Old Sep 25, 2012, 03:57 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Long time no post but here is a small update.
Cheers
Nick
nick_75au is offline Find More Posts by nick_75au
Old Sep 25, 2012, 07:39 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Wow................you're still kickin around huh??? Nice work Nick................gonna get her wet by Spring?(Fall there I guess)
scorpion1 is offline Find More Posts by scorpion1
Old Sep 26, 2012, 03:04 AM
nick_75au's Avatar
Joined Mar 2007
Should have the deck mould done over the weekend, then de flange, leave the plug in and mould the hull half (using the flange created on the deck) by next weekend.
I keep somewhat active on the scale boat stuff, building a 3 metre Oliver Hazard Perry (HMAS SYDNEY) at the moment.
Cheers
Nick
Old Sep 26, 2012, 05:15 AM
nick_75au's Avatar
Joined Mar 2007
Guy I know has a (I'm fairly sure) NEU 1525 1Y 1577 Kv motor with an 8 mm shaft Would this be a good motor as a single for the hull, I would expect to run this on six cells, correct?
Have to double check the specs it may be a 1.5Y
Nick
Old Sep 26, 2012, 08:16 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Did you mean 1527 or 1525 Neu..................the 1527 will work on 6s2p.
Old Sep 30, 2012, 12:12 AM
nick_75au's Avatar
Joined Mar 2007
The Kv is right, I cant recall whether its a 1525 or 21, its not a 1527. Would I be correct in thinking for sport and not out and out racing a single motor of this size would be OK? Say for 50 Kph or so
Cheers
Nick
Old Sep 30, 2012, 05:22 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The 1521/1Y is a 1577 kv motor Nick. I had one in my old Genesis cat a long time ago. Running 6s with a X640 prop it was producing speed in the mid 50's. (mph not kph)
It might be a little wimpy in power level as a single for a 42" cat though.
bill34207 is offline Find More Posts by bill34207
Old Sep 30, 2012, 05:55 AM
nick_75au's Avatar
Joined Mar 2007
Cheers Bill,
I guess I suspected as much, I really would like to run twin but for the sake of simplicity this one will be essentially a first FE for me I'm probably better off with a single. However as I will have a mould this situation can change with the second one
I have no Idea how this will handle as well, It has been suggested by a petrol boater the design of the hull for RC may be a limiting factor in the speed that can be achieved. He explained that as the tunnel tapers from the front to the back it compresses the air providing lift but for the model this may be too much resulting in a boat that wants to flip once the critical speed is reached.
Nick
Old Sep 30, 2012, 06:14 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Originally Posted by bill34207 View Post
A 2028 would be overkill in a 42" hull.
Guess I need to make a retraction on this statement made at the beginning of your thread. The 41" Falcon cat I built about 6 months later seems to really like the 2028 power level.
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Sep 30, 2012, 04:00 PM
osprey21 is offline
Find More Posts by osprey21
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
That it does.
osprey21 is offline Find More Posts by osprey21
Old Oct 05, 2012, 12:18 PM
cosey321 is offline
Find More Posts by cosey321
Joined Sep 2012
Nice work Nick
I cant wait getting mine in the hooouuuse.
Bought 2 leo 4082 kv2000 3500 w for that small hull http://www.r2hobbies.com/rc-boats/hu...at-hull-1.html
i intend to post over a 100kmh.
cosey321 is offline Find More Posts by cosey321
Old Oct 05, 2012, 05:00 PM
nick_75au's Avatar
Joined Mar 2007
Hopefully when I get back to work on Monday the slushies will have finished the tooling gel and layup of the deck. Then I pull the temporary flange off and get the bottom prepared and waxed
Cheers
Nick
Old Oct 08, 2012, 04:54 AM
nick_75au's Avatar
Joined Mar 2007
Progress
I'm ready to deflange the deck and prep the hull half for moulding, Just before I left I added a timber frame and glassed it to the mould to give a stable mould
Cheers
Nick
Old Oct 29, 2012, 03:43 AM
nick_75au's Avatar
Joined Mar 2007
Got to be a name for it now
Hull half is progressing, wasn't game to work on it
Nick
Old Oct 29, 2012, 05:03 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I don't know what kind of Aussie spider that is, but I know what kind it would be if it was on the floor and I had my boots on.
Found Cowl from HobbyKing Pitts-EP 42 inch ARF djmoose Aircraft - Electric - Airplanes (FS/W) 1 Jun 30, 2011 12:36 PM
Video 105 inch dragster 2nd run kenazzo Car Talk 21 Jun 23, 2011 02:48 PM
Video 105 inch dragster first moves kenazzo Car Talk 18 Jun 16, 2011 01:23 AM
Found Cowl from HobbyKing Pitts-EP 42 inch ARF djmoose Aircraft - Electric - Airplanes (FS/W) 2 Apr 04, 2011 10:28 PM
Help! What radio gear from Hobby King for a 20 inch (40 cm) Cessna 180 type model? knlever Scratchbuilt Indoor and Micro Models 7 Mar 26, 2011 06:48 PM
