Old Feb 05, 2013, 06:20 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Originally Posted by neck View Post
Just curious...you crimping guys. Are you crimping battery connections and ESC connections?
I've never seen anyone do that.
If you mean "are the APPs on both ESC and battery attached by means of crimping?", then absolutely!
All of my APP battery and ESC connectors have always been crimped with my WMR crimpers.
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 05, 2013, 06:36 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
+1 on ESC to Battery, 12s lipo systems. Solder bullet connectors ESC to motor
gww528 is offline Find More Posts by gww528
Old Feb 05, 2013, 06:52 PM
eMoon is online now
Find More Posts by eMoon
I meant to do that
eMoon's Avatar
United States, NY, Albany
Joined Sep 2011
Not to derail charging station talk, but what's the best connector for smaller batteries, 1-3S? While finishing my
Case I can change connectors on batts and charger cords? Right now I run XT60s but they are physically a little big.
eMoon is online now Find More Posts by eMoon
Old Feb 05, 2013, 07:38 PM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
I try and standardize on Deans wherever possible, but on my smaller Depron planes, I use JST connectors
http://www.helipal.com/connector-jst.html
ltc is online now Find More Posts by ltc
Old Feb 05, 2013, 08:47 PM
wjs is offline
wjs
Find More Posts by wjs
wjs
William
United States, MI, Brighton
Joined Oct 2012
Batt to ESC - yes. ESC to motor - no. Use the stock bullets for space and because you don't hardly ever need to touch them. Otherwise I would use APP on those also if not for the size of the connectors.
wjs is offline Find More Posts by wjs
Old Feb 05, 2013, 08:55 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Any good source for a 6' Y-Power cable for the power supply C13 connector for dual power supply to single 3 prong 110V outlet
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Feb 05, 2013, 09:16 PM
wjs is offline
wjs
wjs
William
Joined Oct 2012
Originally Posted by Ohio AV8TOR View Post
Any good source for a 6' Y-Power cable for the power supplys
6' ?? Will have to go 10-12awg I would think. I would be curious of the use case here, as it may change the following ideas. Did not say what connectors on ends, but you can make any cable here with all kinds of quality connectors.
http://www.powerwerx.com/adapter-cab...stom-cable.asp
Personally, I would make something with Zip Cord from here or the depot.
http://www.powerwerx.com/wire-cable/...-zip-cord.html
Probably take a 10awg out as far as needed first from the PS and Y off toward the end with a short Y cable, or use a crimp T-Tap near the end of first pair to take off the Y. I might also forget the Y and just source back another pair directly to PS. Depending on your physical setup.
Old Feb 05, 2013, 09:40 PM
On loan to Texas
Joined Oct 2005
Looking for a Y-Power cable for the power supply C13 connector for dual power supply to single 3 prong 110V outlet. I have 3 computer power supply cables maybe I will just make one
Old Feb 05, 2013, 09:41 PM
wjs is offline
wjs
wjs
William
Joined Oct 2012
These Wago lever terminal blocks are quite handy also. Will take stranded or solid conductors ranging from 28-12awg.
http://www.ebay.com/itm/50-Wago-222-...item1e59f6e5e8
Old Feb 05, 2013, 10:44 PM
So. Cal.
I have a box full of them that I provide with my supplies. They're 6', have one standard grounded 110V plug, and a molded Y that extends to two C13 plugs. PM me and I will take care of you as I have a few extra.
Mark
Old Feb 06, 2013, 08:05 AM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Originally Posted by Ohmic View Post
He was referring to good quality industrial grade tools, not the stuff your find at Harbor Freight.
This is what I use when I crimp Anderson Powerpole connectors.
http://www.powerwerx.com/crimping-to...powerpole.html
Here's the genuine JST XH crimp tool. It's almost $500.
http://www.digikey.com/product-searc...45292?k=wc-110
...and I have both of those, actually two sizes for the APP's and two of the JST-XH crimpers as I am wearing out the first one.
That Wago crimper tool linked above on ebay would not have a home in my tool box. I have tried those and they failed miserably for my demands. Perhaps good for most here but not for me.
Rick
rampman is online now Find More Posts by rampman
Old Feb 06, 2013, 08:19 AM
justpoet is offline
Find More Posts by justpoet
Reckless Driver
justpoet's Avatar
Joined Feb 2013
I just wanted to say that this thread is one of the reasons I joined. There are some very nice setups in here, and I hope to add one of my own to the list soon™.
justpoet is offline Find More Posts by justpoet
Old Feb 06, 2013, 10:31 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I have three genuine Anderson crimp tools, 15/30A, 45A, and 50/75A.
I didn't think you could ware out the JST crimp tool. The Anderson tools are rated conservatively at 50k crimps.
Ohmic is offline Find More Posts by Ohmic
Old Feb 06, 2013, 10:39 AM
Max Headspeed is offline
Find More Posts by Max Headspeed
Outstanding in a gravity field
Max Headspeed's Avatar
New Haven, CT., USA
Joined Feb 2006
Ep rc field box.
WOW!! I came across this link during a recent 'web-browsing', session. (....what ever happened to the term, "Web surfing"...?)
It appears that this fellow RC hobbyist seems to have it together with his 'wheeled' RC Electric flight support field-box.
My field box (2 min 23 sec)
Oh...,and here's the link to the thread on a related EP RC aircraft forum where I found that You Tube link to that vid.
http://www.wattflyer.com/forums/showthread.php?t=57236
Max Headspeed is offline Find More Posts by Max Headspeed
Old Feb 06, 2013, 12:19 PM
On loan to Texas
Joined Oct 2005
Glad you are here. There are a lot of wealthy information threads around here. Spend some time looking around to find them then save them to your "MyGroups" for easy following. Do forget to share what you know as well.
Show your charging station/table tic Electric Plane Talk 6 Oct 31, 2015 06:32 AM
Help! Help wiring up a portable charging station pdiddyg40 Batteries and Chargers 24 Feb 26, 2015 10:58 PM
Gallery Show off your Foam! Pic Thread. kashalp Foamies (Kits) 0 Aug 18, 2011 12:04 AM
Gallery Show off / List your FPV Multi-rotor Setup BayAreaCrasher Multirotor Talk 10 Aug 17, 2011 03:58 AM
