Old Aug 23, 2011, 04:05 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Careful!
"JST" connector confusion - the real story
With the growth of more mainstream micro gear the confusion around the common "JST" connectors has grown. Leaving aside the proprietary systems from Micro Invent etc I thought it might be helpful to gather in one place the info about the most common types. One of them is not even a JST connector but is made by Molex. Hobby King and others however refer to anything small and white as a "JST" connector.
This is just stuff I am familiar with. Feel free to correct any errors or add any other manufacturers/items that use the common 3 small ones to add to the information base. There is limited possibility to move the pins from one system into the shell of another (generally bigger) one, sometimes by trimming very slightly the retaining nylon tabs. This is a lot easier than changing the connectors over for most people but you need to try it and see. Crimping the connectors is not easy but possible. There are no crimping tools for ordinary folks at a reasonable price for these sizes that I am aware of and very high quality needle nose pliers are the best option. And a magnifier and steady hand. Soldering also works but will cause the wire to break easily if it is not also crimped at the strain relief.
There are a few specialist vendors that supply these small leads and/or a change over service. RC-Connectors, and Hansen Hobbies in the US and Micron in the UK are all people I can personally recommend for the servo connectors. There may be others just as good.
http://www.rc-connectors.com/
http://www.hansenhobbies.com/
http://www.micronradiocontrol.co.uk/
JST-XH is 2.5mm pin spacing (same as 0.1inch for all practical purposes)
Not micro size but very common. Used in most balance plugs on LiPos and is the "standard" header spacing in many electronic components including PCs. The standard Futaba/JR style servo plugs are this spacing.
JST- ZH is 1.5mm pin spacing
Used in the Spektrum AR 6300 system and a compatible DSM2 Rx from DelTang (DelTangs are available with all 3 connectors).
Molex PicoBlade is 1.25mm pin spacing.
Used in Futaba, FlyDream, Walkera and the new Hobby King Micro (DSM2) 2.4G systems. The HobbyKing 1.7 and 2.2g Servos have this connector. The 2 pin version is used on the PZ bricks as a battery connector.
JST-SH is 1.0mm pin spacing.
Used for servo connection in Spektrum AR6400 "Brick" and the HobbyKing SuperMicro (not DSM2) systems. Most linear servos have this connector.
You should always check the wiring polarity is also correct. Vendors have had a habit of producing connectors with the wiring swapped around.
The attached picture of the 3 micro connectors and also the common JST balance plug shows the sizes and what they look like front and back. Gene has done a similar one in post 6 which adds the usage info.
I have also attached spec sheets for the connectors which have all the physical measurements. Note that one data sheet covers all the connectors of the same family no matter how many pins they have.
Hope this is useful.
John
UPDATE 26Sep2015: Mark Christian has put up a nice guide to the common 1.00 -1.50mm pitch connectors on the MicronWings website. Lots of clear pictures and dimensions plus useful identification tips.
John
http://www.micronwings.com/HintsAndT...es/index.shtml
jj604 is online now Find More Posts by jj604
Last edited by jj604; Sep 26, 2015 at 07:08 AM. Reason: Typo on picture corrected JST-SX -> JST-SH
Old Aug 23, 2011, 05:20 AM
Peter Mack is online now
Find More Posts by Peter Mack
Mack
Peter Mack's Avatar
Australia, VIC, Mentone
Joined Jun 2004
A terrific summary John. Thanks for unravelling the mysteries of connectors. The makers know not what they do to us! Hope to see you at Sandy next Monday.
Peter
Peter Mack is online now Find More Posts by Peter Mack
Old Aug 23, 2011, 05:24 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Peter, should be there. The Vapor is repaired.
Peter
Old Aug 23, 2011, 07:00 AM
billyjim is offline
Find More Posts by billyjim
billyjim
Cullman, AL
Joined Jun 2007
Bless you, John!
Tnx so much for injecting some Reality into our out-of-this-world hobby!
Even more impressive since of course all you OZ people, being south of the Equator, must walk around on your heads.
Bill
billyjim is offline Find More Posts by billyjim
Old Aug 23, 2011, 07:41 AM
billyjim is offline
billyjim
Cullman, AL
Joined Jun 2007
Here's 'proof.'
Old Aug 23, 2011, 12:53 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Thanks much, John - that was needed!
I took the liberty of consolidating some of the info in your post in the attached jpg. Do I need to add/delete or change anything?
Now we need something similar for battery connectors!
Gene K
speedy01 is online now Find More Posts by speedy01
Last edited by speedy01; Aug 23, 2011 at 07:24 PM. Reason: Added "Nano JST" and "Micro JST" label
Old Aug 23, 2011, 01:08 PM
dhdrover is offline
Find More Posts by dhdrover
slow climbing turn to the left
USA, CT, North Branford
Joined Sep 2009
Ah, clarity.
G'day JJ604,
I have to join the chorus of those who have called this summary very helpful.
I've been intrigued by the DelTang stuff on offer and have found BSDMicrorc very helpful with connector info, but this knowledge should be accessible to all interested.
If only someone would aggregate all this knowledge, clarify it, and put it in an ink-and-paper book (yes, I'm of that age).
Say hi to Melbourne for me. I have family there and do miss it so.
Cheers,
'Drover
dhdrover is offline Find More Posts by dhdrover
Old Aug 23, 2011, 06:00 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Gene, great idea. But I don't think that is a JST-XH connector. It has the same look as the smaller Molex 1.25mm. Where did you get the picture?
There is a bewildering array of this type of connector. The Molex web site lists 3014 different styles of "crimp housings". And that's styles not individual types of connectors.
What I might do is photograph all 4 of them again myself and recreate your useful foursome but with both sides of the plug showing. Then replace the original picture in post #1. That OK with you? The JST-XH has a distinctive pair of location forks on the other side which help identify it.
John
Gene K
Old Aug 23, 2011, 06:08 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
ǝɯ oʇ punoɹƃʞɔɐq ǝɥʇ uı ʎu ǝʞıן sʞooן ʇɐɥʇ ʇnq ǝɹnʇɔıd ǝɥʇ ɹoɟ sʞuɐɥʇ
Originally Posted by billyjim View Post
Here's 'proof.'
Old Aug 23, 2011, 06:53 PM
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by jj604 View Post
I don't think that is a JST-XH connector. Where did you get the picture?
Got it from a Danish web site, I think (Google image search), but it's obviously wrong. I edited my post.
Good idea!
Gene
Old Aug 23, 2011, 07:16 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Thanks. By the way the English micro Rx is DelTang not Deltag. He does a version for all 3 of these connectors. They are made by David Theunissen who has an excellent web site for small stuff here:
http://www.flyelectric.org.uk/
I edited my post.
Gene
Old Aug 23, 2011, 08:05 PM
billyjim is offline
billyjim
Cullman, AL
Joined Jun 2007
JOHN: Yeah I would say it's the NY skyline, but it can't be 'cause the guy's upside down.
And tnx again for further unraveling the connector mess!
Bill
Old Aug 23, 2011, 11:28 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
4 common "JST" connectors
How does this look? Make sense to people?
Last edited by jj604; Sep 23, 2011 at 12:30 AM. Reason: Typo on picture corrected JST-SX -> JST-SH
Old Aug 24, 2011, 02:04 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
And to add to the confusion, another common "JST" connector (the first one I learned about) has 2 pins, is usually red and is typically used to connect smallish batteries (but typically 2s or 3s) to an ESC and is good for several amps (depending on who you ask). This "JST" connector also goes by the name BEC connector (for Battery Eliminator Circuit connector). I believe that the pin spacing is 2.5mm.
flying-llama is offline Find More Posts by flying-llama
Old Aug 24, 2011, 03:11 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
It is. I have a feeling though that the pin profile might be different from the XH series to cope with higher currents but you could check that on the datasheet.
Problem is "JST" is the manufacturer's name not the name of any particular connector.
Question JST connector for 27v at 1.2A? nikg Batteries and Chargers 3 Jun 09, 2011 08:22 PM
Sold JST-XH crimp tool for the JST pins - the real McCoy of crimpers rampman Aircraft - General - Miscellaneous (FS/W) 0 Nov 10, 2010 10:04 PM
connector confusion lasllc Power Systems 1 Dec 09, 2003 11:52 PM
JST Connector Part Number? MikelFelix Parkflyers 3 Jun 14, 2002 10:20 PM
GWS receiver w/ JST connector ToddL Parkflyers 3 Oct 01, 2001 02:08 PM
