Old Aug 24, 2011, 11:04 PM
rickhensley is offline
Find More Posts by rickhensley
GliderPilot
rickhensley's Avatar
United States, NC, Charlotte
Joined Aug 2011
Multiplex EASY STAR
Well after much debaiting and reading many threads about this bird, thought why not give one a try. I had been looking @ a close version of this until I found a really great deal on a Easy Star w/added brushless motor and ESC.
I have already purchased numerous gliders and or sailplanes, which ever suits your fancy.
I am still on the learning curve and thought this would be a good trainer to learn flying a glider on.
I will post my build of this when I receive, that is also another neat thing I like about Multiplex, you assemble the plane, and you are afforded the ability to do as you like w/o tearing down, which is not sooo easy sometimes w/foam!
And yes I know much has been said already about this very well documented airframe, but not from me
rickhensley is offline Find More Posts by rickhensley
Old Aug 25, 2011, 12:18 AM
glover is offline
Find More Posts by glover
Toy Flyer
glover's Avatar
Flying Field, Work Bench
Joined Mar 2004
And you are going to provide insight not covered by threads like http://www.rcgroups.com/forums/showthread.php?t=1363621
Fly safe, Glover
glover is offline Find More Posts by glover
Old Aug 25, 2011, 07:08 AM
GliderPilot
Joined Aug 2011
No, that has already been said, but for the benefit of those who do not know those threads exist and for what has become new since.
But if you feel I should not add I will stop this thread here.
Old Aug 25, 2011, 12:30 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Go ahead, Rick, continue with your thread, there's no problem, every RCGgroups member has the privilege to start any kind of thread that they choose, just as long as the content is in compliance with RCGroups.com posting guidelines, that's it. So Post away!
Doubletap <RCGroups.com veteran member and Lifelong RC Addict!
Doubletap is offline Find More Posts by Doubletap
Old Aug 25, 2011, 06:20 PM
GliderPilot
Joined Aug 2011
Thank you for your kindness, I was afraid I had stepped on a toe.
Old Aug 25, 2011, 06:22 PM
GliderPilot
Joined Aug 2011
PS: Thread was started alittle over 20 hours ago and has already had 59 hits, somebody must be interested still in this basic yet very advanced airframe.
Old Aug 25, 2011, 07:04 PM
Doubletap's Avatar
Joined Jul 2005
Right On!! Carry On!
Old Aug 25, 2011, 08:16 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Would be nice to see an Easy Star thread where they talk about..... the Easy Star.
Lord knows how sidetracked they get on the big one
There great planes, I have 3 myself.
1320fastback is offline Find More Posts by 1320fastback
Old Aug 25, 2011, 09:36 PM
GliderPilot
Joined Aug 2011
I agree, so help and teach someone just getting into them what their secrets are and what you think about these as you said 3 birds you own. I want to see as many as are willing to in-put their wealth of knowledge about this lady as they are will to share. Thanks for your in-put.
Old Aug 25, 2011, 11:23 PM
USA, CA, Oceanside
Joined Jul 2008
No secrets on this here Inter-web!
My powered Easystars both get:
Increased rudder size: Simply grab a tupperware lid when your wife isn't looking and cut a bigger shaped rudder from it. CA to the original rudder.
Brush-less system: 2000KV Inrunners are built for this bird. Use a 6x4 APC and be done with it.
Belly protection: I use water bottle plastic cut and glues to bottom of the fuselage only where it contacts the ground. Source a 1 gallon square type water bottle from local grocer (strike????) and cut to fit.
Your EZ* will slide like its on ice and taxi like it has wheels!
Wing retention: I use 1 magnet where the wings join together. After a while and a few mishaps the wings will start to slide apart.
Fuselage connectivity: I use very little CA when putting the fuselage together. Only a little at the factory nubs and use clear packing tape elsewhere. This makes splitting the fuse very easy(*) later.
If you ever get the urge to slope a EZ* without a power system (Motor, ESC and big battery) a 600Mah NiMh in the nose will get your CG spot on!
This slope glider is capable of flying in very light lift when others are grounded!
Acrylic paint from WallyWorlds craft section is a easy(*) way to brighten up your plane for high altitude use.
Old Aug 25, 2011, 11:25 PM
Doubletap's Avatar
Joined Jul 2005
My Easy Stars
Well, I have 2 Easy Stars and several EZStar style planes. My first easy star was a damaged box RTF item obtained from Hobby People's annual sidewalk sale 6 years ago for $25. I never flown it stock but immediately upgraded it to brushless/lipo power, and flew it that way a few years until I again modified it by adding ailerons 3 years ago, that really made the Easy come alive! My other Easy is still in kit form waiting to be built....it will be built similarly like my first but will be stock RET 3 channel but with the same brushless setup and with an array of LED lights specifically for night flying.
Old Aug 25, 2011, 11:45 PM
GliderPilot
Joined Aug 2011
Wow great stuff already, stock is fine and modified is Ok too.
This is the stuff I am looking for. I have a brushless set coming w/the kit, 1320fastback the tips about glue/tape was a great tip and the plastic on the bottom is one I am sure many will use not only on this bird, but any other type as well.
And we are still w/the subject matter too boot.
doubletap, when you build, do you think you may do a turtorial of your build and share with us.
I also like the paint tip very much too. I have learned one important thing about sailplanes, color in the right place will save the day!
Old Aug 26, 2011, 02:11 PM
skyhawk1 is offline
Find More Posts by skyhawk1
United States, WV, Calhoun
Joined Nov 2004
I fly my EZ Star with an in runner brush less. And usually fly it as a sailplane. With a 2100 3 cell it is not hard to get 1 hour flights. Just get up high and catch the thermals.
The only other modification that I have on my EZ is an extended rudder. The extended rudder makes it turn on a dime.
I do have another EZ completely ready to go. Just need to somehow destroy the one I currently fly.
Todd
skyhawk1 is offline Find More Posts by skyhawk1
Old Aug 26, 2011, 05:04 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
My EZ* has stock motor and runs off 7 cell nimh battery. No need to enlarge the rudder if you like nice graceful turns. But if ugly skidded, height diminishing turns are your thing, then get your credit card out...and nail it to your tail.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Aug 26, 2011, 08:06 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Many guys like the way the EZ flies with the rudder extension mod. They don't report that it results in "ugly skidded, height diminishing turns".
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Discussion Easy Star RTF - only "easy" after 1 year - NOT for beginners MiddleMarc Beginner Training Area (Aircraft-Electric) 43 Feb 27, 2012 05:36 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 04:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 04:11 PM
Discussion Multiplex Easy Star 2006 - A discussion of anything Easy Star and sometimes more Grassy Knoll Foamies (Kits) 6833 Dec 31, 2006 11:45 PM
