Old Sep 23, 2011, 09:59 PM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
how does the micro deans plug size up to the walkera molex connector ....i mean is it bigger or smaller?
thanks...
magic_marty is offline Find More Posts by magic_marty
Old Sep 23, 2011, 10:00 PM
<Marty>
Joined Jul 2011
Originally Posted by tracknoob View Post
Yup, I put -40 expo into the RUDD for my own 2801Pro based on great advice from right here, and that made the tail a lot more comfortable, and while it doesn't piro like an ice dancer, the tail does get around okay, now. The main thing is it HOLDS -- no blowouts!
i did the same only i i went over the 100% on the DR ...seems to be doing fine....and as far as the piro speed it seems the same as the Devo 7 ....
Old Sep 23, 2011, 11:05 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
for those with the devo 6 rtf models
in normal mode, how much throttle can you apply before you can hear motor bog?
also
what about idle up for bogging?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Sep 23, 2011, 11:07 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
also
what pitch curves are you running Razor
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Sep 23, 2011, 11:26 PM
Vimd is offline
Find More Posts by Vimd
I crash therefore I am
Vimd's Avatar
Queensland Australia
Joined Nov 2007
Hi all,
I got my 2801 version RTF this week and absolutely love it already. This is the 4g3 we thought we were getting 3 years ago. Plus 3 axis stabilization. Amazing.
My question concerns tail trim. I am having to dial in full right tail trim to get it to hold. It will stay but I have even had to resort to 150 clicks of right rudder sub trim and bind with full left trim travel to give me enough right travel to hold. I know this is not normal but can't find any rx rudder adjustment and so have to use just tx methods. Any advice appreciated.
Vimd
Vimd is offline Find More Posts by Vimd
Old Sep 23, 2011, 11:31 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
stock, or what it came with
says
normal
100, -67, -33, 0, 33, 67, 100 (which are 7 points I guess?)
the output for these points is
-15, 0, +12, +25, +36, +49, +60 (does this mean that mid stick is 25+)
I'm still trying to figure this radio out - not sure on pitch/throttle curves
in this scree, there is also a function called :EXP - off/on - no idea what this is.
anyways
idle up is
-55, -37, -18, 0, +20, +40, +60
also
for some reason, with some of these output for each point, there is a button saying "status" - active or inhibit? not sure, why I wouldn't want that point active? it comes default to inhibit?
weird
anyone on here figure out the throttle curve/pitch curve settings menu's for Devo 6 or 8?
also
why does it ask me for servo hold when entering pitch/throttle curves?
Regards David
Old Sep 23, 2011, 11:43 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by Vimd View Post
Hi all,
Vimd
What are your gyro settings?? and do you have it set to be on??
livonia bob is offline Find More Posts by livonia bob
Old Sep 23, 2011, 11:46 PM
Vimd is offline
Vimd's Avatar
Joined Nov 2007
82% on 0 and 1.
Yes it is on.
I've tried higher and lower. Doesn't seem to make much differerene. Is higher more tail gyro sensitivity?
Old Sep 23, 2011, 11:48 PM
Hellraser's Avatar
UK
Joined Jul 2007
says
normal
anyways
idle up is
also
weird
I'm thinking of changing H to maybe 85%/
idle up is -100, -67, -33, 0, 33, 67, 100
yes its always difficult to translate curve's into true pitch but "IF" they have done the same old trick with 5 deg pitch at center stick - I suspect its 5 deg = 25 then 60 = 12 deg - if you have two much pitch then it labors the motor and can cause it to bog down.
unless you really want to throw it around I would drop the pitch to 9 or 10 deg = which I suspect is 5 = 1 deg
you can set as many points as you wish for a straight line curve you only need to set two - first and last.
Hope this helps .....
Regards David
Old Sep 23, 2011, 11:59 PM
Heli collector
Joined Apr 2009
82% on 0 and 1.
Yes it is on.
Higher is/should be more set "0" to 90% and "1" to 80% and switch back and forth to see which one is better,,,, say "1" feels better,, then change "0": to 85 and "1" to 75 test again keep dong this till you get it dialed in moving the two values closer together but not the same so you have a choice.. After all no reason to have a switch if both are the same,, Like you flip the light switch up and the light is on,, you flip the switch down and the light is on what's the point of having a switch if you have to unscrew the HOT bulb to get in the dark..
Old Sep 24, 2011, 12:03 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Dave
it does help thanks
I was contemplating lowering top end, low end seems fine and doesn't bog much, if at all.
so, your saying that if I change the L and H settings, the other settings will follow suit, or do you mean just the top and bottom should be changed to stop bogging?
also
idle up has higher RPM's, and seems to bog less than normal mode, yet top end is the same?
sorry for tall the questions
Regards David
Old Sep 24, 2011, 12:29 AM
Hellraser's Avatar
UK
Joined Jul 2007
Dave
it does help thanks
also
If it was me razor I would keep middle at 25 if you are happy to lift at center stick (Normal Mode) - then all points above middle inhibit except Top which I put at 45 that should give you 9 deg pitch if my maths is right.
If you decide you want zero pitch at center stick then at a later date you just need to drop middle to zero but you would also need to increase throttle curve a bit at center because you would be lifting on lower throttle.
Yes you are right Idle up uses higher RPM with a V on throttle curve where throttle starts at 100 drops a little at center stick and then back to 100 at full stick.
PS its not wist to try and change mode in mid air when the two curves are so wide apart as Tom will tel you.
Regards David
Old Sep 24, 2011, 12:39 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
You set "ACT" if you want to set the value in percent.
INH is for linear between points.
EX:
PL = 100.0%
P1 = INH
P2 = INH
PM = 80.0%
P3 = INH
P4 = INH
PH = 100.0%
You set your low, mid, and high values that you want. If you want linear points in between you select INH.
I will be posting my Devo 7 TX settings later today.
I just took this example out of one of the settings.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Sep 24, 2011, 12:46 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Hi all,
Vimd
It seems another person has reported a similar issue. Can you check whether your tail rotor is alright. I wonder if there is insufficient pitch in the rotor?
zadaw is offline Find More Posts by zadaw
Old Sep 24, 2011, 01:08 AM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
82% on 0 and 1.
Yes it is on.
Hi Nathan,
Does the tail rotor spin freely when you blow on it?
Iam just wondering if the tail blade might be on too far.
Regards Jason
jasonjetski is offline Find More Posts by jasonjetski
Discussion smallest lightest 10-12mp camera? cdi3d Aerial Photography 16 Apr 27, 2011 09:36 PM
Article Think Geek's MX-1 RTF Helicopter Review: Is it the World's smallest R/C helicopter? Michael Heer Coaxial Helicopters 27 Oct 29, 2008 08:43 AM
The lightest 3D belt driven micro electric helicopter in the world--------ELE Firefox ELE kiki Product Announcements 42 Aug 27, 2007 11:49 PM
Discussion ELE firefox-100, flying weight 180g-the lightest 3D helicopter in the world. ELERC Mini Helis 11 Jun 21, 2007 08:17 AM
