OK here goes, part one of the plans, please excuse the rough drawing, but it is as near to scale as I can get it, I am drawing up the wing layout at the moment, that will follow shortly, I am making a few changes so bear with me.....
It was a toss up between longer fuselage or bigger VS, I added some balsa strips onto the VS and it doesn't seem to alter the aesthetics, so I'm sticking with that. For my sanity,
I am building some dihederal into the wings, which consequently, will be as one complete wing this time round 2.75deg, I am also building washout into the wing.
The fuselage will be slightly skinnier and I am looking into a more satisfactory way to mount the aileron servos. I have completely redesigned the battery compartment, and the rudder and elevator servos are going to mounted into the fuselage nearer to the tail so they can be controlled with wire instead of the bowden cables, which were ok, just ok lol.
Oh and I am still contemplating whether or not to leave the foam out and just build her from balsa, had all sorts of issues with weak points on the fuselage, will still probably use a solid foam nose cone though for impact resistance...
I will probably be moving those wing spars forward to allow for positioning of the aileron servos.
I think that's about it for now....
