Old Aug 22, 2011, 02:32 PM
SquireM is offline
Find More Posts by SquireM
Joined Mar 2010
Thoughts on FPV pods for the Easystar
DIY Drones just came out with a new pod for FPV (and UAV) on the EasyStar.
Description:
Several things I really like about it is there is ample room for all the other gear I eventually want to get. It's light and, most importantly, it allows you to look down.
Until today I had my eye on the ReadyMade Pod.
Description:
I do like the look of it more, but you don't see that while flying.
What I haven't found yet is a set up that will allow me to look 180 degrees in all directions. Though I believe both could be modified to so. If I want do modify something, it would seem wood is easier to play with than plastic, though perhaps it's a wash.
Both cost about $40 and neither come with servos.
Thoughts?
SquireM is offline Find More Posts by SquireM
Old Aug 22, 2011, 03:23 PM
Vitamin_J is offline
Find More Posts by Vitamin_J
Denver, CO
Joined Dec 2004
Here is my EZ* "pod:"
I've moved the vtx into the belly for a straight coax since these pics.
Vitamin_J is offline Find More Posts by Vitamin_J
Old Aug 22, 2011, 03:50 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Attachment 4228760
Attachment 4228761
Thoughts?
The DIY Drones pod looks like it is for the Micro Cameras. I'd be sure the camera you'll be using will work.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Aug 22, 2011, 03:53 PM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
No scrap balsa lying around? Make it just the way you like
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Aug 23, 2011, 11:34 PM
DMEN is offline
Find More Posts by DMEN
DMEN's Avatar
Sacramento, CA
Joined Nov 2009
Readymaderc gopro pod for easy star gives me 180 in all directions with tx set at 150% travel.
DMEN is offline Find More Posts by DMEN
Old Aug 23, 2011, 11:59 PM
hobbyboy is offline
Find More Posts by hobbyboy
United States, AK, Wasilla
Joined Nov 2001
Readymade is geared and uses a standard servo for 180 degrees. With a servo stretcher you can do 360. That is my set up on a SW.
hobbyboy is offline Find More Posts by hobbyboy
Discussion Your thoughts on these goggles for fpv Disarray FPV Talk 7 Aug 06, 2011 03:00 PM
Wanted FPV Pod Pan & Tilt Kit for EasyStar consta FPV Equipment (FS/W) 0 May 02, 2011 12:06 AM
Discussion My thoughts on the Parkzone Radian as an FPV platform & request for next model ideas Craig9080 FPV Talk 20 Jan 12, 2010 04:46 PM
Discussion Pods on an Easystar for vertical photography harrys one Aerial Photography 12 May 17, 2008 01:31 AM
Discussion Advice on 36mhz antenna placement on Easystar FPV project chancesAU Radios 0 May 03, 2008 06:12 AM
