Old Jan 27, 2012, 10:00 PM
J.Avant is offline
Find More Posts by J.Avant
J.Avant's Avatar
United States, TX
Joined Aug 2011
Here's a few shots of mine. Nothing special 1004 watt 12/24 volt @43 amps. Self contained
Wired with #8 to terminal strip then connectors wired to the terminal strip with #12. All silicone wire.
http://www.rcgroups.com/forums/showa...4&d=1327719457
J.Avant is offline Find More Posts by J.Avant
Old Jan 27, 2012, 10:54 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Mine is pretty portable.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jan 28, 2012, 05:14 PM
icarus46 is offline
Find More Posts by icarus46
icarus46's Avatar
Joined Apr 2010
Man you guys have some great setups.
icarus46 is offline Find More Posts by icarus46
Old Jan 29, 2012, 06:09 AM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Originally Posted by TheWoodCrafter View Post
Now that is BS.
It will short together and trip a circuit breaker.
That is a far cry from seriously injuring someone.
I haven't yet seen 12V hurt someone.
I would have to disagree with you.
Although an isolated 12v potential is highly unlikely to seriously injure you (insuffient potential to generate a current to affect your heart), the issue is the nature of the return potential.
A 12v battery is very different than a 12v AC/DC power supply. An improperly modified/configured supply can place the 12V a couple hundred volts above what you believe is "ground" and can lead to death in a fault situation (I.e. when you become the return).
As an electrical engineer with 40 yrs of experience, including the design of patient monitoring medical electronics, I have dealt with safety design in this area, which for obvious reasons is both redundant and rigiously designed and tested.
ltc is offline Find More Posts by ltc
Old Feb 01, 2012, 02:10 AM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
You might be beating your head on the preverbial "wooden" wall there. (inside joke between me and thwoodcrafter".
anyways, the build of my case can be found here on my blog.
Almost finished Pelican 1520 case wth 2875Watts.
marksextra is offline Find More Posts by marksextra
Old Feb 01, 2012, 11:06 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
mines pretty simple
I think I spent about 70 bucks for all the PSU gear
stgdz is offline Find More Posts by stgdz
Old Feb 03, 2012, 11:59 PM
jrplane is offline
Find More Posts by jrplane
Fast is good
jrplane's Avatar
USA, IN, Hagerstown
Joined Oct 2003
This is what I got!
Lab 8, 24 volt power supply,
jrplane is offline Find More Posts by jrplane
Old Feb 04, 2012, 01:11 AM
Pescador is offline
Find More Posts by Pescador
Boat racing enthusiast
Pescador's Avatar
Canada, AB, Calgary
Joined Jan 2009
I just watched the latest Big Bang Theory and it sure looked like a ProgressiveRC case with fans and lights in Sheldon's emergency kit.
Pescador is offline Find More Posts by Pescador
Old Feb 04, 2012, 08:09 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
It very likely is a Pelican case as that is where ProgressiveRC is getting them from.
http://www.pelican-case.com/
Here is one of the setups I posted about earlier after I added the deck to it with the ventilation fan etc.
earlwb is offline Find More Posts by earlwb
Old Feb 04, 2012, 08:32 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Why would anyone want to keep a Pelican in a case?
Old Feb 04, 2012, 08:58 AM
Troutbum is offline
Find More Posts by Troutbum
Just Fly!
Troutbum's Avatar
United States, WV, Bridgeport
Joined Feb 2011
I like that case!
Can you give me any information about it?
Troutbum
Troutbum is offline Find More Posts by Troutbum
Old Feb 04, 2012, 09:32 AM
jointer is offline
Find More Posts by jointer
Czech Republic, Hlavní město Praha, Prague
Joined Oct 2010
I have done one simple one over the winter.
2x 775W HP, 26V, so around 60-65A/1600W max.
I tested single PS at 75A load for 10-20 seconds and it did not switched off.
Low quality phone photos, sorry.
Power cable and iCharger does fit inside, but since i do not have power line on the places where i fly, it is not built inside the case.
Edit:
Built from these:
http://www.rcgroups.com/forums/showp...&postcount=712
Edit2:
Measuring devices from here:
http://www.sureelectronics.net/goods.php?id=988
jointer is offline Find More Posts by jointer
Old Feb 04, 2012, 12:59 PM
stgdz is offline
stgdz's Avatar
Joined Jul 2011
Where do you guys get you amp and watt readouts?
Old Feb 04, 2012, 02:30 PM
Pescador is offline
Pescador's Avatar
Canada, AB, Calgary
Joined Jan 2009
I think ProgressiveRC cases look more like Serpac than Pelican. Cheaper too.
http://www.orvac.com/SubCategory/Cas...d%20Cases.aspx
Show your charging station/table tic Electric Plane Talk 6 Oct 31, 2015 07:32 AM
Help! Help wiring up a portable charging station pdiddyg40 Batteries and Chargers 24 Feb 26, 2015 11:58 PM
Gallery Show off your Foam! Pic Thread. kashalp Foamies (Kits) 0 Aug 18, 2011 01:04 AM
Gallery Show off / List your FPV Multi-rotor Setup BayAreaCrasher Multirotor Talk 10 Aug 17, 2011 04:58 AM
