Yes, Tim. The 1/4" root ribs of the "tip main panel" needs to get beveled before the 1/16" plywood cap is glued on. This is on the tip panels where the wing joiners go in. Reference the plans sheet.
Latest blog entry: Stork 4 Pro X-tail from...
I have yet to re-cover my damaged tip.....
But I have the covering now and its about ready. R, Target |
To CVS??
R, Target |
When I built Oculus # 2 I didn't weigh the wing so I can't tell you if you are heavy or light. So don't sweat the small stuff because the planform should handle the weight. Clarence |
Sounds good to me Clarence - new to much of this so I appreciate the help.
Regards, Tim Quote:
Tim-
I would wonder how you'd lighten the panel after its built, anyway!? If anything, keep the tips of the wing light, and you will be better off. The center of the plane is a good place to have strength and weight in the airplane, IMO.... My Oculus coame in at 62-63oz with shear webs added to the main tip panels, and covered entirely in UltraKote Lite (no ParkLite used on my plane). The difference in weigt according to the website was very little, and I hate repairing covering, so a little more weight I figured was worth some puncture resistance. I winched my Oculus with a busted wing and fuse at Sacramento to win the RES class. Don't make your wing "light".... R, Target |
