Old Jan 21, 2012, 03:56 AM
maourit is offline
Find More Posts by maourit
Joined Jan 2012
Hi,
I start FPV 3 months ago within a bixler and 2.4 ghz 500mw VTX, and would like to fly midle range, about 4 km without patch antena. I am wondering what should be the Video setup (TX, RX, Anatena) in 1.3 ghz. I plan to order a 1 w lawmate setup, but still uncertain about the range.
THANKS
maourit is offline Find More Posts by maourit
Old Jan 21, 2012, 04:08 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by maourit View Post
Hi,
THANKS
Start here: http://www.rcgroups.com/forums/showthread.php?t=1355327
This thread is to post complete Skywalker setups, not for Q&A.
ian
Daemon is offline Find More Posts by Daemon
Old Jan 25, 2012, 02:09 PM
raRaRa is offline
Find More Posts by raRaRa
Joined Nov 2010
What motor do you guys recommend from HobbyKing if I buy the Skywalker from there? I'm looking for long flight with maximum efficiency. I'm thinking about something below 1000kv with 4s battery.
raRaRa is offline Find More Posts by raRaRa
Old Jan 25, 2012, 02:23 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
All the Turnigy motors listed earlier in the the thread, are sold at HK.
ian
Old Jan 25, 2012, 03:31 PM
raRaRa is offline
Joined Nov 2010
Yeah, is this the one that is good with 4s? http://www.hobbyking.com/hobbyking/s...dProduct=18232
There are quite a few motors with 3542 1000kv
Thanks!
Old Jan 25, 2012, 04:01 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
this is not the place for Q and A, use the normal skywalker thread. This is for proven and working power systems.......
stop asking questions here
Adidas4275 is offline Find More Posts by Adidas4275
Old Jan 27, 2012, 03:28 PM
maourit is offline
Joined Jan 2012
Thank you, I am trying to set up my skywalker.
Old Feb 05, 2012, 02:52 PM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Does anyone have a Skywalker fuselage for sale?
lrrps is offline Find More Posts by lrrps
Old Feb 11, 2012, 03:59 AM
AeroWRX is offline
Find More Posts by AeroWRX
Joined Mar 2010
Originally Posted by Crist Rigotti View Post
format stolen from ecampos. :
  • Weight: 1.9 to 2.5Kg depending on 1 or 2 battery setup
  • Motor: Scorpion SII-3014-890kv
  • Prop size: 9x7 APC (cut down from 10)
  • ESC: Castle Phoenix 45 under wing + vent hole, ferrite on Bec out (signal only used)
  • Separate BEC: BEV 4A and ferrite on output
  • Servos used: Hitec HS65HB
  • Flight battery: 1 or 2 x turnigy 4S 5000mA 25C
  • Video battery: Turnigy 3S 2200mA 25C or 3S 1000mAh
  • Flight cam: eBay 480TVL
  • VTX: FOX 1.5W 1280Mhz
  • VTX antenna: DIY straight dipole
  • RX: Dragon Link
  • RX antenna: Stock DL
  • Stabilizer: Eagle Tree Guardian
  • OSD: ET OSD Pro
  • OSD to VTX/CAM: Standard 24awg servo wires
  • LRS: Dragon Link
  • Cruise minimal consumption: 8-10A
  • Climb minimal consumption: 20A
  • Max speed: 32A
  • Max distance reached: 20 miles (40 miles round trip)
  • RTX: Dragon Link
  • RTX antenna: Stock Long Range
  • VRX 1 and 2: Lawmate 1.3Ghz (model without battery)
  • Diversity: Eagle Tree Eagle Eyes
  • VRX 1 antenna: DIY Yagi 14dbi
  • VRX 2 antena: DIY 8dbi Patch
  • Ground station battery: 12 volt lead acid 7000mAh
  • Video distribution: BOSS 4 channel video amp
  • Flight recording: Aiptek MPVR+CB and VuPoint Digital Recorder
  • Flight control viewing: Haier 10" monitor
  • Flight backup viewing: Aiptek MPVR+CB LCD
I'm trying to put together a 20 mile range FPV system. What did you use for the video receiver unit? I see two VRX antennas listed for you?
AeroWRX is offline Find More Posts by AeroWRX
Old Feb 14, 2012, 01:49 PM
hollywoodjoe67 is offline
Find More Posts by hollywoodjoe67
hollywoodjoe67
United States, NH, Wakefield
Joined Mar 2011
* Weight: 1.9 to 2.5Kg depending on 1 or 2 battery setup
* Motor: hk3536
* Prop size: 9x6e APC
* ESC: detrum 70a
* Servos used: Hitec HS65HB
* Flight battery: 4S 5000mA 25C
* Video battery: zippy 3S 2200mA 25C
* Flight cam: gopro hd hero2
* VTX: immerrc 2.4g 500mw
* VTX antenna: ibcrazy bluebeam whip
* RX: Dragon Link
* RX antenna: Stock DL
* Stabilizer: none
* OSD: dosd v2
* OSD to VTX/CAM: Standard 24awg servo wires
* LRS: Dragon Link
* Cruise minimal consumption: 8-10A
* Climb minimal consumption: 20A
* Max speed: 32A
* Max distance reached: 3 miles out so far
* RTX: Dragon Link
* RTX antenna: Stock Long Range
* VRX : Lawmate 2.4g
* Diversity: none
* VRX antenna: blue beam ibcrazy
* Ground station battery: 3s 11.1v lipo
* Flight recording:ez cap and VuPoint Digital Recorder
* Flight control viewing: fatshark base ed.
* Flight backup viewing: gateway laptop w/ezcap
hollywoodjoe67 is offline Find More Posts by hollywoodjoe67
Old Feb 19, 2012, 10:03 AM
bah7566 is offline
Find More Posts by bah7566
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
bah7566 is offline Find More Posts by bah7566
Old Feb 23, 2012, 03:37 AM
jpaus is offline
Find More Posts by jpaus
Down Under
jpaus's Avatar
Joined Aug 2009
* Weight: unsure
* Motor: Hacker a30-10xl
* Prop size: ma 9x7 three blade
*esc : castle Phoenix 45a
* Servos used: Hxt 900s apart from ele - hs82
* Flight battery: 4S 4000mA 30C
* Video battery:3S 3000
* Flight cam: kx171
* VTX: lm 500mw 1.2
* VTX antenna: stock
* RX: Spektrum 9ch
* RX antenna: 2 x sats
* Stabilizer: ET guardian
* OSD: Eagle Tree OSD Pro
* LRS: Nil at this stage
* Cruise minimal consumption: 4a
* Climb minimal consumption: 15a
* Max speed: 80kmh
* Max distance reached: 1.4km
* VRX : 8dbi patch (1.2) / 3dbi omni
* Diversity: Eagle Eyes
* Ground station battery: 3s 5000mah lipo
* Flight recording: fpv japan
* Flight control viewing: dominators
* Flight backup viewing: Japan fpv
Max amps 30a, climbs like hell!! 40 minutes flight time with another 1000mah left
jpaus is offline Find More Posts by jpaus
Old Feb 24, 2012, 07:20 PM
GhostRider32 is offline
Find More Posts by GhostRider32
Joined Dec 2006
* Weight: 4lbs and 14oz
* Motor: Scorpion II 3014-830kv
* Prop size: 9x6 Graupner Cam Folding Prop
* ESC: Jeti / Hacker MasterSPIN 44A
* Servos used: Emax ES08MA 12g metal gear
* Video battery:N/A
* Flight cam: Fat Shark 922
* VTX: RMRC 910mhz 500mw
* VTX antenna: home made V
* RX: TSLRS long range 12 channel
* RX antenna: custom TSLRS long range diversity antennas (extended)
* LRS: Thomas Scherrer V4
* Cruise minimal consumption: unknown at the moment
* Climb minimal consumption: unknown at the moment
* Max speed: estimated at about 60mph
* Max distance reached: yet to be determined
* VRX : 8dbi patch (910mhz) / 3dbi omni
* Flight recording: Aiptek DZO-V58N
* Flight backup viewing: Aiptek recorder screen
More info found here on my blog:
http://www.rcgroups.com/forums/member.php?u=174199
SW build second project down.
Thanks for looking,
Bruce
Where did you get that little camera mount for the camera on top?
GhostRider32 is offline Find More Posts by GhostRider32
Old Feb 25, 2012, 08:26 AM
bah7566 is offline
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
Old Feb 25, 2012, 08:47 AM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
GhostRider32,
That is an cheap $3.99 mount from Hobby King. It's not too bad for a mount that price. Made out of CF and even has two bearings on the tilt.
http://www.hobbyking.com/hobbyking/s...dProduct=11442
Guys, pls stick with the topic here, for any other any other questions look up the first post/links.
Thx.
nakelp86 is offline Find More Posts by nakelp86
Help! flyfly power set up ian.c Electric Ducted Fan Jet Talk 3 Aug 20, 2011 08:33 PM
Discussion STOL power set-up moes Power Systems 6 Aug 17, 2011 11:35 PM
Question Easy glider power set-up slowstick4ap Power Systems 1 Jul 07, 2011 07:23 AM
Help! GY401 SET-UP - DX7 - tail set up... help :( d1cky_kds Electric Heli Talk 16 Jun 27, 2011 06:10 PM
Discussion My XP9303/DragonLink and Skywalker Set Up Crist Rigotti FPV Talk 6 Apr 02, 2011 11:50 PM
