Old Dec 11, 2012, 02:33 AM
andrew wallace is offline
Find More Posts by andrew wallace
andrew wallace
coleraine ,northern ireland
Joined Mar 2007
nice touch Merrill
love the blue
got word yesterday that my covering has been despatched so fingers crossed i'll be ready to fly soon i reckon i'll be doing a bit of covering over christmas, heat iron in one hand and a hot whiskey in the other to keep warm
andrew wallace is offline Find More Posts by andrew wallace
Old Dec 12, 2012, 05:21 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Originally Posted by skye8070 View Post
Clarence,
Do you have any info on that motor's weight and physical size? I don't see it on the website.
Skye
Well here is what I have for you, width of the motor is 1-7/16 at the widest part and the gear box is at 1-1/16 and the length is 2-5/16 total and 2-1/4 without the drive shaft. I don't have a scale right now but the weight should be close to other motors on the market. I have included 2 pictures and the background squares are 1/2" so that should give you and idea of the size.
Clarence
onethermal is offline Find More Posts by onethermal
Old Dec 15, 2012, 11:15 AM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Wanted to share somethings I have done to fix a problem that I have found. Remember to give enough of the end of the spar to stick out of the ply rib to sand flush. If you don't after time from many hard launches the joiner will show signs of failure. If so please contact the Mfg right away.
In the photos below I will show how to fix this problem. You will need to find something that fits the inside of the hole like a brass or Alum tube or rod. It is 9mm ".352". Wax up the rod a few times and buff out. Slide into the hole a few inches and mix up some Cab-a-cel with a slow hard resin. I have West System in the shop so that is what I used. Mix the consistency of tooth paste. Roll up a half sheet of paper to make a bakers tube. Fill the tube with your mixture and add around the rod. Let set for 24 hours and remove the rod. Sand flat and smooth with a T bar. You may need to clean up the inside of the hole with a round file. The joiner rod should side in and out smooth.
Merrill
Mr B.... is offline Find More Posts by Mr B....
Old Dec 15, 2012, 01:13 PM
ttoomm is offline
Find More Posts by ttoomm
(LITTLE TOM)....
ttoomm's Avatar
United States, CA, Huntington Beach
Joined Jan 2005
Nice job man.
ttoomm is offline Find More Posts by ttoomm
Old Dec 17, 2012, 09:09 AM
concreteman is offline
Find More Posts by concreteman
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Finished 2nd yesterday at contest... Missed landing points by a foot or so, got greedy at went for the smallest target.... Plane went up the line with firm pedal (yes Merrill, on our winch) and pinged firm (I can see Merrill wincing-I can torque em pretty hard), so I am happy about the modifications done while redoing the tips.
WD
concreteman is offline Find More Posts by concreteman
Old Dec 17, 2012, 07:01 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
WD
The second place is good...now just control the greed and 1st will come again.
Clarence
Old Dec 18, 2012, 07:41 AM
andrew wallace
Joined Mar 2007
rudder and tail plane covered and i'm now starting the wings
didn't like the parklite white so i took it off again
Old Dec 18, 2012, 03:35 PM
tailsld is offline
Find More Posts by tailsld
United States, NY, Hamburg
Joined Aug 2011
Looking good Andrew... I have been using solid color on the LE and white on the TE. Easier for me to see, just not so cool looking.
tailsld is offline Find More Posts by tailsld
Old Dec 18, 2012, 09:39 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
The new blue print is done. It now has the E-fuse included on the glider print. Here is a snap shot of the print.
Old Dec 19, 2012, 08:34 PM
jpt62 is offline
Find More Posts by jpt62
Joined Feb 2012
Merrill..
What size servo are you sticking in there for the E-rudder?
jt
jpt62 is offline Find More Posts by jpt62
Old Dec 19, 2012, 08:41 PM
alstrahm is offline
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
United States, CA, San Jose
Joined Oct 2002
Merrill, where can I get a full size print of the E-fuse? Got a few days off over the holidays, might get back on the build
Al
alstrahm is offline Find More Posts by alstrahm
Old Dec 19, 2012, 08:43 PM
BFV is offline
BFV
Find More Posts by BFV
BFV
BFV's Avatar
USA, Mt, Frenchtown
Joined Oct 2002
Any chance of a few pics of the installation? My understanding is the servo horn would protrude a little out of the rudder. Did you use a blister over it?
BFV is offline Find More Posts by BFV
Old Dec 19, 2012, 08:54 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Originally Posted by jpt62 View Post
Merrill..
jt
I used a HS 81BB.
Al
Al I have it on a PDF I can send you.
Old Dec 19, 2012, 09:02 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Here it is!
Old Dec 20, 2012, 09:26 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Oh man shooting paint in molds in December is a bit chilly!
Merrill
