Old Sep 10, 2003, 09:17 AM
Daniel Follador is offline
Find More Posts by Daniel Follador
Sao jose dos Campos - Brazil
Joined Sep 2003
Idea
1/200 Scale U-boat
Hi There!!!
I'm planning to "convert" one 1/200(35cm long & 3cm wide on the larger section...) scale U-boat from Nichimo on a R/C Sub.
I've found the micro R/C receiver on the website:www.mikroantriebe.de(receivers with 4 & 5 channels with 21x12x10mm(approx.) but I'll try to build a micro ballast system for it. I'm trying to find plans for a micro pneumatic cilinder...
Can anyone help me?
Daniel
Daniel Follador is offline Find More Posts by Daniel Follador
Old Sep 10, 2003, 12:37 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Look for Clippard Air Components.
They specialize in micro-air fittings, valves, and cylinders.
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Sep 12, 2003, 11:38 AM
daisycutter is offline
Find More Posts by daisycutter
36 Russky jets
daisycutter's Avatar
malaysia
Joined Nov 2002
umm, how about small hypodermic srynges? you could try modifying some or you could make your own system from brass tubing and a bit of rubber
daisycutter is offline Find More Posts by daisycutter
Old Sep 15, 2003, 09:08 AM
Joined Sep 2003
I'm gathering ideas on wich one will be the safest method to build, since the size will be very reduced.
A friend from mikroantriebe gave me other idea, use a Lego pneumatic cilinder. I've found it but unfortunatelly it's too big...
I'll take some photos of the unbuilted sub ASAP.
Daniel
Old Sep 19, 2003, 12:05 PM
Joined Sep 2003
Hi There,
here goes a pic of the ballast tank ill try to build.
This is the first time I try to attached a pic... if it doens't work, please forgive me.
Take care you all!
Daniel
Old Oct 05, 2003, 08:05 PM
scififlyer is offline
Find More Posts by scififlyer
Registered Useless
scififlyer's Avatar
United States, TN, Knoxville
Joined Feb 2003
Cleverest thing in The SubCommittee Report was a pump ballast tank that had the pump FILLING the sealed tank with water to go negative. The tank emptied when a relief valve was opened, the trapped air under pressure blew the water back out! It would fit a small boat better than a gas system, and it is a fail-safe design.
scififlyer is offline Find More Posts by scififlyer
Old Oct 06, 2003, 11:11 AM
Joined Sep 2003
I'll check the Subcommittee for it! Is it a open report or members only?
Thanks a lot for the help!
Daniel
Old Oct 24, 2003, 09:06 PM
Registered Useless
scififlyer's Avatar
Joined Feb 2003
The article was in the "SubCommittee Report" magazine, for subscribers. Don't know if an article was posted on the website.
Old Nov 10, 2003, 10:31 AM
Registered Useless
scififlyer's Avatar
Joined Feb 2003
Check out the review of the soon-to-be-released 1/72 Type 7c in another thread here. May be better for conversion!
miss bud 1/12 scale nitro boat rico3 Racing Boats - Internal Combustion 13 Dec 19, 2004 12:45 AM
Cool miss bud 1/12 scale nitro boat rico3 Dock Talk 2 Aug 15, 2004 04:07 AM
1/72 scale U-boat preview scififlyer Submarines 1 Oct 27, 2003 04:08 PM
Question What propellor for 1/200 scale ship? glebel Scale Boats 3 Oct 27, 2003 06:08 AM
1/72nd scale pt boat running gear? sgonzo Scale Boats 6 Sep 30, 2003 02:02 AM
