Old Sep 24, 2011, 01:20 AM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
Originally Posted by Vimd View Post
Hi all,
I got my 2801 version RTF this week and absolutely love it already. This is the 4g3 we thought we were getting 3 years ago. Plus 3 axis stabilization. Amazing.
My question concerns tail trim. I am having to dial in full right tail trim to get it to hold. It will stay but I have even had to resort to 150 clicks of right rudder sub trim and bind with full left trim travel to give me enough right travel to hold. I know this is not normal but can't find any rx rudder adjustment and so have to use just tx methods. Any advice appreciated.
Vimd
when i binded mine for the first time it was doing the same thing and i found out i had the rudder channel reversed.....it needs to be set to normal...
magic_marty is offline Find More Posts by magic_marty
Old Sep 24, 2011, 02:30 AM
KABAL99 is offline
Find More Posts by KABAL99
FRANCE
Joined Dec 2004
hi friends
what is the weight of the blades ???
My 100 D03 blades are dead and i wonder if i can put the Genius blade on it (i think yes)....
Many thx
KABAL99 is offline Find More Posts by KABAL99
Old Sep 24, 2011, 04:03 AM
The Doktor is offline
Find More Posts by The Doktor
United States, NJ, Lumberton
Joined May 2010
Looks like I'm gonna hold off on the Genius for a while. Just had my 2nd crash with my V120D02 due to a serious malfunction with my ~1 month old 2801 Pro. No, not blaming TX for my poor flying skills. I've shredded several sets of blades with no help from TX, these 2 were different & troubling.
Perhaps some long time Walkera fans could comment on my problem. WARNING! Long post here
Ed
The Doktor is offline Find More Posts by The Doktor
Old Sep 24, 2011, 04:28 AM
helicraze is offline
Find More Posts by helicraze
Joined Mar 2010
Get a new tx only 99 us for 2801 pro
helicraze is offline Find More Posts by helicraze
Old Sep 24, 2011, 05:07 AM
Vimd is offline
Find More Posts by Vimd
I crash therefore I am
Vimd's Avatar
Queensland Australia
Joined Nov 2007
Originally Posted by livonia bob View Post
Higher is/should be more set "0" to 90% and "1" to 80% and switch back and forth to see which one is better,,,, say "1" feels better,, then change "0": to 85 and "1" to 75 test again keep dong this till you get it dialed in moving the two values closer together but not the same so you have a choice.. After all no reason to have a switch if both are the same,, Like you flip the light switch up and the light is on,, you flip the switch down and the light is on what's the point of having a switch if you have to unscrew the HOT bulb to get in the dark..
Thanks Bob I'll try that.
Vimd is offline Find More Posts by Vimd
Old Sep 24, 2011, 05:12 AM
Joined May 2010
helicraze, where do I get a 2801 Pro for $99? And is shipping something like $50?
Got $140 + shipping in current TX from WOW. Considering the level of support I've received, would not mind trying a different source...
Ed
Old Sep 24, 2011, 05:22 AM
Vimd is offline
Vimd's Avatar
Joined Nov 2007
Thanks Marty. Rudder reverse is set to normal.
Old Sep 24, 2011, 05:25 AM
Vimd is offline
Vimd's Avatar
Joined Nov 2007
Originally Posted by jasonjetski View Post
Hi Nathan,
Does the tail rotor spin freely when you blow on it?
Iam just wondering if the tail blade might be on too far.
Regards Jason
Hi Jason.
I'll check that again but the rotor seems to have clearance on the motor can.
Old Sep 24, 2011, 06:52 AM
Ottawa919 is offline
Find More Posts by Ottawa919
Joined Dec 2010
The 2801 is tempting, but I can't help but think that the Genius might be one of the last Walkera's to have an rx for it and that it will be Devo only very soon.
Ottawa919 is offline Find More Posts by Ottawa919
Old Sep 24, 2011, 07:04 AM
ScottAllyn is online now
Find More Posts by ScottAllyn
ɹǝsn pǝɹǝʇsıbǝɹ
ScottAllyn's Avatar
United States, FL, Lutz
Joined Sep 2011
Originally Posted by KABAL99 View Post
hi friends
I have a dozen blades here and they all weigh between 1.71 and 1.72 grams.
ScottAllyn is online now Find More Posts by ScottAllyn
Old Sep 24, 2011, 07:46 AM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
The 03 blades are 19.5mm wide where as the genus are 16mm so probably have much different lift properties - when it comes to thickness at the shank to fit the blade holders both are just under 3mm so should fit OK - using the calipers to gage the actual thickness the 03 blades are 2mm where as the genius is only 1.2mm.
so its really a case of try the genius blades and see if they will work for you - my gut feeling is they will probably do the job but not give as much lift as the 03 blades - and the 03 is quite an heavy machine.
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Sep 24, 2011, 08:11 AM
JackDaniels is offline
Find More Posts by JackDaniels
Joined Sep 2005
I've gotta give credit where it's due. This thing is flat out awesome..... Stock with no mods..
I'm running zippy 240s that I had sitting and they fit and they work great.
JackDaniels is offline Find More Posts by JackDaniels
Old Sep 24, 2011, 08:39 AM
Joined Mar 2010
Cant remember maybe ebay or rc711 or somewhere else
Old Sep 24, 2011, 08:54 AM
alexaglob is offline
Find More Posts by alexaglob
alexaglob's Avatar
Joined Nov 2010
Ed
$95 http://www.hobbyone.com.hk/cn/product.jsp?id=10309
$119 http://www.miracle-mart.com/store/in...oducts_id=3390
dont know about shipping
alexaglob is offline Find More Posts by alexaglob
Old Sep 24, 2011, 08:56 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Woot!
That sounds like a crazy good price on what is, IMHO, a terrific "intermediate" level radio set.
tracknoob is offline Find More Posts by tracknoob
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
