Old Aug 25, 2012, 07:10 PM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Will be pulling my E-Oculus fuse out in a few min. Going to start a Blog on it soon.
The E-Oculus is out and trimmed. It is 10.05 oz WOW!
I just may have to build a new wing for this one.
Merrill
Mr B.... is offline Find More Posts by Mr B....
Old Aug 26, 2012, 08:38 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Here's my Hot Rod RED one!
Originally Posted by Keith Kindrick View Post
That looks like a very nice Red. Do you have a picture of the e-fuse to post?
Oculus goes E-------
Merrill
Old Aug 26, 2012, 09:31 PM
NZ7C is offline
Find More Posts by NZ7C
NZ7C's Avatar
United States, AZ, Gilbert
Joined Jun 2011
What motor are you hiding in there Merrill and how soon will you be shipping the red fuses??? Looks great!
NZ7C is offline Find More Posts by NZ7C
Old Aug 26, 2012, 10:07 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
I have a Hacker A30-10XL. All the fuse's are sold as soon as they come out of the mold Red or White. I am filling the orders as fast as I get parts in.
Merrill
Old Aug 26, 2012, 10:10 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
sweet !!!
onethermal is offline Find More Posts by onethermal
Old Aug 27, 2012, 10:55 AM
alstrahm is offline
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
United States, CA, San Jose
Joined Oct 2002
Nice!
alstrahm is offline Find More Posts by alstrahm
Old Aug 27, 2012, 01:08 PM
NZ7C is offline
NZ7C's Avatar
Joined Jun 2011
A30-10XL performance results?
Merrill -
Have you done test flights with the A30-10XL? If so, with what prop and battery size did you use and how many seconds did it take you to reach the 200m ALES contest height?
Thanks.
Tim
Merrill
Old Aug 27, 2012, 05:18 PM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
I will post all the info when I have done the test flight. Just not there yet.
Merrill
Old Aug 28, 2012, 11:21 AM
NZ7C is offline
NZ7C's Avatar
Joined Jun 2011
Back to building - hurray!
Ahhhh......after several months off (consumed by a evening class work on top of my day job, I'm back to the building table) and she's going to have a red fuse!!! Couldn't resist!
Old Aug 29, 2012, 05:13 PM
dwood75 is offline
Find More Posts by dwood75
soaring guy
USA, AZ, Mesa
Joined Oct 2009
Let me know when you are going to fly the new one with the red fuse.
Dee
dwood75 is offline Find More Posts by dwood75
Old Aug 29, 2012, 05:38 PM
NZ7C is offline
NZ7C's Avatar
Joined Jun 2011
Hi Dee!
Well the red fuse is ordered but don't know when it will arrive. I have the center wing built and, finally after all these months, will be able to start on the outer wings this weekend. Believe me - I want to see this critter built - she's going to be a beauty!
Tim
PS Had to retrieve you know who's Ava from that larger area south of the field for him - it survived intact after we blinked and lost sight of it for 2 seconds!
Tim
Dee
Old Sep 02, 2012, 11:40 AM
NZ7C is offline
NZ7C's Avatar
Joined Jun 2011
Overall weight for Oculus E
Merrill -
What are you aiming at (ie best guess at the moment) for an AUW with motor, battery, and esc? OR what's the weight of the ship you are electrifying BEFORE the motor, esc, and battery are added?
Finally able to get back to building and am working on the outer wing panels this weekend. I am still in awe of how well designed and thought out the Oculus kit is. Outstanding.
Tim
Merrill
Old Sep 02, 2012, 11:55 AM
Mr B.... is offline
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
I will let you know when I have it all put together.
Merrill
Old Sep 02, 2012, 07:27 PM
NZ7C is offline
NZ7C's Avatar
Joined Jun 2011
Incidence question - Outer wing panel to center panel
I don't see what makes the ribs meet flush at this joint without having one of the ribs angled.
I am laying out both left and right wing panels. The manual says to layout M2 through M16 and M17(modified T1 for planking); setup on the spars and glue all ribs perpendicular to the building board. After sheeting it indicates on page 9 to install the plywood root rib M1. At this point both the center wing section and the outer wing section have ribs which are perpendicular to the building board (ie if you match the two sections flush to one another the wing would be straight - no dihedral). On page 11 the manual again says to glue the plywood wing root "cap" rib M1 to the outer panel and then proceeds to describe the incidence pin installation.
I would expect that the outer wing panel inboard ribs M1 and M2 would NOT be glued perpendicular to the building board but at the angle required for the dihedral. Otherwise I do not see how the outer wing panel and center panel adjacent ribs can meet flush when the wing sections are fitted together with the proper dihedral. . I know I'm missing something here, but I don't see it. Can someone clarify this for me? I'm sure I'm not seeing the forest for the trees. Thanks in advance.
Tim
Old Sep 02, 2012, 07:47 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Tim-
The center panel ribs are upright at 90* to the build board. After framing up the tip main panels, you need to sand in the 10* of angle to the tip 1/4" root ribs.
After that, you will add the plywood caps to the tip root panels. The plywood is necessary for the incidence pins.
HTH,
Target
target is offline Find More Posts by target
