Old Aug 25, 2011, 08:00 PM
Chatenever is offline
Find More Posts by Chatenever
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Question
How to Reverse Rotation on a Brushed Motor
Is this just a matter of reversing the two power wires to the motor? Or, is there more to it, like doing anything with the capacitors?
Chatenever is offline Find More Posts by Chatenever
Old Aug 25, 2011, 08:17 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Capacitors are just there to reduce EM noise. Switch the wires. Some brushed motors are timed (optimized) to run better in one direction than another by rotating the can a few degrees one way or another. If you reverse the direction they will run just fine, but not be able to put out as much power (rpm) in the new direction.
You can fine tune many brushed motors by timing or rotating the case, if it's really important that you wring out every last bit of power or efficiency from it.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Aug 25, 2011, 08:28 PM
z-matrix is offline
Find More Posts by z-matrix
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
No, they are DC motors, the commutators do the switching, though the motor can be optimized for 1 direction like having inclined and or interleaved commutation angles...
some reading:
http://en.wikipedia.org/wiki/Commutator_(electric)
Z
z-matrix is offline Find More Posts by z-matrix
Old Aug 25, 2011, 09:14 PM
Joined Jul 2006
some reading:
Z
??? I've been reversing brushed motors for years, simply by switching the wires. Or am I reading your answer wrong?
Old Aug 25, 2011, 09:51 PM
z-matrix is offline
z-matrix's Avatar
Joined Dec 2005
Well you posted while i was writing and you are reading it wrong, i have said no for the capacitor thing, it is not an AC motor that runs off 3 phase
Old Aug 25, 2011, 09:55 PM
Joined Jul 2006
Ah, ok. got it.
Yes he can reverse the motor direction simply by reversing his wires. We're in agreement.
Old Aug 25, 2011, 10:37 PM
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
We're in agreement.
Whew! I'm so glad. Thanks for the info.
Old Aug 25, 2011, 10:46 PM
Joined Jul 2006
Hi Chatenever,
I have brushed motors that are run direct drive (no gearbox) that must obviously turn in one direction in order to fly correctly.
I use the same motor, though in gearboxes, which mean they must now turn in the opposite direction; so that after going through the gearbox, they are once again spinning the correct direction.
Most of these motors are the run of the mill el cheapo motors supplied by vendors such as GWS, et al.
They are timed 'neutral' which is a fancy word for saying that they spin in both directions equally efficiently.
All I need do is switch the leads. And so I do. And the planes fly beautifully.
PS: I'm a dyed in the wool lover of brushed motors and gearboxes (old fashioned but often times way more efficient than the modern day brushless outrunners).
My absolute BEST flying planes (for me) use brushed motors and gearboxes...
It's all in the parameters we want to optimize.
Chuck
Discussion how to reverse motor rotation dudly Power Systems 8 Nov 22, 2009 11:36 PM
Discussion How to reverse servo rotation on mixing? GreenAce92 Foamies (Scratchbuilt) 2 Nov 07, 2008 06:24 AM
Question Reverse a Reverse Rotation Motor? MOSHEE Power Systems 0 Feb 08, 2005 11:11 PM
how to reverse rotation with a brushless motor bpu6999 Power Systems 2 Mar 08, 2002 07:06 PM
Reverse rotation props for a reverse turn motor? Foxtrot Beginner Training Area (Aircraft-Electric) 2 Jul 29, 2001 09:04 AM
