This thread is privately moderated by bob4432, who may elect to delete unwanted replies.
Old Aug 22, 2011, 10:34 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Alert
Group buy frsky tfr4 fasst compatible cppm out
HK did end up carrying this and they are currently in stock for $28.29 - FrSky TFR4 FASST
This Group Buy is obviously cancelled but appreciate those that were in it, will be contacting you about this shortly.
Brian/bob4432
I am putting the Group Buy on hold as I have received information that HobbyKing should have these units around Sept 8. I am assuming that if HK does offer these they will be cheaper than this group buy could offer due to the quantity that HK can buy at. Thanks in advance for those that were participating but it looks like they will be out soon enough for all of us .
Brian/bob4432
GROUP BUY FRSKY TFR4 FASST COMPATIBLE CPPM OUT RX
Setting up a group buy of the FrSky TFR4 FASST Compatible CPPM OUT RX. The RX has the ability to put out 8 Channels via a PPM signal along with PWM RSSI for you FPV flyers. If you are using normal servo connections, this unit will put out 4 channels.
image courtesy of FrSky
1.1 Compatibility:
FASST 2.4G: Air Systems (7CH Mode/Multi Mode) & Surface Systems (C1 Mode)
FrSky TF Modules: TF-8M, TF-14M
1.2 Specifications:
Number of Channels: 4
Operating Voltage Range: 3.5V~10V
Operating Temperature Range: -10℃~80℃
Dimension: 34*19*8mm
Weight: 6.2g
1.3 Features:
1) Compatible with FASST 2.4G: Air Systems (7CH Mode/Multi Mode) & Surface Systems (C1 Mode)
2) CPPM and RSSI (PWM) output - If CH3 and CH4 are connected by a jumper, CH1 will output CPPM for CH1~CH8, and CH2 will output RSSI (PWM)
3) Lighter weight and physically smaller;
4) Two selectable failsafe setting options.
FrSky TFR4 Webpage / Link to TFR4 Manual
We need at least 20 units to get this group buy going. I am going to buy 2 or 3 so that leaves only 17 or 18 to get the Group Buy going. According to FrSky I will have the units in hand 4-10 days after the order is placed.
Price: $38US + Shipping
Shipping Costs: I plan to use the USPS Small Flat Rate Box for shipping both US and International. This equals $5 for US resident and $13.25 for International. From the data given to me by FrSky the units come blister packed and it looks like I could get 4 in the USPS Small Flat Rate Box.
Once we hit the 20, I will put up paypal info - I would suggest doing a regular transaction and you pay the fees - Make sure you put in the notes section your username and I will ship the unit/s to the paypal address, so please make sure that is up-to-date.
** Any warranty issues will be between you the buyer and FrSky
At this time please respond with your name and how many units you would like.
I will update this portion of the thread/blog so all new information will be in this area.
Bob4432/Brian
---- The List ----
bob4432/Brian - 3 - US
SeismicCWave - 1 - US
AP_OZ - 4 - AUS
bob4432 is offline Find More Posts by bob4432
Last edited by bob4432; Oct 26, 2011 at 06:19 PM. Reason: updates / clarification / pics moved
Old Aug 24, 2011, 06:58 AM
AP_OZ is offline
Find More Posts by AP_OZ
disenfranchised...
AP_OZ's Avatar
Joined May 2010
I go in for 4. I am in Australia but can provide a US address if easier for you?
Cheers,
John
AP_OZ is offline Find More Posts by AP_OZ
Old Aug 24, 2011, 09:06 AM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
cool unit, ok i am in europe, but if i would be in the us...
Goofy23 is offline Find More Posts by Goofy23
Old Aug 24, 2011, 10:32 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
Cheers,
John
John,
I do not have an issue sending to AUS or anywhere, but the cost would go up due to the shipping cost, that is all. By buying multiples that brings shipping more inline.
These come blister packed and I am pretty sure I could get 4 in the Small Flat Rate box with the dimensions that FrSky has supplied .
Thanks for your interest in this and hope we get to the 20units for the FrSky minimum.
Brian/bob4432
Wanted fasst compatible rx's darkside212 Aircraft - General - Radio Equipment (FS/W) 6 Aug 05, 2011 10:27 PM
Discussion FRSky TFR6 and TFR4 FASST Compatible Receivers AndyOne Radios 0 Aug 01, 2011 12:07 PM
Sold SPEKTRUM compatible dsm2 6ch rx with satilite 35$ shipped only 5 sets left ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 18 Feb 18, 2011 06:54 AM
