Old Aug 23, 2011, 03:42 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Question
105 CM, 42 inch Cat power required?
I'm just making an enquiry at this stage, I may have a line on a 1:10 scale Class ONE offshore cat, the hulls are V not flat like the other cats I've seen.
What motor single and what for twins? Is this classed as Big, Because there could be a bigger one available to me as well.
nick
nick_75au is offline Find More Posts by nick_75au
Old Aug 23, 2011, 05:00 AM
nick_75au's Avatar
Joined Mar 2007
Some pics, I cant say too much about it at this stage, at least until this is made into a plug
Nick
Old Aug 23, 2011, 05:14 AM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'd think something in the same power range as a Neu 1527 or Lep 5692 would work well as a single. For twins maybe 1515's or 4074's. A 2028 would be overkill in a 42" hull.
My friend Scott has a 115 cm HPR cat and with a pair of the Castle 1520's hits high 70's on 6s 1p per motor.
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Aug 23, 2011, 05:27 AM
nick_75au's Avatar
Joined Mar 2007
Thanks Bill
Cheers
Nick
Old Aug 23, 2011, 06:12 AM
Rusty Old Fart is offline
Find More Posts by Rusty Old Fart
Zombie Apocalypse
Rusty Old Fart's Avatar
Newcastle, Australia
Joined Nov 2010
crikey she has some ribs
Rusty Old Fart is offline Find More Posts by Rusty Old Fart
Old Aug 24, 2011, 07:04 AM
F1 madness is offline
Find More Posts by F1 madness
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Twin scorpion outrunners would be sweet also
Depends on how many cells you wanna run
F1 madness is offline Find More Posts by F1 madness
Old Aug 25, 2011, 05:02 AM
nick_75au's Avatar
Joined Mar 2007
I've been working on the building boards for the two halves and I glued in the top of the tunnel.
Going to be a little while for motors
Old Aug 25, 2011, 08:07 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I think a couple of these on 6s would rock! 4 polers............
http://www.hobbyking.com/hobbyking/s..._Inrunner.html
scorpion1 is offline Find More Posts by scorpion1
Old Aug 25, 2011, 09:50 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
only 1 probs there scorp
says max 14.8 volts
Old Aug 25, 2011, 10:07 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Thats a bunch of crap, the 4082 1500 version is rated to 6s spinning more mass. 90% of folks on here would run that on 6s.
Old Aug 27, 2011, 04:59 AM
nick_75au's Avatar
Joined Mar 2007
The building boards are complete, and some small progress has been made. I've made a start on the hull.
The boards are called torsion boxes, designed to stay flat.
Nick
Old Aug 27, 2011, 07:51 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
It's also only rated for 55a, sounds like a pretty useless boat motor IMO.
wparsons is offline Find More Posts by wparsons
Old Aug 27, 2011, 10:14 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
55a on 6s is around 1300 watts, almost 2 hp, and HK is famous for underrating a bit. Dunno, i think they(the 4060's) would be good or step up to 4074's.
Old Aug 28, 2011, 10:27 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The HK rating is 800w because of the 55a and 14.8v limits. I'm not sure I would want to be pushing that motor to 1300w.
Old Aug 29, 2011, 03:13 AM
nick_75au's Avatar
Joined Mar 2007
While you guys are debating the motors.........
Here is an update
Nick
Found Cowl from HobbyKing Pitts-EP 42 inch ARF djmoose Aircraft - Electric - Airplanes (FS/W) 1 Jun 30, 2011 12:36 PM
Video 105 inch dragster 2nd run kenazzo Car Talk 21 Jun 23, 2011 02:48 PM
Video 105 inch dragster first moves kenazzo Car Talk 18 Jun 16, 2011 01:23 AM
Found Cowl from HobbyKing Pitts-EP 42 inch ARF djmoose Aircraft - Electric - Airplanes (FS/W) 2 Apr 04, 2011 10:28 PM
Help! What radio gear from Hobby King for a 20 inch (40 cm) Cessna 180 type model? knlever Scratchbuilt Indoor and Micro Models 7 Mar 26, 2011 06:48 PM
