Old Aug 24, 2011, 07:17 PM
tyra is offline
Find More Posts by tyra
Joined Aug 2011
Fixed tail wheel or movable on tail dragger
Got a question for you folks' I recentlly aquired a Telemaster 66 complete in the box. In the intruction/plans it has a fixed tail wheel provided. Which would you guys recommend, go with the fix tailwheel, or a movable tail wheel? The runway will be short grass. Sugestions gent's and girls,
tyra is offline Find More Posts by tyra
Old Aug 24, 2011, 08:46 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
The tail wheel should track with the rudder for best control. A fixed wheel will not allow you to turn or keep the takeoff run straight,until you get a good prop blast over the rudder and tail up.
Did you really mean fixed in position or "fixed" as not a caster?
Fokker DII is offline Find More Posts by Fokker DII
Old Aug 25, 2011, 04:19 AM
tyra is offline
Joined Aug 2011
Yes it is a non caster, the tailwheel wire is fixed to a former and is non turning. I have a couple of the caster types in my parts box, so I think I will mount one of those instead. Thanks for the reply.
Old Aug 25, 2011, 07:56 AM
Top_Gunn is offline
Find More Posts by Top_Gunn
Joined May 2010
The best setup is a tailwheel that turns with the rudder. A castering tailwheel (i.e. one that is free to turn in any direction and not attached to the rudder) is worse than a fixed tailwheel, at least on grass. So if your choice is between castering and fixed, fixed is better: at least you'll get a straight takeoff run once you get the plane lined up.
Top_Gunn is offline Find More Posts by Top_Gunn
Old Aug 25, 2011, 08:12 AM
tyra is offline
Joined Aug 2011
Top gunn that was what I'am going to do, have it work with the rudder. It was 4am this morning when I was writing that and had not had my first cup of coffee. Thanks a bunch.
Old Aug 25, 2011, 10:09 AM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
If you are flying off grass, the fixed tail wheel will be almost as good as a steerable one, you could even substitute a skid instead of the wheel to save weight and simplify. A wheel does help on a hard runway but even there it is not necessary.
Rodney is online now Find More Posts by Rodney
Old Aug 25, 2011, 02:57 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
slave the tail wheel to the rudder. i've had tail skid and non slaved tail wheels. swore them off over 10 years ago. it's not worth the weight savings!
Toysrme is offline Find More Posts by Toysrme
Old Aug 25, 2011, 03:05 PM
redh is offline
Find More Posts by redh
Fla.
Joined Apr 2005
I use a couple castering type and like them. They are a challenge and if the wind isn't to high they are no big deal. I get a kick out of some of the guys that can't handle it. It's all in what YOU can use and what you want. ENJOY !!! RED
redh is offline Find More Posts by redh
Old Aug 25, 2011, 03:20 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
I've got very mixed feelings about tailwheels, for the most part, I've found inexpensive tailwheel assemblies to be rather flimsy and over time, they get bent out of shape, especially if flying off grass, which also tends to tangle up in them.
That said, steerable wheels can be a boon, but on smaller models, I've never really found them to be much better for directional control than a tailskid which ends in a fairly small radius.
I don't like physically linking rudder to tailwheel, at least without some breakaway built in, so that a hard landing, divot or a slightly skewed landing doesn't transmit all that load directly to the servo.
What I have seen is a semi-castering wheel which freely casters but only within a limited range. I quite like that idea. Taxying isn't an issue for the most part since taxying in and out of the pits is verboten at my club.
MCarlton is offline Find More Posts by MCarlton
Old Aug 25, 2011, 03:35 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Taxying in ond out of the pits is forbidden at my club too BUT, taxying back from the landing at the other end of the field is much easier with a steerable tail wheel when a cross wind wants to weather vane you
BTW we fly off pavement so don't have the drag of grass to help keep it straight.
Old Aug 25, 2011, 04:16 PM
MCarlton is offline
Cromer,Norfolk, UK
Joined Nov 2006
Ah, see, we have grass, divots, lumps, bumps, sand and wheel ruts from full size aircraft, so taxying anything other than a reasonably large model is rather hit and miss (or indeed hit and nose over!)
My approach is to land such that the landing roll out (what little there usually is) finishes up more or less opposite where I am standing.
Old Aug 26, 2011, 03:33 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
My goal is to do that too, however my DeNight Special 50 does not land that slow and we stand at the front end of the runway.
Discussion Need a .25 size high wing tail dragger, ideas? JKEP44 Fuel Plane Talk 6 Jun 25, 2011 08:58 AM
Help! Recommendation on 40 size tail dragger kit or ARF hutchis Beginner Training Area (Fuel) 4 Aug 02, 2009 05:30 PM
Best landing gear type for Easy Star -- trike or tail dragger? JohnSoPA Foamies (Kits) 11 Aug 07, 2008 10:15 PM
Advice for take off of a tail dragger with steering wheel S55 Modeling Science 46 Jan 21, 2005 07:00 PM
Fixed tail or Dissambled tail on the SS ??? GC456 Beginner Training Area (Aircraft-Electric) 5 May 12, 2004 11:39 PM
