Latvija, Ventspils
Joined Apr 2011
Also stole format
Weight: 2-2.2kg (with or without GoPro) Motor: Turnigy L3015A-1000 Brushless Motor Prop size: 10x7 3 blade TGY ESC: Turnigy 85A Separate BEC: HobbyWing 8-15 amp Servos used: 4 TowerPro MG90S +2 HTX900 for flaps Flight battery: 3S 3000mA x2 Video battery: 3S 800mA 20C Flight cam: Fatshark VTX: 1.2Ghz 1500mW RX: Futaba FASST RX antenna: stock diversity Stabilizer: Ardupilot Mega OSD: Remzibi OSD LRS: 1W 2.4Ghz booster to standard futaba 8fg Max speed: So far, 120km/h Max distance reached: So far, 1.6 km and 1km height Flight recording: Acer One with usb capture Flight control viewing: Fatshark goggles Setup Target: reach 2km height (looks like I'm crazy) Pictures here: http://www.rcgroups.com/forums/showp...postcount=9737 |
Joined Aug 2010
I was going to test the 9x4 but only had one left. I took that prop flying this morning on the Skywalker with the 3536/1450. The 3536/1450 has a 5mm shaft but the 3542/1000kv has an 8mm shaft and I have to ream it out (one way mission) I'll go get a new 9x4 in a minute and let you know how it comes out. Cheers
Joined Jul 2010
I am moving from glow/gas to eletrics and starting in FPV and wanted to know if someone could give me a light here on choosing a motor for my Skywalker.
I want to get a Scorpion motor but can`t decide between SII 3020-890 or SII 3020-1110. I`m going to use it in a 4s setup. Can anyone tell me the pros and cons of both? Best Regards Hugo |
http://www.hobbyking.com/hobbyking/s...dProduct=18232 |
Joined Aug 2010
| Thread Tools | |
| Help! flyfly power set up | ian.c | Electric Ducted Fan Jet Talk | 3 | Aug 20, 2011 08:33 PM |
| Discussion STOL power set-up | moes | Power Systems | 6 | Aug 17, 2011 11:35 PM |
| Question Easy glider power set-up | slowstick4ap | Power Systems | 1 | Jul 07, 2011 07:23 AM |
| Help! GY401 SET-UP - DX7 - tail set up... help :( | d1cky_kds | Electric Heli Talk | 16 | Jun 27, 2011 06:10 PM |
| Discussion My XP9303/DragonLink and Skywalker Set Up | Crist Rigotti | Video Piloting (FPV/RPV) | 6 | Apr 02, 2011 11:50 PM |
