Old Aug 22, 2011, 12:17 AM
agjell is offline
Find More Posts by agjell
Registered human
agjell's Avatar
Joined Nov 2007
Remote Binding Problems (E-Fly 2.4Ghz Micro Heli)
First of all: I have brand new batteries in the remote and the lipo is fully charged.
Video of my issue:
E-Fly EF-136 problems (0 min 59 sec)
I'm having trouble binding my new E-Fly 2.4GHz Micro Heli remote. When I got the heli I could not get it to fly. It kept blinking red and the remote had a solid red light. So I figured I had to bind the remote. But I cannot manage to do it, and I've looked everywhere for a solution. I have tried to bind this remote now at least a hundred times, and now I'm giving up. Am I doing something wrong or is my heli/remote DOA?
agjell is offline Find More Posts by agjell
Old Aug 22, 2011, 11:06 AM
agjell is offline
Registered human
agjell's Avatar
Joined Nov 2007
Anyone?
Old Aug 22, 2011, 05:33 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
You would probably have more luck if you asked in the multi rotor forum http://www.rcgroups.com/multi-rotor-helis-659/
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Aug 23, 2011, 11:47 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
That is definitely not a multi-rotor heli. So asking there (as you suggested him) is actually pretty bad advice That being said, I don't know the answer.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 23, 2011, 04:18 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
It certainly is......it's clearly a multi rotor coaxial heli which is exactly the forum he needs to be in. The term multi rotor on RCG has only recently been connected to quads or other type of non heli aircraft so just about anyone that has beenon RCG for more than a year will call coaxials multi rotors. The coaxial forum was in fact called the multi rotor forum for many years until the quad guys petitioned for their own forum.
Xrayted is offline Find More Posts by Xrayted
Old Aug 23, 2011, 05:56 PM
Hellraser's Avatar
UK
Joined Jul 2007
As Xrayted said the forum was called multi rotor long before quads and the like hit the scene and at that time Co-Ax's such as Esky lama, walkera 5#4 were the main heli's in that category - for a time cop you detective abilities leave much to be desired
However I do take your point - it was not the best advice since Multi rotor has been hijacked by the quads.
Regards David
Old Dec 10, 2011, 01:21 AM
Straight Up is offline
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Joined Mar 2007
I've got the same problem. We bought two: one bound and flies well, the other won't bind. I found the antenna was not properly soldered to the circuit board - it pulled away when given a very light pull. If you look at the back of the board (top right) you'll see the connection marked "ANT". I removed the rubber isolation (that stops the antenna shaking itself loose) and resoldered the join. This should have fixed mine, but it didn't. Might be worth checking yours though...
Straight Up is offline Find More Posts by Straight Up
New Product Snap&Fly 3in1 2,4Ghz and new micro WW I models verticalhobby Scratchbuilt Indoor and Micro Models 53 May 19, 2012 02:27 PM
Discussion E-Fly ETB6II 2.4GHZ wireless trainer function Glen C Radios 0 Jun 29, 2011 01:02 PM
Discussion Hawk 2.4Ghz Micro Coaxial Heli w/ 2.4Ghz Tx TrustyRuss Micro Helis 41 Oct 05, 2010 06:35 AM
New Product Micro Cessna 2.4Ghz Airplane w/ 2.4Ghz Ready-2-Fly CrashingDutchman Scratchbuilt Indoor and Micro Models 22 Jul 14, 2010 12:47 PM
New Product S-Pro FP II 2.4Ghz Micro Heli w/ 2.4Ghz Tx... It's a 4 channel. boredom.is.me Micro Helis 2 Feb 18, 2010 04:19 PM
