Old Aug 24, 2011, 09:28 AM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
SKYWALKER POWER-ELECTRONICS set up
There are so many questions and answers regarding power and electronics set up for Skywalker, we could group all the Skywalker set ups here in one thread.
Please post :
Weight of the finished plane
Motor (web links)
Prop size
ESC
Servos used
If possible power consumption @WOT/cruise
all additional electronics:
Long Range sys. video Frequency,etc.
OSD Filters, regulators and so on.
Hehe, pictures a big +
Strictly technical and specific stuff.
PLEASE POST ANY NOT RELATED QUESTION HERE:
http://www.rcgroups.com/forums/showthread.php?t=1355327
OR HERE :
http://www.rcgroups.com/forums/showthread.php?t=1223595
nakelp86 is offline Find More Posts by nakelp86
Old Aug 24, 2011, 09:38 AM
htran is offline
Find More Posts by htran
Joined Jan 2011
Weight of the finished plane: 2.0 kg
Motor (web links): Moxie 980 KV http://www.lowpricerc.com/product_in...roducts_id=991
Prop size: 9x6
ESC: Moxie V 40A
Servos used: HS65 HB
1 x 4s 5000 mah + 1 x 3s 1000 mah
DX201 camera
FY21AP II + AP117 OSD
ReadyMadeRC FPV pod
ImmersionRC 5.8 VTx
htran is offline Find More Posts by htran
Old Aug 24, 2011, 10:21 AM
jsxx is offline
Find More Posts by jsxx
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
1.7kg
Turnigy 3536 1400kv
60a esc
Apc 9x6
Hxt900
Level flight 6amp
Flight slow climb 7amp
2x2200 3s +1000 3s
Hd cam
jsxx is offline Find More Posts by jsxx
Old Aug 24, 2011, 10:50 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
  • Weight: 59-62oz (1.67-1.75kg) CG 30-35mm behind servo wiring slots.
  • Motor: Scorpion Scorpion SII-3008-1220KV (V2)
  • Prop size: APC 10x6 folding with MAXX 40mm spinner adapter for 5mm shaft
  • ESC: Scorpion Commander 55 under wing w/ vent hole in side of fuse. Its built in BEC powers RC Rx and 6 servos
  • Separate BEC: DPCAV any2any + DPCAV LC filter supplies 12V to Vid Tx, and Turnigy 3-5A BEC supplies 5V to camera and mic.
  • Servos used: HS-65MG all around. Also used bevrc's little MG servos and they're fine
  • Single flight & video battery: Hyperion 3S 25C 4000-5000mAh.
  • Cruise minimal consumption: 6.5A (about 75W)
  • Max speed: 50-55mph
  • Max flight times: 30ish min on a single 4000mAh battery, but usually burn through it flying faster in about 18-20 minutes.
  • RC LRS: TSLRS or TSLRS Pro or Rangelink UHF
  • RCRX: TSLRS LR Rx with a couple 3300uF caps to buffer the power so it'll play nice with my Hyperion digital servos on P&T.
  • RCRX antenna: stock
  • RC RSSI indicator: dpcav RSSI LCD screen, mounted where I can look down at it with flight cam (no OSD) Needs 6V power.
  • Flight cam: RCV922 (or here) on full homemade pan & tilt with head tracking
  • Recording cam: GoPro Hero2 1080p medium wide angle on pan servo Y'd off flight cam's pan channel
  • VTX: Sunsky FOX800 (about 600mW) 1.3Ghz
  • VTX antena: Simple homemade Vee (formed from core and twisted/soldered shield ground) high on tail. Alternate BlueBeam Cloverleaf
  • VRX: Standard single A/V output 4ch Racewood 1.2-1.3Ghz Rx with SAW filter mod. Much better selectivity than cheap Sunsky 12ch Rxs which do not work with UHF RC Txs nearby.
  • Diversity (when used): Oracle
  • VRX antenna 1: Re-tuned 1.2Ghz to 1.3Ghz (makes *huge* difference) L-COM 8dB patch, or 3 turn 7dB Helical CP
  • VRX antenna 2: omni SPW or Virevent
  • Ground station battery: Any big 3S battery. Use old puffed ones that still deliver full capacity but only at low current.
  • Video distribution:Whatever diversity provides + OnVon 5 way powered video splitter (been extremely reliable). Also often retransmit on 5.8Ghz to 2nd Fatshark 5.8Ghz goggles.
  • Flight recording: Lawmate PV-1000 DVR and Aitptek MPVR+CB (aka DV5800) as backup. FPV-Japan and clones are proven alternative.
  • Flight control viewing: wired Fatshark Aviator (old 2.4ghz version that I use A/V in), and sometimes new 5.8Ghz Fatshark Aviator - powered off cheap 2S 1000 Lipos
  • Flight backup viewing: Lawmate PV-1000 has a nice big screen
ian
Daemon is online now Find More Posts by Daemon
Last edited by Daemon; Jul 17, 2012 at 02:18 AM. Reason: Updated format from below and more info
Old Aug 24, 2011, 11:27 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Don't forget what kind of battery you are using.
Not sure of weight, but mine is probably heavier than most.
Turnigy Plush 80 Amp (Way too big but it was on hand)
Moxie 980KV http://www.lowpricerc.com/product_in...roducts_id=991
9x6 prop (I've used APC slow fly and electric prop, can't tell difference)
4S 5000mAh for motor
I can launch easily at 20 Amps, cruise at around 4-5 Amps
Also of note. I've tried this setup with a 3S battery and it was kinda wimpy but my batteries were old and wimpy as well.
I have significant problems with my current setup and RVOSD vibrations. Looking to buy a better motor to help solve this and get back to a 3S setup.
BushmanLA is offline Find More Posts by BushmanLA
Old Aug 24, 2011, 02:38 PM
ecampos is offline
Find More Posts by ecampos
FPVEEE ED
ecampos's Avatar
Quebec, Canada
Joined Jul 2010
K, here we go :
  • Weight: 1.7Kg to 1.85Kg depending on 1 or 2 battery setup
  • Motor: Turnigy 35-36 1400KV
  • Prop size: 9x6 APC like (HK)
  • ESC: Turnigy Trust 70A under wing + vent hole, ferrite on Bec out (signal only used)
  • Separate BEC: Turnigy 3-5A, added 470uF caps and ferrites on both in/out
  • Servos used: HXT-900
  • Flight battery: 1 or 2 x Gens Ace 3S 4000mA 25C
  • Video battery: Gens Ace 3S 2500mA 25C or Turnigy 3S 1000mAh
  • Flight cam: Sony KX-171
  • Recording cam: Ebay #11 Keychain 720p + Ebay 180deg fisheye lens
  • VTX: 1W Lawmate 1.2Ghz
  • VTX antena: DIY tuned Vee (RG-316, 14awg copper wire), 1.2 or less SWR (Bird 43 and Daiwa CN-801SII)
  • RX: Dragon link
  • RX antenna: DIY tuned dipole (RG-316, 24awg servo wire) on the tail, 1.2 or less SWR (Bird 43)
  • RX RSSI sends: DIY RSSI buffer using op-amp + cap + ferrite
  • Stabilizer: Feyutech FY-20A, knobs at 3/4 for elevator and ailerons
  • OSD: ET OSD Pro
  • OSD to VTX/CAM:Shielded cables, 2 x 24awg conductors, 1 ground
  • LRS: Dragon link
  • Cruise minimal consumption: 8-10A@30Km/h cruise
  • Climb minimal consumption: 20A
  • Max speed: 111Km/h @ 38A @ 402W
  • Average flight times: 27 - 32 min on a single 4000mAh battery, 75-85% used @ 10.4V
  • Average distance reached: Easily 7Km (14Km+ round trip)
  • Max winds: Fun: 30km/h or less, Flyable but not that fun: 35km/h to 40Km/h
  • RTX: Dragon link
  • RTX antena: Diamond 771 (tested, 1.2 or less SWR)
  • VRX 1 and 2: Lawmate 1.2Ghz (model without battery)
  • Diversity: ET EE
  • VRX 1 antena: eBay +-13dBi Yagi, moded to be tuned SWR 1.2 or less
  • VRX 2 antena: Hyperlink/L-Com 8dBi patch, stock
  • Ground station battery: Zippy (HK) 3S 4000mAh
  • Power box: DIY heavily filtered (combination of ferrite, caps for each output)
  • Video distribution: BOSS 4 channel video amp
  • Flight recording: Security camera 2000's 2 channel DVR (black)
  • Flight control viewing: Fatshark base (new version), 2S 2100 Zippy LiPo
  • Flight backup viewing: HAIER 10'' monitor
Hope didn't forget anything... :P
ecampos is offline Find More Posts by ecampos
Old Aug 24, 2011, 03:32 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Great job :-)
Old Aug 24, 2011, 06:33 PM
Cir2kuk is offline
Find More Posts by Cir2kuk
Chris R
United Kingdom
Joined Dec 2009
Weight: 2.1kg
Motor: 980kv from BEVRC
Prop size: 9x6
ESC: 40a Turnigy
Servos: MG90
Battery: 4S 3000mah x 2
Current draw at level flight: about 3-4A in no wind conditions.
Hobbyking $16 camera with 2.8mm lens
Version #11 HD spycam
video Tx: FOX 800 with whip antenna and patch good for 10km+
Cir2kuk is offline Find More Posts by Cir2kuk
Old Aug 24, 2011, 07:53 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
format stolen from ecampos. :
  • Weight: 1.9 to 2.5Kg depending on 1 or 2 battery setup
  • Motor: Scorpion SII-3014-890kv
  • Prop size: 9x7 APC (cut down from 10)
  • ESC: Castle Phoenix 45 under wing + vent hole, ferrite on Bec out (signal only used)
  • Separate BEC: BEV 4A and ferrite on output
  • Servos used: Hitec HS65HB
  • Flight battery: 1 or 2 x turnigy 4S 5000mA 25C
  • Video battery: Turnigy 3S 2200mA 25C or 3S 1000mAh
  • Flight cam: eBay 480TVL
  • VTX: FOX 1.5W 1280Mhz
  • VTX antenna: DIY straight dipole
  • RX: Dragon Link
  • RX antenna: Stock DL
  • Stabilizer: Eagle Tree Guardian
  • OSD: ET OSD Pro
  • OSD to VTX/CAM: Standard 24awg servo wires
  • LRS: Dragon Link
  • Max speed: 32A
  • Max distance reached: 20 miles (40 miles round trip)
  • RTX: Dragon Link
  • RTX antenna: Stock Long Range
  • VRX 1 and 2: Lawmate 1.3Ghz (model without battery)
  • Diversity: Eagle Tree Eagle Eyes
  • VRX 1 antenna: DIY Yagi 14dbi
  • VRX 2 antena: DIY 8dbi Patch
  • Ground station battery: 12 volt lead acid 7000mAh
  • Flight recording: Aiptek MPVR+CB and VuPoint Digital Recorder
  • Flight control viewing: Haier 10" monitor
  • Flight backup viewing: Aiptek MPVR+CB LCD
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Aug 24, 2011, 08:26 PM
hobbyboy is offline
Find More Posts by hobbyboy
United States, AK, Wasilla
Joined Nov 2001
20 miles.......
Amazing! Just amazing.
hobbyboy is offline Find More Posts by hobbyboy
Old Aug 24, 2011, 09:30 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Originally Posted by hobbyboy View Post
20 miles.......
Yes it is.
Please keep this thread clean and technical , this is to help anyone building this plane for FPV.
All comments are welcomed on Main Skywalker thread
Old Aug 25, 2011, 12:49 AM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Stole ecampos format aswell...
  • Weight: 2.1 Kg
  • Motor: HK SK 3480 1100 kv
  • Prop size: 11x7 APC
  • ESC: Turnigy plush 80 under wing
  • Separate BEC: 12v BEV 4A and 5v BEC
  • Servos used: Hitec HS65HB rudder, Hitec HS64MG elevator, tower pro 9g servos ailerons
  • Flight battery: 4S 5000mA 25C
  • Video battery: Single battery setup
  • Flight cam: SC2000 $50 520TVL
  • VTX: FOX 800mW 1280Mhz
  • VTX antenna: Self-built IBCrazy Vee
  • RX: Dragon Link
  • Stabilizer: RVOSD Gen 5
  • OSD: RVOSD Gen 5
  • LRS: Dragon Link
  • Cruise minimal consumption: 10A
  • Max speed: So far, 99 km/h
  • Max distance reached: So far, 1km
  • RTX: Dragon Link
  • VRX 1 and 2: 1.3Ghz
  • Diversity: None
  • VRX 1 antenna: Self built IBCrazy ground dipole
  • Ground station battery: 2x 2200mAh 12v
  • Video distribution: PYLE PLV2 1 Into 4 Mobile Video Signal Distribution Amplifier
  • Flight control viewing: Headplay video goggles
  • Flight backup viewing: Aiptek MPVR+CB LCD or 7'' DVD player
Blueshy is offline Find More Posts by Blueshy
Old Aug 26, 2011, 10:33 AM
aeropics is offline
Find More Posts by aeropics
aeropics's Avatar
Joined Jun 2008
Would be nice if you added a pic of your setup too, then we can get more hints
aeropics is offline Find More Posts by aeropics
Old Aug 26, 2011, 01:17 PM
ecampos is offline
FPVEEE ED
ecampos's Avatar
Quebec, Canada
Joined Jul 2010
Pics added !
Old Aug 26, 2011, 02:43 PM
vegasbs is offline
Find More Posts by vegasbs
AMA #535918
USA, NV, Las Vegas
Joined Apr 2006
Stole ecampos format as well...
  • Weight: 1.9 Kg (1.4Kg w/o batteries)
  • Motor: Scorpion SII 3014-1220
  • Prop size: 10x5 APC
  • ESC: Exceed 60 amp Opto
  • Separate BEC: Turnigy 8-15 amp
  • Servos used: 6 Hitec HS65HB, + 2 HS-55 for pan/tilt
  • Flight battery: 3S 5000mA 20C or 3S 5500 25C
  • Video battery: 3S 1600mA 20C
  • Flight cam: SC2000 PZ0035
  • VTX: DPCAV 910mhz 500mW
  • VTX antenna: IBCrazy Vee
  • RX: TLRS
  • RX antenna: stock diversity
  • Stabilizer: none
  • OSD: DOSD + V2
  • OSD to VTX/CAM: bulk servo/computer wires
  • LRS: Thomas Scherrer Long Range System
  • Cruise minimal consumption: 7-9A
  • Climb minimal consumption: <20A
  • Max speed: So far, 68mph
  • Max distance reached: So far, 5.01 miles (17.55 miles total)
  • RTX: Multiplex Royal Pro 12
  • VRX 1 and 2: dual DPCAV 900mhz
  • Diversity: Rangevideo
  • VRX 1 antenna: GP Patch or biquad
  • VRX 2 antenna: Dipole
  • Ground station battery: 12v 7000mA lead acid
  • Video distribution: Rangevideo
  • Flight recording: Diamond One Touch
  • Flight control viewing: Trimersion goggles
  • Flight backup viewing: Toshiba 17" laptop
  • Max Amps: 42
  • Thrust (est): 1640gr (57.85oz)
  • Max Watts: >400
  • Channels used: 12
  • Number of successful flights: >25
vegasbs is offline Find More Posts by vegasbs
Help! flyfly power set up ian.c Electric Ducted Fan Jet Talk 3 Aug 20, 2011 08:33 PM
Discussion STOL power set-up moes Power Systems 6 Aug 17, 2011 11:35 PM
Question Easy glider power set-up slowstick4ap Power Systems 1 Jul 07, 2011 07:23 AM
Help! GY401 SET-UP - DX7 - tail set up... help :( d1cky_kds Electric Heli Talk 16 Jun 27, 2011 06:10 PM
Discussion My XP9303/DragonLink and Skywalker Set Up Crist Rigotti FPV Talk 6 Apr 02, 2011 11:50 PM
