Old Sep 28, 2012, 11:26 PM
andrew wallace is offline
Find More Posts by andrew wallace
andrew wallace
coleraine ,northern ireland
Joined Mar 2007
must say clarence the green does look good
did you use ultracote covering
andrew
andrew wallace is offline Find More Posts by andrew wallace
Old Sep 29, 2012, 05:20 AM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Yes Andrew I did. it is the best covering I have found so far.
Clarence
onethermal is offline Find More Posts by onethermal
Old Sep 29, 2012, 10:00 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I just made ballast for my Oculus.
Its 3 sections of 11/32" brass tubing filled with lead, each 10-5/8" long.
I have 2 spacers made from 5/16" dowel the same length.
These go in the center section spar. The tubes weight just shy of 6oz each, so I can add 6oz, 12oz, or 18oz to the plane.
From my experience in the Spring Fling in Sacramento, the plane can use the forward CG shift in the wind anyway, and the tube is already there.
I will test and report back.
R,
Target
target is offline Find More Posts by target
Old Oct 03, 2012, 12:25 PM
andrew wallace
Joined Mar 2007
since i've taken this picture i have the centre section completed
now ready to start on the outer wing sections
i'm not used working with so much CA i'm more of a white PVA glue man think i've more glue on my fingers than the model
but i'm loving the build hope the rest is as straight forwards
wondering what receivers everybody's using i use spektrum gear?
Old Oct 03, 2012, 01:42 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Hi Andrew
I have been using a Airtronics SD10 G sine they came out on the market and it has been good for me. If the radio you are using now has been good for you then stay with it.
That center panel is looking great and the rest of the build should go as smooth as the first part.
Clarence
Old Oct 03, 2012, 03:22 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You can use almost anything in the cavernous fuse....
I have an AR8000 and satellite in mine.
R,
Target
Old Oct 03, 2012, 04:46 PM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
I have a AR7000 & AR9300 in both of mine.
Merrill
Mr B.... is offline Find More Posts by Mr B....
Old Oct 03, 2012, 09:19 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
R,
Target
Flew a 20 minute flight with two of the three stick of lead, so, 12oz on board last weekend.
Seemed to fly just fine like that. I think that I can safely recommend using the center section carbon tube for a built in ballast tube.
R,
Target
Old Oct 05, 2012, 01:46 PM
vfrank59 is offline
Find More Posts by vfrank59
vfrank59's Avatar
Joined Jan 2007
Ok, I have a question and maybe I have spent to long building and reading the threads but here it is.
I have finished the center main wing panel and the out wing / tip panel. I have 2 beveled ribs left over. I believe they go between the center wing C6 and outer wing.
If so, is the just a spacer to fill in the diheaderal gap?
Does this just glue in between both panels?
Do the spar tubes get connected by the angled carbon dihederal connectors?
I may have missed this on the print or the manual.
I have the spent and one main tip panel completed. 30 hours so far. It is a joy to build a nice kit. 1st one for me in 20 years.
Vern
vfrank59 is offline Find More Posts by vfrank59
Old Oct 05, 2012, 02:07 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Hi Vern
Merrill was talking to me at one time and he was thinking of setting the angle in the rib for the dihedral breaks. right now Merrill is at the fall fest in visalia so he won't be able to answer till monday.
Clarence
Old Oct 05, 2012, 02:13 PM
vfrank59 is offline
vfrank59's Avatar
Joined Jan 2007
Originally Posted by onethermal View Post
Hi Vern
Clarence
yep, i am sure that is what I have. Just concerned, if it fits in between the center and main/tip panel and glued up.
Also a ? on the balsa tips. I have not seen a closeup photo of a finished one.
I would think the 2 tips glue together and add a 1/4 in balsa sheet over th entire thing, drill lightening holes to match and sand to match the rib airfoil. Am I right on this one?
thanks,
vern
Old Oct 05, 2012, 05:20 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Hi Vern
It sounds like you have the concept on the tips, here are two pics I can show you.
on Oculus # 2. I was building without instructions and it was only the second one being built so do what you feel that matches what you want.
Clarence
Old Oct 05, 2012, 05:40 PM
vfrank59 is offline
vfrank59's Avatar
Joined Jan 2007
Hi Vern
Clarence
Clarence
Thanks for the photos. I feel confident in proceeding.
Vern
Old Oct 05, 2012, 08:04 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Merrill Brady with his Oculus finishes 8th place out of 34 pilots at the Fall Fest ALES Friday event.
Clarence
Old Oct 05, 2012, 10:23 PM
jcstalls is online now
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Excellent.
jcstalls is online now Find More Posts by jcstalls
