Old Aug 22, 2011, 05:55 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
New Product
New!! 3mm Colored $Store Foam Sheets w/No Paper!!
I don't know if this is old news but I just noticed that the colored poster board at my Yankee Dollar store was foam, not cardboard.
Picking up a sheet I noticed that there was also no paper on the back, which was pure white foam. Looking more carefully at what I thought was colored paper on the front, I began to think it was just flat colored paint.
I bought a few sheets in red and yellow, and yes it does seem that there is no paper on it at all. I can't tell if there is an extremely thin plastic film under the paint, or whether it is just a foam finish which seems like a film.
Anyway it is 3mm not 5mm and seems to have no paper, it is absolutely smooth with no waves, and has a flat bright color on one surface. Comes in: red, green, blue, white, black, and yellow were available.
The label says:
Made in China
Dynamic
Suffern NY 10901
Item # 54860
Foam Display Board
20" x 30"
Yellow
vtdiy is offline Find More Posts by vtdiy
Old Aug 22, 2011, 06:35 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Cool. Let us know how it works on foamie airplanes.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Aug 22, 2011, 07:05 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
What to build with it really quick? Something simple I can do in an evening. Something not too big -- stuff seems a little flexible.
2S blue wonder-ish
Old Aug 22, 2011, 07:18 PM
yolomojo is offline
Find More Posts by yolomojo
complet beginer
canada
Joined Aug 2010
i would have to say the rcpowers shocoui. if your not fimilar with it just google it. it should fly on a 2s it just might be a bit weak.
yolomojo is offline Find More Posts by yolomojo
Old Aug 23, 2011, 03:25 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
2S blue wonder-ish
with Yellow material? A Cub obviously!
Grejen is offline Find More Posts by Grejen
Old Aug 23, 2011, 04:46 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
cool
i'll have to check my store to see if they have any
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Aug 23, 2011, 05:13 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Remember it's Yankee Dollar, not Dollar Tree (we have both stores here, and I didn't see any in DollarTree -- just the usual 5 mm ReadiBoard).
I'm thinking GPW's Blue Albacorde for the first trial. I happen to have a J250 lying in a drawer and a 15A Aveox brushed esc. and a 350 mah, and a 800 mah 2S pack.
The only thing is, this is 3mm stuff, not 5mm, like fanfold.
But maybe I can double it up -- which would keep the color on the outside on both sides.
And uh, think I'll go with the red. So a Red Albacorde?
Old Aug 23, 2011, 07:45 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
yup
none of colored stuff at Dollarama
just looked, but picked up some ready board.
Old Aug 23, 2011, 07:51 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
I wonder it its available anywhere else. Can't be the only outlet that manufacturer sells to.
Company name is "Dynamic Manufacturing and Distributing" in Suffern, NY.
Old Aug 24, 2011, 09:45 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Red Albacorde
Well, made patterns and cut foam for a GPW Blue albacord using the new colored foam.
Seemed pretty obvious to me after cutting the wing that 3mm in this stuff wasn't going to hack it for a model this size. So I laminated it to 6mm using a light spray of 3M77.
I did that for all of the model -- took two sheets of foam (gosh 2 bucks) instead of one. If I'd been smarter about it I would have just laminated the whole foam sheet together before cutting parts. But I didn't...
Anyway, here's progress so far.
The nice thing about laminating for a profile model is that the color is on both sides of any part.
Old Aug 24, 2011, 09:55 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
looks great
what thread did you get plans from?
this one?
http://www.rcgroups.com/forums/showt...blue+albacorde
Old Aug 24, 2011, 10:12 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Well, this one, which was the original thread:
http://www.rcgroups.com/forums/showthread.php?t=339432
Old Aug 24, 2011, 10:21 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Cool thanks
This model looks agile and quick
Old Aug 25, 2011, 06:08 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Great job VT , I will certainly search for this material in my area...
gpw is online now Find More Posts by gpw
Old Aug 25, 2011, 11:35 AM
emulsifier12 is offline
Find More Posts by emulsifier12
United Kingdom, England, Nuneaton
Joined Dec 2010
Hi,
You could always laminate two different colours. Then it would be easy to identify for inverted flight etc.
Wish we had dollar tree type foam here in the UK for the same price as you guys.
emulsifier12 is offline Find More Posts by emulsifier12
Question Dollar Store Foam paper removal procedure? And UM foam builds. Razors edge 29 Foamies (Scratchbuilt) 365 May 27, 2011 08:32 PM
Three Sheets of 3mm Thick Gray Depron Foam speedster239 Non R/C Items (FS/W) 4 Jun 25, 2010 12:14 PM
3mm and 4mm EPP foam sheets? Martin Hunter Foamies (Kits) 4 Nov 12, 2003 12:54 AM
Source for foam core / paper skinned foam sheets Kevin Murray Electric Plane Talk 6 Sep 08, 2001 05:07 PM
