor I would keep middle at 25 if you are happy to lift at center stick (Normal Mode) - then all points above middle inhibit except Top which I put at 45 that should give you 9 deg pitch if my maths is right.
If you decide you want zero pitch at center stick then at a later date you just need to drop middle to zero but you would also need to increase throttle curve a bit at center because you would be lifting on lower throttle.
Yes you are right Idle up uses higher RPM with a V on throttle curve where throttle starts at 100 drops a little at center stick and then back to 100 at full stick.
PS its not wist to try and change mode in mid air when the two curves are so wide apart as Tom will tel you.
Regards David[/QUOTE]
Tom
Ahh, okay now i see what you mean.
thanks
R
Originally Posted by Tom Z View Post
You set "ACT" if you want to set the value in percent.
INH is for linear between points.
EX:
PL = 100.0%
P1 = INH
P2 = INH
PM = 80.0%
P3 = INH
P4 = INH
PH = 100.0%
You set your low, mid, and high values that you want. If you want linear points in between you select INH.
I will be posting my Devo 7 TX settings later today.
I just took this example out of one of the settings.
Tom
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Sep 24, 2011, 09:29 AM
RotaryC is offline
Find More Posts by RotaryC
United Kingdom
Joined Sep 2011
Hi all,
I'm looking to get one of these little gems for my first CP, can I ask how the brushed motors are holding up?
Cheers
Carl.
RotaryC is offline Find More Posts by RotaryC
Old Sep 24, 2011, 09:30 AM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Your welcome Razor - yes Toms post explains very well just how this new system works for a idle up V shaped throttle curve.
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Sep 24, 2011, 09:34 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by RotaryC View Post
Hi all,
Cheers
Carl.
I think the jury is going to be out on that one for a while... it usually takes a pretty good number of users, over a pretty significant time, in order to start forming an impression of overall motor longevity. Even on the mcpx, it is still not clear to me that there is a main motor 'issue' to be concerned about, yet a few people have reported high current draw almost out of box, or premature failure. I replaced one because I was having low battery times and poor tail control, but I only knew to do that since someone else reported that the motor could still me turning and producing good power, but causing the symptoms I had. Sure enough, replacing it solved the symptoms.
While I am interested in knowing that sort of info on the Genius of course, the reality is that at probably $7-12 for a new one, I am not overly concerned about it unless and until spontaneous reports of early failure were to start streaming in.
Old Sep 24, 2011, 09:36 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
hmm
maybe I should replace my mcpx main
Old Sep 24, 2011, 09:46 AM
Hellraser's Avatar
UK
Joined Jul 2007
I think with these little brushed cp's Genius and MCP X the motor life will be as much down to collective management and resting between flights as it is to the actual quality of the motor's.
Regards David
Old Sep 24, 2011, 09:54 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Regards David
The biggest thing is how many times and for how long have you had the blades stopped from being able to turn while crashing,, while still having the throttle on..
livonia bob is offline Find More Posts by livonia bob
Old Sep 24, 2011, 10:03 AM
fishfiend is online now
Find More Posts by fishfiend
Joined Jun 2008
The v100d08's motors are brushed, the main has carbon brushes and the tail has the fingers. I was surprised the main motor doesn't get hot and i have a feeling it will last as i have about 50-60 flight on it so far and its still as good as it was as new. As for the tail motor im on my third. The first one i pulled the wires out of the can stripping the wire when i changed the boom and the second one burnt up after the tail was jammed and still running after a crash into next doors garden. It seems to me that the latest motors are much better quality than earlier offerings from Walkera. i remember the 4g3 ones......
fishfiend is online now Find More Posts by fishfiend
RM3Studios is offline
Find More Posts by RM3Studios
RM3Studios's Avatar
Joined Jun 2011
Originally Posted by vronny View Post
Whats up RM? I ordered the 2801 BL version an I will probably be off work next week. Been working 13 days 12 hrs so haven't had alot of time to fly.
Hey Ronny! I ordered the brushed version a day before I found out that there was going to be a brushless version. I'll run it this way until the motor burns out, then do the conversion. I think I have the ESC already from my CB100. You are going to love this thing. I never messed with expo before on my other helis, but this one is touchy and needs it (thanks for the help Tom!) Looking forward to hearing how you like the BL set-up
RM3Studios is offline Find More Posts by RM3Studios
Old Sep 24, 2011, 10:07 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I wonder how long should we set the flight timer for? 4 minutes perhaps?
It is not good to run down lipos
zadaw is offline Find More Posts by zadaw
Old Sep 24, 2011, 10:13 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
I set mine to 4.5 min and I only get, Maybe that flight time if I am hovering; FFF maybe 3.5 min if I am lucky.
I don't think these stock Lipos will last long; one of mine is already weak but it's probably my fault.
Zadaw
I think I remember you saying the Bare bones hyp 240's fit?
If so I'll order some.
Old Sep 24, 2011, 10:18 AM
zadaw is offline
Hong Kong
Joined Jan 2010
Zadaw
I haven't tried any other batteries. I got more than 6.5 minutes of FFF in stunt mode. I did that to test things out but it might have ruined my battery as well.
Old Sep 24, 2011, 10:19 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
4 Minutes sounds good for normal/scale flying.
This is from my Genius review:
Flight times: - Stock battery.
3 Minutes: 3.78V
4 Minutes: 3.71V
5 Minutes: 3.68V
158 mah put back into the battery.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Sep 24, 2011, 10:21 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Okay
Must have been someone else then about 240 lipos.
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
