Old Nov 26, 2012, 07:21 AM
Munyuk is offline
Find More Posts by Munyuk
Joined Nov 2008
thoughts on this?
http://www.hobbyking.com/hobbyking/s...r_1320kv_.html
Munyuk is offline Find More Posts by Munyuk
Old Nov 26, 2012, 09:38 AM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Lower max amps, 28. I would prefer something with higher amp cap. Something a little beefier.
Shadrack is offline Find More Posts by Shadrack
Old Nov 26, 2012, 10:06 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
I'm looking at either:
http://innov8tivedesigns.com/Cobra/C...6-12_Specs.htm
Or
http://innov8tivedesigns.com/Cobra/C...5-10_Specs.htm
Not sure of engine compartment dimensions and max prop size (also what prop gets dangerous for launching)
eroeder is offline Find More Posts by eroeder
Old Nov 26, 2012, 10:50 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Engine is external, and you are good stock with a 9 x 6. No danger in launching at all.
Again, look for something in the 1200kv range for 3s, and 1000 range for 4S.
Copy the successful configs on here instead of trying to find a new motor.
Old Nov 26, 2012, 05:18 PM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
Isn't picking a motor part of determining a successful config?
Why so high on the Kv? Won't a larger prop turn slower and use less amps? The recommended motor is 830Kv and 12x6. Assuming the pic is the same, the 9x6 you suggest should be well clear of chomping fingers.
Old Nov 26, 2012, 05:31 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Sure, and if you look around you will see that with 3S, you want about 12-1400kv, for 4S you want less.
12 x 6 won't fit without a lot of mods.
I run the same 1200kv, 9 x 6, and have had level flight with 3 amps.
Can fly an hour with this config.
Larger prop also gives less top speed.
Old Nov 26, 2012, 05:42 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
I don't think we're all talking about the same Skywalker
subsonic is offline Find More Posts by subsonic
Old Nov 26, 2012, 05:51 PM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
Damn, my bust.
Got side tracked between groups mointored on the Skywalker and Skyhunter. Oops.
Sorry.
Old Nov 26, 2012, 06:08 PM
rotojon is offline
Find More Posts by rotojon
Live To Fly
Joined Jan 2010
Good luck
rotojon is offline Find More Posts by rotojon
Old Nov 26, 2012, 06:42 PM
rotojon is offline
Live To Fly
Joined Jan 2010
Subsonic.. Love that compass man! I like the 2-wheel main as well.... Little more drag but better than one center wheel I'm sure.
Old Nov 26, 2012, 09:58 PM
Cathay Stray is offline
Find More Posts by Cathay Stray
Flying Zayin
Cathay Stray's Avatar
China, Guangdong, Guangzhou
Joined May 2012
This compass thing is indeed so good. Can I ask you to post more close-ups of the chassis part? What does it look like from the belly side? To my shame I didn't give it much thinking and just used standard long-legged 2-wheel chassis, but your solution looks so much better and smarter.
Also, is there a wheel on the tail end?
I don't have a wheel there, only (shame on me, yes yes) a strap of tin cut out of a beer can, merely to protect the foam from rubbing against the surface of the runway. Weighs less then 2 g.
Cathay Stray is offline Find More Posts by Cathay Stray
Old Nov 26, 2012, 10:10 PM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
I'll post in the 1680 SW thread. This one is for power systems.
Old Dec 07, 2012, 10:58 PM
Jeffem62 is offline
Find More Posts by Jeffem62
Jeffem62's Avatar
United States, TX, El Paso
Joined Apr 2012
Anybody using sunnysky motors? Just got my new Condor in. Looking forward to the build.
Link to motor.
http://epbuddy.com/index.php?main_pa...roducts_id=189
Jeffem62 is offline Find More Posts by Jeffem62
Old Dec 14, 2012, 02:10 PM
crashellini is offline
Find More Posts by crashellini
Joined Dec 2012
Hi Folks,
I am building a 1900 sw and have an Axi 2808/24 gold line motor kicking around.
It says 2 or 3s lipo cells on the blurb, if I run it on 4s, will it burn?!! (a 9x6 pusher prop)
Will it work on the SW anyway?
Thanks!
crashellini is offline Find More Posts by crashellini
Old Dec 31, 2012, 03:38 PM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
  • Weight: around 73 oz.
  • Motor: 920 kv Emax BL2820/07 from HURC (http://www.headsuprc.com/servlet/the...ushless/Detail)
  • Prop size: 9x6, 10x5, 10x6, 10x7
  • ESC: Hobbywing Platinum 40A
  • Separate BEC: Castle 10A
  • Servos used: HS-82MG x4 on wings (noisy little buggers); HS-65HB x2 on tail
  • Flight battery: 1 Sky Lipo 4S 4000 mAh
  • Video battery: small 3S
  • Flight cam: RMRC 480
  • VTX: 400 mW Sunsky
  • VTX antena: DIY Cloverleaf
  • RX: Sunsky or Lawmate
  • RX antenna: DIY Virevent or Skew-planar wheel
  • Stabilizer: GWS PG-02 dual-gain, switchable via Tx
  • OSD: Remzibi OSD
  • Max wind: about 25 knots
  • Mods: flaps, motor mount, carbon ribbons in wings/stabilizers, proper hinges and control hardware.
Some prop data for my motor. Admittedly, it's not very helpful since I don't have a tachometer and therefore, have no way of measuring thrust.
9x6:
Max current: 28.55 A @ 16.02 V
Max power: 457.3 W
Min voltage: 15.73 V
10x5:
Max current: 31.21 A @ 16.01 V
Max power: 499.7 W
Min voltage: 15.72 V
10x6:
Max current: 35.03 A @ 15.83 V
Max power: 554.6 W
Min voltage: 15.51 V
10x7:
Max current: 37.74 A @ 16.03 V
Max power: 604.8 W
Min voltage: 15.40 V
TexasAggie is offline Find More Posts by TexasAggie
Help! flyfly power set up ian.c Electric Ducted Fan Jet Talk 3 Aug 20, 2011 08:33 PM
Discussion STOL power set-up moes Power Systems 6 Aug 17, 2011 11:35 PM
Question Easy glider power set-up slowstick4ap Power Systems 1 Jul 07, 2011 07:23 AM
Help! GY401 SET-UP - DX7 - tail set up... help :( d1cky_kds Electric Heli Talk 16 Jun 27, 2011 06:10 PM
Discussion My XP9303/DragonLink and Skywalker Set Up Crist Rigotti FPV Talk 6 Apr 02, 2011 11:50 PM
