Old Feb 21, 2013, 07:31 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
That is looking good. Clarence
onethermal is offline Find More Posts by onethermal
Old Feb 21, 2013, 08:45 PM
Jim 17112 is offline
Find More Posts by Jim 17112
United States, PA, Harrisburg
Joined Jun 2012
Ready to go
Here's e-fuse # 44. With everything on board it came in at 64.7 oz.
Here is what's currently installed:
E flite Power 15
40-Amp Lite Pro Switch-Mode BEC Brushless ESC
HS 81s for rudder and elevator
E-flite DS77s for the spoilers
CAM
Spectrum 7 channel receiver
Thunderpower 2100 3 cell 25c battery
42mm spinner
Aeronaut CamCarbon prop, 13 - 6.5
Except for the decal, it's ready to go. As soon as the weather gets a little better, I'll take it out for a few test glides.
It was a fun build.
Jim
Jim 17112 is offline Find More Posts by Jim 17112
Old Feb 21, 2013, 09:36 PM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Sweet.
Please post pics on the M M Glider Tech FB page. http://www.facebook.com/pages/M-M-Gl...8859168?ref=hl
Merrill
Mr B.... is offline Find More Posts by Mr B....
Old Feb 21, 2013, 09:40 PM
tailsld is online now
Find More Posts by tailsld
United States, NY, Hamburg
Joined Aug 2011
Jim, sweeeeet!
tailsld is online now Find More Posts by tailsld
Old Feb 21, 2013, 11:57 PM
jpt62 is offline
Find More Posts by jpt62
Joined Feb 2012
Originally Posted by Mr B.... View Post
So the Blue #4 Oculus flies!
Went out today to test fly a new plane. All the hard work that went into this plane to get it just right took a little longer than most. It took flight just like it came from the factory.
The first flight launched right into a thermal and went out of sight in a matter of minutes. Not much trimming needed but did have to change a few settings before we started. All went well for this beautifully airplane today.
This is the same model that won at the AMA show in Jan.
Jay I hope that you enjoy your new Oculus as much as I do mine!
Merrill
Does that mean I should be keeping an eye on the mail man Merrill??
If you look again it appears the my shiny blue and white bird is a Riser 100.
jt
jpt62 is offline Find More Posts by jpt62
Old Feb 22, 2013, 11:15 AM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
MrB
How many E-#44 fuselages were built?????
I have one also.
John
jcyr1 is offline Find More Posts by jcyr1
Old Feb 22, 2013, 04:46 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
It looks like two!
Merrill
Old Mar 04, 2013, 09:33 AM
andrew wallace is offline
Find More Posts by andrew wallace
andrew wallace
coleraine ,northern ireland
Joined Mar 2007
Test flew the Oculus yesterday, the wind was very light about 6mph and very overcast not many thermals about Northern Ireland this time of the year.
the only thing i'll have to change is the position of the tow hook, once i lot the model go it rotated straight away on the way up on the winch i was having to push down elevator in and i hadn't to use the pedal on the winch much i didn't get maxium height as it came off early. Once off the line the Oculus just floated about in the light wind i done a left turn and a right turn and it was on rails, i flew it around for a good few minutes and the decided to try a landing i was amazed at how good the airbrakes are, i use the throttle stick for my airbrakes so i can adjust the amount of braking needed the angle that it brings the model down at is just perfect. I had two more similar flights and came home a very happy man
i'll be getting in touch with Merrill now to order an E-fuselage
sorry no pictures
andrew wallace is offline Find More Posts by andrew wallace
Old Mar 05, 2013, 12:16 AM
jpt62 is offline
Joined Feb 2012
No pictures no proof of flight... sounds like all Occuli are on rails right off the board. Well done Merrill
jt
Old Mar 06, 2013, 09:46 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Hi Andrew
You are now one more in the Oculus family, and you see that the way it fly's is not just a story.
Keep in touch after your first contest I would like to know how you do.
Clarence
Old Mar 07, 2013, 09:38 PM
Joined Aug 2011
Recovered the wing and flaps. Next install the servos and check the cg. Supposed to be half way nice this w/e, hoping to at least hand throw if not onewinch the Oculus. I will let you know how the flaps work.
Old Mar 08, 2013, 10:31 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
My E-Oculus is almost done...just a bit more covering and a bit of radio programing and it will be going to the sky... I hate covering with ultracote park light it is just like saran wrap...but the look of the white wing tips look soooo good. The wing will be red with white and transparent white on the tips it is looking good.
Clarence
Old Mar 09, 2013, 04:02 PM
Joined Aug 2011
Okay..plane flew as expected. Really light lift, low 40's and 6-7 mph breeze. Plane flew just like before the flaps, landing was much slower. We have a 3' steel guardrail on the approach of our field. If you want to land close to the end so as not to walk alot, you have to just clear the rail... It makes a nice ping sound when you hit it. Now I can clear it by a safe distance and slow the Oculus alot for a no walk landing. When I dropped the flaps the plane didnt drop off to either side nice and straight. I need to program in more down slaved to the flaps. I kept the same carbon look on the LE, used white not cream and brightened up the bottom, well the pic shows.
Old Mar 10, 2013, 05:22 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Hey Everyone
Just talked to Merrill and He has all his orders caught up and He now has a white and a red Oculus fuselage in a kit and ready to go to a new homes.
So if You are looking to build a new Oculus now is the time to contact Merrill.
www.mmglidertech.com
Spring is here Let's Fly
Clarence
Old Mar 10, 2013, 08:30 PM
Joined Jun 2012
First Flight
We had a break in the weather so it was time to give it a go. The parking lot at a local soccer field is about 10 feet higher than the field. I gave it a good chuck from the end of the parking lot out over the field. It was a very long walk to retrieve my E-Oculus.
Powered launch was very steep. I didn't program in any down elevator. It really wasn't needed.
Power off stalls were straight ahead, the wing tips stayed level.
Wing tips stayed where they were supposed to in turns also.
I am using the flap switch on a Spectrum 7S for the flaps (I added the extra bay).
I have to program a little more elevator compensation next time out.
My E-Oculus weighs in at 64.7 oz. The cg is at the 4.5 mark. I don't know how that compares to some of the others, but at that weight it handles extremely well and is a blast to fly
I was impressed.
Jim
