Old Oct 05, 2012, 11:18 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Vern-
The beveled rib was supposed to glue in at the root of the tip panels. Then the plywood 1/16" cap rib glues outside that. You will end up with two plywood 1/16" ribs butted together where the joint is and yes, the dihedral wing joiner is what goes in unglued to the tube spars to join the wing panels when flying.
Tape is used to keep the panels from sliding apart in flight.
After flying, un tape the wings and you have a center section and two tips.
target is offline Find More Posts by target
Old Oct 06, 2012, 07:48 AM
andrew wallace is offline
Find More Posts by andrew wallace
andrew wallace
coleraine ,northern ireland
Joined Mar 2007
i have one outer wing panel finished and have the other all ready for glueing
i take it there's no shear webbing on the outer panels
andrew
andrew wallace is offline Find More Posts by andrew wallace
Old Oct 06, 2012, 10:13 AM
vfrank59 is offline
Find More Posts by vfrank59
vfrank59's Avatar
Joined Jan 2007
Originally Posted by target View Post
Vern-
ok, thanks for the info. I have already used the normal 1/4 in rib and glued the 1/16" plywood cap. So, it will not be a hard re-do repair. I see at the bottom right of the print showing the angle rib and 10 degree angle. It was covered up by all the glue and tools sitting on top of that portion!! crap!
thanks,
Vern
vfrank59 is offline Find More Posts by vfrank59
Old Oct 06, 2012, 11:37 AM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
andrew
Hi Andrew
If you want to put shear webs there you can but it doesn't need it, but I put it on my mid panels not the tips.
The Oculus is designed for a good hard launch not a full pedal launch...you will find that it will go up like a kite on a line without trying to get it to the moon.
Clarence
onethermal is offline Find More Posts by onethermal
Old Oct 08, 2012, 10:33 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I used one "stick" of ballast Sunday at Visalia on my last flight of the contest with the Oculus. There was some light breezes on tghe ground, and many powerful thermals working through the field.
With the added 6oz weight, the plane had no problem in the massive thermal I drove it to.
In fact, it may have helped it climb higher with the slightly higher airspeed the plane was cruising at.
I can say that using the center panel main spar as a ballast tube does work.
R,
Target
Old Oct 08, 2012, 11:15 AM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
[QUOTE=target;22944292
R,
Target[/QUOTE]
Yes it works but with all things there is a cost. ballast in the wing tube works at cost of handling because the further out you spread the ballast past the center point of the wing it requires more to turn the plane so there is a point that all is still good but there is also a point that you cut the turning performance on a RES plane it is not seen as much on full house planes. that is why many people that ballast will put the mass of the weight inside the fuse in a larger mass to help keep the performance cut from happening.
I am going to make up a 6oz and I might make a 10oz for mine to work in a pinch for when I need to ballast...it would amaze some people what just 6oz can do in a light wind.
Clarence
Old Oct 08, 2012, 11:40 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
It works for me and adds no extra weight while not ballasted.
I'll continue to use it.
R,
Target
Old Oct 09, 2012, 12:02 AM
vfrank59 is offline
vfrank59's Avatar
Joined Jan 2007
Great to hear it flies well!
I am a slow builder, I have 40 hrs into the wing. I have the wing completed. It is a fun build. I am trying to assemble the Oculus as perfect as it is suppose to be. Now I have to spend time peeling the glue off my fingers. I don't think I have any fingerprints left!
Vern
Old Oct 09, 2012, 01:21 AM
vfrank59 is offline
vfrank59's Avatar
Joined Jan 2007
On the carbon wing joiner rods, once the incidence pins are set and glued, Do I also glue in one side of the carbon wing joiner rods? Mine rotate around and it is difficult to get everything lined up again?
thanks,
Vern
Old Oct 09, 2012, 04:08 AM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Hi Vern
No need to glue the rods in it will move around so you will need to tape the wing root ends together before flight. the trouble with gluing the rods in is that if you need to replace them and yes it can happen you will be in a bad way trying to figure out how to get the rod end out without damaging the wing spar tube.
Clarence
Last edited by onethermal; Oct 09, 2012 at 04:09 AM. Reason: me spell corectly no I use spell check :-)
Old Oct 09, 2012, 05:41 AM
andrew wallace
Joined Mar 2007
hi vern
i'm with you on the glue on the fingers i would normally build using white pva so using so much CA really does speed the whole thing up
i now have the two outer wing panels finished and i have just the tips to make now
Clarence i've went with the shear webbing on the mid panels because i would be aggressive on the winch the model i would normally fly i'm able to keep my foot to the floor, so i'll need be a good bit of practice
Old Oct 09, 2012, 10:52 AM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Hi Andrew
It looking good and at this rate it won't be too long before you finish. The shear webs are a good choice because the small amount of weight you add will be nothing compared to the added strength you will add to the wing panel.
"so i'll need be a good bit of practice" don't we all...too many times I see people over drive the winch and the plane in there quest to be the highest on launch and when all is said and done they didn't get that plane to the moon, it is all about practice and set up in getting a great launch.
Clarence
Old Oct 13, 2012, 03:16 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Well a few more hours of work on # 22 and I will be done, I can't wait to give it a flight.
Today is a happy day for another reason, I just picked up My new E-Oculus fuse and the red is "SWEET" and the workmanship that goes into the fuse is amazing.
so now I need to get the green Oculus done before I start with the E-Oculus.
Way to go Merrill this E-Oculus is another winner in a long list of winners from MM Glider.
Clarence
Old Oct 14, 2012, 12:01 AM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Got started back on the new master for a 2nd mold for the Oculus. Hope to have it molded in a few weeks. Had to clean up some pin holes in the canopy area. If it works out I will make a 3rd mold. Trying to keep up with demand. With the cold weather setting in curing times are slower.
The fuse colors are Flaming RED & Eyeball White.
Merrill
Mr B.... is offline Find More Posts by Mr B....
Old Oct 14, 2012, 03:39 PM
FrogChief is offline
Find More Posts by FrogChief
Russian Federation, Sakha, Yakutsk
Joined May 2006
Merrill
Merrill,
What kind of finish is used on the fuselages? Enamel, Epoxy Paint, Gelcoat?
FrogChief is offline Find More Posts by FrogChief
Reply With Quote  (Disabled)
