Joined Jun 2004
Where in The USA are these in STOCK
HI All I need on these ESC badly. My project is being held up because of this ESC..I would like to know IF any USA Internet Co. has these in stock?
http://www.hobbypartz.com/volcano-se...hless-esc.html I know the Opto ones are in stock..Don't want to go with a UBEC, if I DON'T have too. Thanks dan |
USA, ME, Ellsworth
Joined May 2008
That is a Hobby Wing ESC, shop it around some of the other sources and look for one that has the same specs and that looks the same (except for color and markings), it will probably be the same ESC. That Hobby Wing stuff is sold under a lot of different house and store brands all over the world.
Here it is in the UK as a Hobby Wing: http://www.giantcod.co.uk/emax-60amp...ller-p-43.html Jack |
Thought I found it, but this one says NO BEC. 10 extra bucks will get you an external BEC.
http://www.valuehobby.com/product_de...=2&item_id=231 |
United States, AR, Jonesboro
Joined May 2011
Here goes these. http://www.hobbypartz.com/60p-dye-1015-60a-esc.html
I use the 30A ones in my MWC Quad and they work great. They should be almost exactly like what you got. The weight on that page says they are 33grams, but it is wrong, its more at a little over 60. Hope it helps. P.S> They have the same demensions as the Volcano series. So, by my standards and guess', its the same thing, just rebranded. |
Joined Jun 2004
Bec
Hi Jack I'm only using 4 servo's-Power HD HD-1160A Mini Servo
http://www.valuehobby.com/products.php?category_id=61 PLane is a 3 1/2 sport type plane, looking for 350 watts or more, onn 3's Thanks Dan |
Pleasant Valley Modelport
Joined Sep 2006
I have one Power Up 20 Amp and it is far better than the lower priced versions. It starts very well and doesn't make that lost sync tick sound because it doesn't loose sync. It costs a small bit more, and I can say pay the SMALL difference. You'll be glad. It is sold at Heads Up RC. I assume other Power Up ESC's will be equally better.
They have other one that should fit your needs. I do not like that lost sync thing, it ca hit the battery with a pulsed short circuit and in some situations of energy stored in the motor, an almost 2X voltage short circuit pulse. Called counter EMF. The Power Up ESC's do not (or have not) had heli functions, so you get limited but correct function. http://www.headsuprc.com/servlet/the...-20-Amp/Detail |
USA, ME, Ellsworth
Joined May 2008
So, in theory, you may have a moment in time when you could be drawing 2.4A (4 x 600 mAh) with four servos. But it is very unlikely to ever happen is my spin on it. I've looked at the fluctuations in the current draw in the eLogger data that was collected in flight on various plane and when you stop the motor and really give the servos a work out, moving them all and to their limits, the most current I have ever seen from four servos was maybe 1.6A or so and just a spike at that. But you know how it goes... If you manage to get a servo stalled (it is still trying to move and some counter force is stopping it) the current goes up and eventually things can get too hot. But once a servo that is not restrained somehow has attained a new commanded position, the current should drop... Jack |
Alameda, CA
Joined Dec 2006
Dan,
Why do you need a 60A if your designing for only 350W?? Is it just to get the switching bec? Sounds like you are tied to Hobbywing, but if you are open to trying something different, I have one of these nib I could let you have for $20 http://www.hobbyking.com/hobbyking/s...dproduct=11618 Hobbywing used to be my go-to affordable esc until I found this one. It has an amazing array of programmables, incl EIGHT timing setting and 5v/6v selectable output. Regarding the prog card, I believe you can get one, but all of the programs can be done very simply with the tx - very straightforward, fast, and easy to understand. A buddy and I have been beating it to death in our PA Addictions without one hiccup - had them to 50A for very short bursts many times. Throttle range is excellent from post to post, and throttle response is immediate. If you want, buy it and use it until you can get your Volcano 60, then I'll buy it back for the same price. Let me know if you're interested. If not, I completely understand - just trying to help get you in the air. Steve |
| Thread Tools | |
| Discussion Avitron USA.. kits in stock | Kinkade | Ornithopters | 31 | Sep 24, 2011 10:47 AM |
| Discussion Where can I buy Lipo's in the USA for a good price? | lacofdfireman | Batteries and Chargers | 15 | Jun 30, 2011 03:52 PM |
| Discussion Why are all these popular vendors out of stock? | sgilbert | Electric Heli Talk | 7 | Apr 07, 2011 10:46 PM |
