Old Feb 17, 2012, 01:41 AM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
Originally Posted by Wornpiston View Post
If any of you want a great place to get some plexy glass from to help build your custom PSU case, check this place out: http://www.estreetplastics.com/
They have all kinds of sizes, custom sizes, colors, and thicknesses to choose from.
If you want lexan instead, they have it as well. Great prices too!
I'm not affiliated with this company or anyone that is employed at this company.
I just thought I'd share this place.
Jim
That's where I got my colored plexi from for my charging case build. +1
marksextra is offline Find More Posts by marksextra
Old Feb 18, 2012, 05:08 AM
RemiWM is offline
Find More Posts by RemiWM
Norway
Joined Feb 2012
Here is my portable charging station.
25A powersupply
iCharger 206B
iMax B6
Extra 12v banana plug output.
Led lights
On left side: 220v input and 12v input with a selective switch between these two.
RemiWM is offline Find More Posts by RemiWM
Old Feb 18, 2012, 10:48 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Wow, you guys sure can come up with some really nice setups. The highlights are sort of over the top, but pretty neat.
earlwb is offline Find More Posts by earlwb
Old Feb 19, 2012, 10:03 AM
tsymonds is offline
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
Here's my X4 setup I've been using for awhile. I took the rubber feet off, found some longer screws, bought some nylon spacers and mounted it with about an inch gap under it for good airflow and to make it easier to plug in the balance boards.
Currently building a new box with a pair of X2s on a carbon plate deck with a pair of power supplies under.
tsymonds is offline Find More Posts by tsymonds
Old Mar 12, 2012, 11:22 PM
jrplane is offline
Find More Posts by jrplane
Fast is good
jrplane's Avatar
USA, IN, Hagerstown
Joined Oct 2003
my new toy
Lab 8 , pelican 1550, 24v 1150 watt power supply, and some plexiglass
jrplane is offline Find More Posts by jrplane
Old Mar 13, 2012, 04:57 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
Very slick. I like the plex compartment that opens for storage.
Harry
Harry H is offline Find More Posts by Harry H
Old Mar 17, 2012, 05:38 PM
jhutchey is offline
Find More Posts by jhutchey
United States, NV, North Las Vegas
Joined Jun 2011
Here's my portable charging setup.
Honda EU2000
Meanwell SPV-1500
Powerlab 8
jhutchey is offline Find More Posts by jhutchey
Old Mar 17, 2012, 08:16 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
575 watt/47 amp charging station
Following much advice I got here on these forums last night and this morning I put together this "charging station". Pics pretty well explain it. Not complicated, just a little time consuming. But the end result is great. A totaly contained unit. Right now I have 3 sets of connectors to use, and will probably add one more on the outside. Works out great, fan to keep the PSU cool runs off 12v, that little baby really hums! Power supply is only attached with double sided tape but is solid.
The unit all closed up, storage in the top is very handy.
Two Sky 200 watt chargers fit perfectly;
Power supply and connections;
Fan for additional cooling;
Just plug it in to turn it on.
Traxxas Summit: TQi radio,EVX2 w/lvc,Kershaw DeWalt 14.4v, RPM bumpers, full T-Bone Racing skids, Proline Trencher X on Desperado black wheels, double orange springs front and rear. Full T-Bone Racing Skids, SPC and Sky Lipo batts. Sky and Duratrax chargers.
stuball56 is offline Find More Posts by stuball56
Old Mar 20, 2012, 09:02 PM
SCOREMAN is offline
Find More Posts by SCOREMAN
Joined Oct 2007
I never could make this case work well for anything 'till now.
3 hp server supplies in bottom, flow-through tunnel.
Top shelf hinged with large klett hinges.
Battery shelf is balsa laminated depron. Inside storage simply depron foam.
SCOREMAN is offline Find More Posts by SCOREMAN
Old Mar 21, 2012, 01:05 PM
battmo is offline
Find More Posts by battmo
United States, MO, Columbia
Joined Apr 2007
here is what I came up with.Using the 2 Dell 6650's= 1800 watts and 72 amps.
battmo is offline Find More Posts by battmo
Old Mar 21, 2012, 05:33 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
Did you make that box? It's beautiful!
TheTick is offline Find More Posts by TheTick
Old Mar 21, 2012, 05:58 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
WOW. Homemade hinges and latches and OAK. I love it!!!!
Rick
rampman is online now Find More Posts by rampman
Old Mar 21, 2012, 06:55 PM
Nelapaty is online now
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
wow thats some serious woodworkin skills beautiful
Nelapaty is online now Find More Posts by Nelapaty
Old Mar 21, 2012, 06:57 PM
asm_ is offline
Find More Posts by asm_
California
Joined Apr 2006
For those of you that have both 12v and 24v output with only two PS, how are you able to preventing accidental short if 12v and 24v charger's case come in contact while in use??
asm_ is offline Find More Posts by asm_
Old Mar 21, 2012, 07:08 PM
gww528 is online now
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
The 24v connectors (Anderson Power Poles) are black & red, 12 v are black & yellow.
gww528 is online now Find More Posts by gww528
Show your charging station/table tic Electric Plane Talk 6 Oct 31, 2015 06:32 AM
Help! Help wiring up a portable charging station pdiddyg40 Batteries and Chargers 24 Feb 26, 2015 10:58 PM
Gallery Show off your Foam! Pic Thread. kashalp Foamies (Kits) 0 Aug 18, 2011 12:04 AM
Gallery Show off / List your FPV Multi-rotor Setup BayAreaCrasher Multirotor Talk 10 Aug 17, 2011 03:58 AM
