This thread is privately moderated by whedge, who may elect to delete unwanted replies.
Old Aug 21, 2011, 07:12 PM
whedge is offline
Find More Posts by whedge
Trader Rating: 0
United States, MA, Whitinsville
Joined Sep 2010
Trader Rating: 0
4 Glow RC Airplanes for sale. 3 with Saito 82 engines installed
Selling all my RC Glows. I'm going bigger. All gas for me from now on!! I have 4 planes for sale for $650. You can also buy any one for $200ea. These are great planes. If you take all four planes, I'll add in my fuel, starter battery, starter, Extra Futaba FP-R-138DP receiver, extra Futaba FP-R127DF receiver, Futaba S3004 servo, S3010 servo and a brand new LIFE 1300 battery (cycled a few times only). Local Pickup only. Located in Whitinsville, MA. will drive up to 1 hour to meet. Cash only please.
Hanger 9 Funtana 50X - This plane flies great. One rough dead stick landing loosened the gear. Beefed up and fixed better than new. Never crashed. All built, it will only need receiver, elevator and rudder servos to fly.
Wingspan: 56 in (1422mm)
Overall Length: 56.75 in (1441mm)
Wing Area: 714 sq in (46.1 sq dm)
Engine Size: .32--.46 2-stroke; .40--.82 4-stroke
Motor Size: Motor (for electric conversion) E-flite Power 60 brushless outrunner (EFLM4060A)
Radio: 4 channels with 5 servos
Trim Scheme Colors: White (HANU870), Pearl Blue (HANU845), Cub Yellow (HANU884), Silver (HANU881)
CG (center of gravity): 5-1/16--5-11/16 in (129--144mm) behind the leading edge of the wing.
Control Throw (Ailerons): Low Rate: 3/4 in (19mm) (9°) Up, 5/8 in (16mm) (6°) Down. 3D Rate:2-1/8 in (54mm) (27°) Up, 1-7/8 in (48mm) (23°) Down
Control Throw (Elevator): Low Rate: 7/8 in (23mm) (11°) Up & Down. 3D Rate: 2-5/8 in (67mm) (40°) Up & Down
Control Throw (Rudder): Low Rate: 2 in (51mm) (25°) Left & Right. 3D Rate 3-7/8 in (98mm) (45°) Left & Right
Comes with:
Saito 82
Throddle servo Futaba S3004
Aileron Servos Futaba S3004
Rudder and Elevator servos will be removed
Receiver not going with plane
Hanger 9 Twist 3D - Never crashed or repaired. Flies great and is so gentle on landings. Needs nothing. Ready to fly.
Wing Span: 47.75 in (1212.85mm)
Overall Length: 48.38 in (1228.73mm)
Wing Area: 747.37 sq in (48.2 sq dm)
Flying Weight: 5-6 lb
Engine Size: .40-.48 2-stroke; .50-.82 4-stroke
Radio: 4-channel
Servos: 5
Trim Scheme Colors: HANU872 Bright Yellow, HANU867 Deep Pink, HANU868 Smoke Purple
Comes with:
Saito 82
Futaba S3004 servos in Ailerons, Rudder and Elevator
Futaba FP-S48
Futaba-R127DF low band with a 27 crystal.
U-CAN-DO 3D. This is my best flying glow. This was crashed. Broke some stringers in the fuselage. Repaired and flew just as good after. Is still my best flying glow. The cowl is off, but I do still have it and is in good shape. Easy to reinstall. All built, only needs receiver to fly
Wingspan: 56.75 in (1440mm)
Wing Area: 904 sq in (58 dm2)
Weight: 5.25 lb (2380g)
Fuselage Length: 58.5 in (1485mm) Wing Loading: 13.7 oz/sq ft (42 g/dm2)
Requires: 2-stroke .32-.51 cu in (5-8.5cc) or 4-stroke .52-.70 cu in (8.5-11.5cc) engine, 4-channel radio w/6 servos, glow fuel and support equipment. Minimum requirement for 3D flight is a .50SX engine.
Comes with:
Saito 82
Elevator servos Futaba S3004
Rudder Servo Hitec HS-5645 MG
Hobbico Sukoi SU31 - Not my type of plane. Good sport plane, but will not do 3D. Keep this one light. I would install a two stroke 60. Very realistic looking and flying plane. This one flew 10-15 times, but took the radio gear and engine out to put in the Funtana 50. All built, just needs all servos, receiver and engine. Landing gear came loose, so beefed up and better than new. Never crashed. Will part with this one for $100.
Wingspan: 61 in [1550mm]
Wing Area: 708 sq in [45.7 dm2]
Weight: 7.5 - 8.5 lb [3400 - 3850g]
Wing Loading: 24 - 28oz/sq ft [73 - 85 g/dm2]
Length: 51.5 in [1310mm]
Radio: Four-channel with 5 servos
Engine: .50 - .75 cu in [8 - 12cc] two-stroke,
.70 - .91 cu in [11. 5 - 15cc] four-stroke
whedge is offline Find More Posts by whedge
Sold RC Airplane / Airplanes For Sale! Lot's of Planes! Check out it out! RC4x4 Aircraft - Fuel - Airplanes (FS/W) 23 Aug 25, 2011 12:39 PM
Sold 4-Used glow engines for sale AB Bob Aircraft - Fuel - Engines and Accessories (FS/W) 2 Aug 20, 2011 08:39 PM
Sold For sale four 4 stroke engines saito and surpass johnsheri Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 06, 2011 12:07 PM
Sold Saito .72 and .82 Engines For Sale Dynomike Aircraft - Fuel - Engines and Accessories (FS/W) 7 Sep 08, 2010 06:56 PM
Sold 2 SAITO FA-82 ENGINES 4 Stroke Engines 1 Brand NEW 1 USED TWICE rcp51 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 11, 2010 09:20 AM
